Power Stop Brake Pads
Discussion in '3rd Gen Tundras (2022+)' started by eddiefromcali, Apr 10, 2024.
  1. Apr 10, 2024 at 11:34 AM
    eddiefromcali
    eddiefromcali [OP] New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    ryanwgregg likes this.
  2. Apr 10, 2024 at 12:30 PM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    pads won't cause pulsation that's a rotor issue not sure if there is a better option yet than OEM but I've had good luck with Powerstop.
  3. Apr 10, 2024 at 12:38 PM
    eddiefromcali
    Eddie
    100% Stock
    not always the case. Rotor could be fine but could have uneven pad material on the rotor
    raylo likes this.
  4. Apr 12, 2024 at 7:53 AM
    eddiefromcali
    Eddie
    100% Stock
    Just a follow up post....went with napa UP 882853CR rotors and power stop 17-2439 pads from rockauto
    pwpblue and Jettster like this.
  5. Apr 14, 2024 at 7:18 PM
    blueprint
    blueprint New Member
    Jeremy
    Alabama
    2022 Blueprint Tundra Platinum
    how are the quality of the rotors? are they any heavier than the OEM ones?
  6. Apr 14, 2024 at 7:39 PM
    eddiefromcali
    Eddie
    100% Stock
    Haven't received them yet. I'll post some comparisons when I do
  7. Apr 28, 2024 at 8:19 PM
    eddiefromcali
    Eddie
    100% Stock
    Napa rotors on right. 20mm thick. Stock rotors are 19.83 inside the wear lip. Lip is 20mm thick
    Napa rotors vents are 9.20mm X 8.43mm. Stocks are 8.99 X 8.23mm
    Both 16.5lbs
    ATV25 and Kap1 like this.
  8. Apr 28, 2024 at 11:45 PM
    eddiefromcali
    Eddie
    100% Stock
    Couldn't get the ebrake to retract via the 3 up and 3 down and hold sequence. Instead, I fed 12v to the ebrake motors. You'll need a very thin 17mm or needle nose vice grips to hold the slide pins while removing the caliper bolts. Very straightforward job other than the ebrake.
    Black widow TRD likes this.
  9. Apr 29, 2024 at 12:22 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    I tried that 3/3 after seeing it on Car Care Nut with no luck either. Theres got to be a trick somewhere. Maybe a plug in retractor tool with a battery in it.
    raylo likes this.
  10. Apr 29, 2024 at 12:41 AM
    eddiefromcali
    Eddie
    100% Stock
    Yep, tried it a few different ways and I could get the dang BRAKE to flash real quick but never heard the motors retract. Wired up one of my M12 batteries and retracted them that way. I agree with you though, there's got to be something we're missing
    raylo likes this.
  11. Apr 29, 2024 at 7:30 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    There’s no special trick for the electronic integrated parking brake on the 3rd gen. It’s just like a regular mechanical integrated parking brake.
    Just got to turn the piston in with a brake caliper compressor tool. They like $25 from Amazon.
  12. Apr 29, 2024 at 8:01 AM
    eddiefromcali
    Eddie
    100% Stock
    Did try that and it did spin but it kept twisting the seal. Didn't know that was the actual procedure. Thanks!
  13. Apr 29, 2024 at 8:57 AM
    PNW Tundra Mike
    Southern Cal
    I’ve never waited this long for 3rd party shop manuals before on any vehicle. The level of tech on this truck, on all vehicles really, must have really caused a huge backlog for the editors of these.
  14. Apr 29, 2024 at 10:01 AM
    eddiefromcali
    Eddie
    100% Stock
    I've used alldatadiy for other vehicles and it looks like they have something for 3rd gens already.
  15. Apr 29, 2024 at 10:12 AM
    PNW Tundra Mike
    Southern Cal
    Thx. I’ll check that one out. All I found was a digital version from FM. $100 download. I’m highly skeptical though. Their vehicle brand list isn’t alphabetized correctly, all reviews are 5 stars including the ones that are 100% complaints. Very sketch. Asked them to send examples of the 3rd Gen Tundra book. We'll see
  16. May 12, 2024 at 9:33 AM
    BlazingGSXR
    BlazingGSXR New Member
    Jeff
    2022 Army Green Crewmax Tundra Limited
    AFE hot charge pipes, TRD air filters
    Brakeperformance.com
    These are for the rear. Have had the fronts on for around 15k miles already. $210 for pads and rotors
  17. May 18, 2024 at 1:03 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    How's the fronts on .. wear/performance/squeaks ect ? They look great for the price.
  18. May 18, 2024 at 1:05 PM
    BlazingGSXR
    Jeff
    They have been great. No squeaks, no pulsating, just good stopping power.
  19. Mar 26, 2025 at 6:06 PM
    Gtatx
    Gtatx New Member
    Gohar
    22 TRD Pro
    35 12.5 18 RT Trails,
    So i was in a similar situation today. I go to this Asian auto mechanic for last 20 years and he had a trick up his sleeve. He had a 12v battery and the battery cable with stripped cables on one side. They just touched the stripped side to the parking brake plug and it released the parking brake.
  20. Mar 27, 2025 at 7:55 AM
    David713
    David713 New Member
    2023 Tundra Platinum
    King shocks, TRD UCAs, Hellwig rear bar, 295/60-20 tires on 20x9 Sparcos
    I just put Porterfield 4S pads on my Tundra. After watching a few youtube videos, I figured out the rear brakes. My method:
    1 Unplug the emergency brake and use a 12V battery with small jumper wires to release the emergency brake. Note polarity of switch so you know if you're tightening or loosening for step 3.
    2. take the caliper loose from the bracket using a 14mm socket and skinny 17mm wrench. They're loctited so takes some effort.
    3. use the 12V battery to power the emergency brake to full loose. You'll know when it's fully backed off when the caliper starts to rotate.
    4. straighten out the piston boot which is now probably twisted from the piston rotating.
    5. use the battery to rotate the piston to proper orientation (notches align radially with disk, one notch towards center of rotor, other notch outwards from rotor)
    6. use channel locks or similar to compress the piston.
    7. install pads and put it all back together (don't forget loctite on caliper bolts, probably should be red but at minimum use blue)
    8. pump brakes, actuate emergency brake, drive forward and backwards hitting brakes until any error codes go away.
