  1. Apr 26, 2024 at 5:42 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    in my 'art' pile.
    oh...i was kidding... like instead of anti-sway, i meant extra-sway.
    words are hard sometimes.
  2. Apr 26, 2024 at 6:06 PM
    I'm still curious what a rear sway bar would be like.
  3. Apr 26, 2024 at 6:11 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Yep. Pretty sure its outside up per components diagram in FSM. Screech gone?
  4. Apr 26, 2024 at 6:14 PM
    ToyotaDude
    ToyotaDude Member
    +5hp
  5. Apr 26, 2024 at 6:15 PM
    ToyotaDude
    ToyotaDude Member
    One pictured stock in FSM.
  6. Apr 26, 2024 at 6:24 PM
    ToyotaDude
    ToyotaDude Member
    Spray it? How much did it take?
  7. Apr 26, 2024 at 6:51 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    It'd be like a front one but out back lmfao
  8. Apr 26, 2024 at 6:52 PM
    VR6T
    Doing the same thing, but on the clock, and on my sups 96 Dodge 1500
  9. Apr 26, 2024 at 6:52 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    drift truck on rainy days.
    455h0le_dachshund and VR6T like this.
  10. Apr 26, 2024 at 7:06 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  11. Apr 26, 2024 at 7:21 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Linky no worky.
  12. Apr 26, 2024 at 8:03 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Works for me. You may not be a member of that particular FGT group. There's so many now. I get them confused.
  13. Apr 26, 2024 at 9:20 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
  14. Apr 26, 2024 at 9:32 PM
    WTHamIdoing
    WTHamIdoing New Member
    Eric
    2001 tundra v8(2uzfe) auto extended cab
    Killmat entire cab Method 703 wheels King 2.5 coilovers w/ 700lb springs JBA UCA Coastal Off Road high clearance front/rear bumpers and sliders Dirty Deeds 250cc 12 hole fuel injectors
    I did a thing today! However I forgot to video the sound level before vs after. I believe it is about 12-17% quieter.
  15. Apr 26, 2024 at 9:41 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Does the top part of the rear cubbies unbolt?
  16. Apr 26, 2024 at 9:45 PM
    VR6T
    What brand, total square footage and how much was material cost?
  17. Apr 26, 2024 at 9:49 PM
    WTHamIdoing
    Eric
    Are these the cubbies you are referring to?
    Killmat is the brand from Amazon : https://www.amazon.com/dp/B0751CBXBT?ref=ppx_yo2ov_dt_b_product_details here is link. I bought two boxes and used about 1 1/2. I estimated about 70 sqft including roof and doors but didnt do either. I could do the roof with what I have left I think.
  18. Apr 26, 2024 at 10:22 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    jerryallday[QUOTED] likes this.
  19. Apr 27, 2024 at 3:20 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    my craftsman 14mm fit fine? Even when I torqued the main bolt down. But now I'm kinda between torque on the top nut. As of now; stock torque seems good for handling, but the bushings look kinda wonky. I may back it down from 14ft/lbs to 12? Maybe even 10. Trying to find a middle ground between longevity of the bushings/handling characteristics.
    I will note that I originally torque'd the top nut to what the instructions say. But during highway use, the truck seemed a little off.
  20. Apr 27, 2024 at 5:21 AM
    VR6T
  21. Apr 27, 2024 at 6:28 AM
    daveeasa
    I have one. On the shelf. Need longer links I believe.
  22. Apr 27, 2024 at 7:26 AM
    VR6T
  23. Apr 27, 2024 at 7:27 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    it took some messing around to get it right for me. That wrench made it easy cause nothing else would fit, my craftsman from an old mechanic set were too thick.
    I will upload a photo of what my bushings look like. Before adjusting, on the recommended specs if I would hit uneven things on the highway the truck would feel like the wheel were about to fall off. I have no problem replacing bushings in the next couple of years
    But now she rides perfect. I can see my self going looser for off road adventures
    des2mtn likes this.
  24. Apr 27, 2024 at 9:35 AM
    shifty` Oh, I have felt Cobain's sarcoma
    Well, good thing I 303’d everything while cleaning it out. Hauling paint annd styrofoam around to recycle them and a can gushed. Pretty much flaked right off after being treated with 303, applied more 303 and done.
  25. Apr 27, 2024 at 11:19 AM
    Azblue
    The Dirty T ( ^_^)_且
    See, this is why it's not worth it to recycle. Just dump it down the drain, much easier.
    bmf4069 likes this.
  26. Apr 27, 2024 at 11:30 AM
    VR6T
    Alright buddy, I'm gonna need you keep breathing calmly, but I bought something.....
    I've been checking every week since @Mr.bee told me about them and they popped in stock last night, I fell a sleep before I could order them.
  27. Apr 27, 2024 at 11:53 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    :yes:
  28. Apr 27, 2024 at 11:59 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    Truck is covered in pollen (been under the pole barn), but here's a teaser.
    Going out tonight to check the alignment
  29. Apr 27, 2024 at 12:07 PM
    abcinv
    Tommy
    NW Georgia
    I just got rid of about 10 containers of paint; used this to solidify it -
    Easy, cheap and responsible...
  30. Apr 27, 2024 at 12:09 PM
    VR6T
    Cat litter will work as well.
    BroHon likes this.
