Rear leaf spring U bolt torque specs.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Eaganite, Jul 20, 2020.
  1. Jul 20, 2020 at 12:56 PM
    Eaganite
    Eaganite [OP] New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    So I am installing Sumo springs on my 2020 CM Limited TRD Off Road, and was hoping someone here could supply me with the correct torque specifications for the U bolts.
    Thanks in advance for any help!
    Gary
  2. Jul 20, 2020 at 1:32 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    I believe it's 74ft lbs if you're using new OEM U bolts and from what I've read don't reuse the old ones.
    Y0TA PR0 likes this.
  3. Jul 20, 2020 at 2:07 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    74ft/lbs on OEM, I just installed timbrens.
  4. Jul 20, 2020 at 2:30 PM
    Eaganite
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Thanks guys, much appreciated. It does seem that not reusing the U bolts is strongly advised, my springs just got substantially more expensive.
    Casper3 and Y0TA PR0 like this.
  5. Jul 20, 2020 at 2:33 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    What'd they grab you for new one's?
  6. Jul 20, 2020 at 2:34 PM
    Eaganite
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    38 bucks a pop!
    Casper3[QUOTED] likes this.
  7. Jul 20, 2020 at 2:38 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    :eek: damn! Can't remember what I paid, I put Timbrens in about 3yrs ago.
  8. Mar 1, 2024 at 1:24 PM
    MadTrapper
    MadTrapper New Member
    2018 Crewmax TRD
    So a late arrival. $66 Canadian apiece in Calgary. Almost the same price as the Sumo Springs. Wow.
  9. Mar 2, 2024 at 4:17 PM
    tufftundy11
    tufftundy11 New Member
    2000 tundra limited
    King shocks, spc upper control arms
    74 ft lbs
  10. Mar 3, 2024 at 4:00 AM
    Eaganite
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    @MadTrapper I've had the black Sumo's for almost four years now, still like them and yes I would buy again.
    What color did you buy?
  11. Mar 4, 2024 at 3:55 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Where did you buy Sumosprings at that price?
  12. Mar 4, 2024 at 4:36 PM
    Nikwho
    Nikwho New Member
    Nik
    Black 2015 Limited TRD Tundra
    Yes
    Dang. I usually run down to my buddy's spring shop and he bends me whatever u-bolts I need for $10/ea! I need to take him some beer! I just installed some air bags last week and the brackets required that I remove the stock bumpstops, which are captured under the u-bolts.
    I know that the book answer is to not re-use u-bolts, but I wasn't about to go source new u-bolts in the middle of an install. So, I re-used mine. It's my truck, and my risk to calculate. But, I snugged the down, drove on the air bags for 4 or 5 days, then crawled back under the truck and snugged 'em down again today. I couldn't tell you what the torque spec is on new u-bolts, but I can say that I have never put a torque wrench onto a u-bolt in life. I've always just tightened them by hand and probably get anything 5/8" or bigger somewhere in the neighborhood of 100 ft./lbs. Little less "umph" on smaller u-bolts. But, I've been turning wrenches, building hot rods and rock crawlers for the past 25 years, and haven't had anything come apart. Nor have I broken a u-bolt. Replace them if they're heavily corroded, sure, but just because I have to loosen some doesn't necessarily dictate that I replace them. This is just my $0.02, and it's worth what everyone paid for it. Just chiming in, since I had a wrench on my u-bolts today, and just saw this thread...
    Nik
    Ruggybuggy likes this.
  13. Apr 26, 2024 at 12:27 PM
    nyc2cali760
    nyc2cali760 New Member
  14. Apr 26, 2024 at 1:04 PM
    nyc2cali760
    Just a note. I called the dealership near me and after giving my VIN he said it was at 74ft lbs.
  15. Apr 28, 2024 at 8:29 PM
    TundraBrew
    TundraBrew New Member
    I like this response because I did not replace my u-bolts with Sumo spring install. Didn't know that was a thing.
  16. Apr 29, 2024 at 10:46 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    You’ll see as much play on this as an oil change thread. Some people will replace a u-bolt every time a wrench touches it, and some will replace them when they look like shit or don’t torque down nicely. They’ll both tell you they’re right.
    I don’t think either of them are really wrong though…
  17. Apr 30, 2024 at 4:18 AM
    Ubolts are designed with rolled threads that are a one time use.
    BR73 likes this.
