2018 Limited - Sunroof popping when trying to move...anyone experience this?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mssmith8, Aug 31, 2020.
  1. Aug 31, 2020 at 12:07 PM
    Mssmith8
    Mssmith8 [OP] New Member
    2018 Tumdra Limited
    Description kind of says it, but you hit the button to move/slide the sunroof forward or back and there is a loud popping/clicking sound. Eventually it will move very slowly, but something is definitely wrong.
    I do not ever use the sunroof, but have had a lot of rain recently and when driving had a drip of water drop out of the map light. Thought the sunroof might not be secure and it was not raining at the time so hit the back button to slide the glass open and it began the popping/clicking like there was a motor issue. Then did the same thing when I went to move it forward. Have tried once more and same issue. Afraid to try again because I worry it will get stuck and not close.
    Truck only has 38K miles so I am guess this will not be covered under warranty, so anyone else had this issue in the past?
  2. Aug 31, 2020 at 12:14 PM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    Mine is smooth and works properly on my '18 Limited. Good Luck with your problem.
  3. Aug 31, 2020 at 3:21 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    I have a 2020 that does not do that. But the 45 mph air deflector noise took a while to figure out...
  4. Aug 31, 2020 at 5:49 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    2014 with 197k, sunroof works great, use it all the time. I'd tilt it up, and clean the seals really good, then slide it back and clean the sunroof sealing surface, you may have treesap in the seals causing it to bind, or some other kind of gunk, I think a good cleaning, and lubing up the seals would do wonders. I don't have a recommendation on a lube, maybe tire shine or somethin. I'd google it first to see what's compatible and would last.
    I had to clean mine really good after hitting mud holes on gravel roads, it was packed full of sand and clay, sunroof wasnt too happy about that.
    BUGEATER likes this.
  5. Feb 28, 2022 at 10:51 AM
    Coulson HercMec
    Coulson HercMec Sproat Lake Tanker Base Home of the Mars Bomber!
    Randy
    Port Alberni BC Canada
    2019 Black Tundra TRD CrewMax
    Rhino Boards, Toyo skins, Full tint, levelling kit TRD Performance Duals
    Hey Mssmith8, did you ever figure this problem out? What did you do to fix? Mine just started!!
  6. Mar 25, 2022 at 11:02 AM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    The moonroof in my 2019 TRD Pro started doing this crap today. Truck has less than 20K miles, and the moonroof almost never gets used. Called my buddy at Toyota and he wants to see the truck on Monday. He says it's probably stuck to the track. I wish my truck had not come with that hole in the roof.
    SuperWhitePro19 likes this.
  7. Apr 6, 2022 at 7:29 PM
    SuperWhitePro19
    SuperWhitePro19 New Member
    2019 Trd Pro Tundra CrewMax
    Sitting on 275/65r18 duratracs, truxedo sport soft roll topper, home install bed lights
    Any update? My 19 pro just started today
  8. Apr 7, 2022 at 2:45 AM
    Bad Cow
    Georgia USA
    They had the truck for two days. Replaced the cable assembly that operates the sunroof. Sunroof works perfectly now, but now my headliner is not tucked in right. Apparently they broke some clips, taking it back tomorrow for them to fix that. But the sunroof is fine.
  9. Apr 7, 2022 at 8:32 PM
    SuperWhitePro19
    Thanks for the reply. I just dropped my truck off at the dealer today so we’ll see what comes of it. Have you had any water leaks since they worked on it? Wish the pro didn’t come with one! Bummer about your headliner..
    Bad Cow[QUOTED] likes this.
  10. Apr 8, 2022 at 7:26 AM
    Bad Cow
    Georgia USA
    The truck is back in shop today for the headliner, should be an easy fix. No water leaks from the sunroof. Inside the channels are two drain holes, one on each side that allow water to drain away from the sunroof. Make sure those drains are not fouled out with debris. The main thing to remember is to USE the sunroof more often. Open and close it on a regular basis, which I never did. I'm with you, wish the PRO did not come with the sunroof, I just don't care for them. I actually thought about removing the fuse for the sunroof. That way it will not get used, but that in itself could cause problems like I had in the first place. Oh well, just gotta roll with it.
  11. Apr 8, 2022 at 4:35 PM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    2021 MGM Tundra Platinum CrewMax
    This happened to mine today. It was all going great until I decided to open the sunroof for the first time, I just bought the truck yesterday. It was all bound up and wouldn’t close. Took it to my local dealer who ordered a new cartridge, cables, etc. said it was all bound up and the cables were seized. They couldn’t even force it to move. They told me it should be fixed and back in my hands by next Friday as long as the parts get there when they’re supposed to. Damn, it’s a 2021 and only has 2400 miles! Fortunately, all under warranty! I’m guessing the first owner never used the sunroof.
    Bad Cow likes this.
  12. Apr 9, 2022 at 7:26 AM
    Bad Cow
    Georgia USA
    Hate seeing this happening with Toyota. Mine was fixed back good as new. Now I just have to remember to open the damn thing every once in a while. Really wish my truck didn't even have that hole in the roof.
  13. Apr 9, 2022 at 8:17 AM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    Plus 1 - Its like the 4wd system - use it or lose it.
    Also don't park uphill over extended periods under pine trees. The needles get past the seal and end up plugging the drain holes.
    Rain water ends up in the cabin in a location depending on how your truck is leaning.
    Mine came in on drivers pillar.
  14. Apr 10, 2022 at 4:55 PM
    SuperWhitePro19
    That will be hard for me since I live on a hill and there is no escaping pine or cedar trees! Guess I’ll just have to use it regularly and clean the drain holes every oil change or once a year… yay..
  15. Apr 10, 2022 at 4:58 PM
    SuperWhitePro19
    I hope they get your headliner straightened out for you, this all happened to me a week before my warranty expires. Thank the lord they honored it. I couldn’t imagine how mad I would have been just being out side the warranty. Any experience cleaning the drain holes/regular sun roof maintenance? I’ve seen YouTube videos of weed wackier cord. Curious as to what would be best.
  16. Apr 26, 2024 at 9:07 AM
    Swede
    Swede New Member
    2018 Platinum
    I just had my 2018 Platinum in for this issue as well. Dealer quoted me up to $4000 if everything needs to be replaced. Unfortunately, I'm passed warranty so I'll order the parts and do it myself at some point. There is a TSB out for this btw... https://static.nhtsa.gov/odi/tsbs/2020/MC-10174874-9999.pdf .
  17. Apr 26, 2024 at 1:12 PM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    Known issue, the cables rust.
