2007 with 147k?
Discussion in '2nd Gen Tundras (2007-2013)' started by thomps132, Apr 18, 2024.
  1. Apr 18, 2024 at 4:47 AM
    thomps132
    thomps132 [OP] New Member
    Hello everyone,
    I really like the older model Tundras. I found a 2007(SR5 4.7 V8) model that's in excellent condition, inside and out but it has 147k miles on it. I am considering purchasing it. Based on my research, toyotas are very reliable automobiles, but do you think buying it with 147k miles would be a wise choice or is it to risky?
    Thanks in advance
  2. Apr 18, 2024 at 6:04 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Welcome! I don't think that buying a Toyota with 147k is a bad idea at all. With the 4.7, I believe that the timing chain needs replacement every 120kish miles, so I would definitely check with the current owner for some service records to be sure.
    Bob likes this.
  3. Apr 18, 2024 at 6:32 AM
    thomps132
    I sincerely appreciate your response. Thank you so much!!
    BreyTundy likes this.
  4. Apr 25, 2024 at 8:57 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    4.7 is a timing belt. Definitely has a mileage limit for replacement. It's not something to do unless you are confident.
    But those are truly one of the longest lasting motors in the world, and compete only with Toyota Diesels for longevity.
    There are so many bolts on the engine when you remove them for goodness sake remember to put the same bolt
    back in the same location. Very subtle differences in lengths and it bit me on the ass when I did mine, we had to
    go back thru a bunch to sort out our error when I did mine. But it's the smoothest running V8 on the planet.
  5. Apr 25, 2024 at 10:20 AM
    AZBoatHauler
    So.Arizona
    I have a Sequoia with 246k on it. Don’t be scared of mileage if everything else checks out.
    Cruiserpilot likes this.
  6. Apr 27, 2024 at 7:35 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    I have a 2007 4.7L if the timing belt hasn’t been done change it out, consider also replacing the water pump which is behind the timing belt it would be a bitch if you changed out the timing belt and the water pump fails, I just change out the water pump with every timing belt replacement whether it needs it or not. I have replaced the timing belt 2x with about 100-120k miles on each one they were both in good condition when I did Toyota recommends every 90k miles which I think is overkill I would also replace fluids ( diffs, transmission and power steering and transfer case if you have 4 wheel drive I would assume none of the maintenance was done
    Spark Plugs should also be done every 100k miles when I have done mine the plugs were all in decent shape
  7. Apr 28, 2024 at 5:52 PM
    cdub61
    cdub61 New Member
    2007 Blue Tundra SR5 TRD 4.7L
    Bought my pickup with 186000 miles. Changed my timing belt and water pump at 188000 miles. It was all original in there. Water pump leaking badly. The Belt was way past due. The job is long and a bit tedious but very doable in your driveway with basic hand tools. Take pictures as you go and follow along with Timmy the Toolman on youtube.
