Multiple problems, can't afford new truck...help! Suggestions?
Discussion in '2nd Gen Tundras (2007-2013)' started by evidencetech, Apr 28, 2024.
  1. Apr 28, 2024 at 4:02 AM
    evidencetech
    evidencetech [OP] New Member
    Henry
    2007 Tundra
    Have a 2007 Tundra that has multiple warning lights (ABS, anti-skid, check engine and more) coming on periodically, runs EXTREMELY rough (also periodically). Has a 2017 motor which was installed in last few months. The following has been done: Knock sensors and wiring harness have been replaced; the specific things that the warning lights are for have been checked and nothing is bad; ground post cleaned/reattached; ground wire from frame to motor cleaned/reattached; two different very reputable mechanics have checked it over thoroughly, spending countless hours and have not been able to find out what's going on. I use this truck for farm and cannot afford another one (long story, but multiple equipment problems/break-downs over past year+, financial difficulties as a result). Need to haul cows to market and afraid to try with the truck in this condition. Appreciate any info you might have.
  2. Apr 28, 2024 at 5:49 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Why was engine replaced? Is it same engine as was in previously? Who did the engine swap? How long did it run
    well after the swap or did it ever run well after the swap?
    Trade in at dealer for a good used truck and cut your losses?
  3. Apr 28, 2024 at 6:54 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    If its is running Extremely rough - it will have set CELs - what are they? Those are the clues to follow.
  4. Apr 28, 2024 at 7:01 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    What codes is it throwing. I"m assuing in all this troubleshooting that you connected a code reader to the ecu.
  5. Apr 28, 2024 at 7:05 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Oh boy… 2007-2017 is a ten year gap and the extreme of the range of “interchangeable” parts.
    We need more details about how the engine swap was done. Is it running all the 2007 wiring and Engine ECU? If it’s a mix of 2017 and 2007 electrical this could turn into a big headache fast.
    Find someone with Toyota Techstream or a really good scanner, read all the codes and post them.
