BEDRUG XLT install tip
Discussion in '3rd Gen Tundras (2022+)' started by jctmundra, Apr 27, 2024.
  1. Apr 27, 2024 at 9:01 PM
    jctmundra
    jctmundra [OP] New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Recently picked up a BedRug XLT for my 5.5 bed. No instructions. Part in the bed was obvious. Tailgate not so. Tailgate piece has two full length velcro strips. looking at the tailgate, it has a continuous ridge at bottom. I attempted to mount along the bottom ridge and top was at the bottom of the cap molding. No go as the fold is too large. If the fold is down, the gate will not close. I repositioned the tailgate carpet such that it was at the very top of the tailgate, this worked. The tailgate carpet now has velcro on the vertical ridges on the bottom and at very top of the tailgate, and closes.
  2. Apr 28, 2024 at 3:57 AM
    Rickoo
    Rickoo New Member
    Yeah, you have to play with the position to get the tailgate portion high enough, but won't interfere with closing. Just below the top edge of the plastic trim seems to work just fine. Velcro gets put on where needed. This Velcro has the highest bond strength of any I have ever seen.
  3. Apr 28, 2024 at 8:42 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My kit came with a bunch of strips for the tailgate but the only 2 big ones for the bed.
    I just ran the smaller strips top to bottom on the tailgate. At first the wrinkle/joint was pointing up and now it has dropped down but doesn't seem to affect the tailgate closing.
  4. Apr 28, 2024 at 4:10 PM
    dccrens
    dccrens New Member
    Leesburg, VA
    2024 Tundra I-Force Max Hybrid, Lunar Rockin!, 6.5 Bed
    2024 Limited, iForce Max hybrid, 6.5ft bed, TRD off-road package, TRD 20in wheels, TRD Grille, TRD skid plate, blacked-out badges, NYTOP Rear Recovery Points; Red, aFe Power Front Tow Hooks Red
    I took the bolts off and slid my bedrug under the tailgate top. Then put the screws back on. Looks much better. 3-PXL_20240408_215040439.jpg
    MAC25Tundra, SnowToy, akira and 6 others like this.
  5. Apr 28, 2024 at 4:13 PM
    jctmundra
    Northern VT
    And just when I thought I was done - looks great
    dccrens likes this.
  6. Apr 29, 2024 at 10:57 AM
    volleyball
    volleyball New Member
    I am leaning towards the mat. My cap has matching material.
    How is it on the knees crawling on it?
    Has anyone gotten the rug that has bed lights
  7. May 2, 2024 at 8:27 AM
    bullet3z
    bullet3z New Member
    24 Tundra
    This is my 3rd truck with a bedrug. Under the rug there are reverse ribs of padding that allow the rug to sit flat in the bed. This is also nice for crawling around on your knees. Like when you need to get something that is up near the cab.
    ChucklesToy likes this.
  8. May 21, 2024 at 6:58 AM
    RockwarriorTRDPro671
    RockwarriorTRDPro671 New Member
    Ray
    2010 Tundra RockWarrior / 2024 Tundra TRD Pro (May 2024)
    Yes there is a patter to for cut out on the outside but I installed it first and had all the bolts in place, pressed against bedrug and poked holes in every location to include the bed hooks so that everything was inside the bedrug to look factory as possible, took a while but well worth it.
    Black widow TRD likes this.
  9. Jun 10, 2024 at 8:47 AM
    tamadabee128
    tamadabee128 New Member
    It mentions on their site the Bedrug won’t work with the oem drop in plastic liner. Did you have to remove the liner or did it work with it? Thanks!
  10. Jun 10, 2024 at 8:50 AM
    jctmundra
    Northern VT
    I have the factory sprayed in liner, not a drop in.
  11. Jun 10, 2024 at 8:58 AM
    volleyball
    There is no drop in for the 3rd gen. I wish there was
    It would replace the drop in on a second gen
  12. Nov 6, 2024 at 10:51 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    How is it holding up? Mine delivers this Friday. Do you have the oem spray liner underneath?
  13. Nov 6, 2024 at 10:56 AM
    dccrens
    dccrens New Member
    Leesburg, VA
    Holding up great! No issues. When I did the install, I used extra Velcro tape patches and screwed it down under the tailgate. So, no issues moving around or coming off at all. Still looks like the day I installed it even with all my fishing and bee keeping gear in there 24/7!
    PS. No, I ordered the spray on liner but they didn't put it in in the factor/port. So I went without it. With the bedrug you really don't need it.
  14. Nov 6, 2024 at 12:04 PM
    eddiefromcali
    Eddie
    100% Stock
    Thats good to hear that its holding up. I had one in my previous truck and it was awesome. I'll have to tuck it under the tailgate cap too, looks very clean. I have the bed lights, so will have to cut around those as well.
  15. Nov 7, 2024 at 6:31 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    When I installed mine the easiest way to make holes for the tie down system, 120V plug port and the side lights was to use a soldering iron. Put the bed mat in place and burn the holes in using the soldering iron. Makes for a neat install with no frayed edges or overcuts. The other thing I did was to get some edge trim from Amazon. I put it over the felt edging on the tailgate portion. Haven't had a problem with it moving or shifting at all and it protects that finished felt edge.
    https://www.amazon.com/gp/product/B0BZV2QV6X?ie=UTF8&th=1
    SDT-Online likes this.
  16. Mar 29, 2025 at 4:42 PM
    Libagui
    Libagui New Member
    Librado
    2024 midnight black Toyota Tundra Limited, TRD offroad
    Installed my bedrug today. About 5 hours of work.
    My best recommendation is to zipper it on the floor with botton side up. This will make you life easier.
    If you have a rollup tonneau, you might need thicker side seals since the clamps won't tight enough with the rails separated from the sides a good 1/8 or more.20250329_145316.jpg 20250329_152220.jpg 20250329_154222.jpg 20250329_161735.jpg 20250329_181856.jpg 20250329_193544.jpg 20250329_145316.jpg 20250329_152220.jpg 20250329_154222.jpg 20250329_161735.jpg 20250329_181856.jpg 20250329_193544.jpg
    RockwarriorTRDPro671 likes this.
  17. Apr 17, 2025 at 7:45 AM
    RDW
    RDW New Member
    Rob
    NJ
    2025 Tundra Platinum TRD Off-road
    Heritage Grille w/ TRD Marker Lights, Diode Dynamics Light Bar and OEM TRD Dash Switch, Rigid Yellow Fogs, Diode Dynamics C1 Hitch Pod Light, AMP Powersteps Smart Series, Aftermarket Power Bed Step, Bedbug XLT, Rough Country Neoprene Rear Seat Cover
    Doing this install this weekend...did you do any cutting to get this to fit under the lip? I assume you had to poke some holes in the bedbug to accommodate the screws, but the plastic trim is bulging quite a bit, so I'm just curious if you just put the edge under or if you went all the way up to the top of the trim piece?
    Thanks!
  18. Apr 17, 2025 at 10:39 AM
    eddiefromcali
    Eddie
    100% Stock
    I did the same thing...Used a soldering pen to burn a hole through. No bulge after its all bolted down and I just tucked it all the way up as far as it would go.
  19. Apr 17, 2025 at 10:41 AM
    RDW
    RDW New Member
    Rob
    NJ
    Awesome, thanks man!! Going to give this a go shortly!
