Transmission drain and fill at 130k?
Discussion in '2.5 Gen Tundras (2014-2021)' started by BrokeTreeSalesman, Apr 24, 2024.
  1. Apr 24, 2024 at 7:38 PM
    BrokeTreeSalesman
    BrokeTreeSalesman [OP] New Member
    Jacob
    2015 Silver Tundra SR5 double cab
    I recently bought a 2015 tundra from a dealership. The previous owner seemed to be super meticulous about getting it serviced every 5k miles. However I do not know for certain that the transmission was done at 60k. I’ve put about 20k miles on it and is now sitting at just a hair under 130k. I tow pretty consistently and have no issues with the transmission, and everything feels solid.
    Should I just do a drain and fill? Should I drop the pan/filter?
    Or should I just let it ride?
    Thanks!
  2. Apr 25, 2024 at 3:41 AM
    Bammer
    Monroe, CT
    Drain & Fill, repeat every 60K. Leave the pan and filter alone !
  3. Apr 25, 2024 at 7:59 AM
    Dirtytruck
    Dirtytruck Overkill it
    2021 SR5
    I’ve read of stories about guys stripping out or breaking off transmission pan bolts. So, ditto on what Bammer said. You break off or strip out a bolt and you’ve got a real headache.
    Keep in mind the pan only holds about 1/6th the total fluid in the system. My ‘21 came from the factory stating the system holds 12.2qts overall. The pan holds 2.2qts. It’s nearly all in the torque converter at any giving time.
    I do at least 5 d&f’s over a 3-5 day period. That’s just me and my way.
    BrokeTreeSalesman[OP] and Bammer like this.
  4. Apr 25, 2024 at 9:33 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    I like to do the D&F about every 30k, did the pan and filter at 30k, clean as a whistle, probably only found D&F’s moving forward. About 5 QTs every 30k and you are good to go
    BrokeTreeSalesman[OP] likes this.
