Engine swap for future
Discussion in '1st Gen Tundras (2000-2006)' started by KTM_AJ421, Apr 24, 2024.
  1. Apr 24, 2024 at 6:04 PM
    KTM_AJ421
    KTM_AJ421 [OP] New Member
    AJ
    2006 SR5 DC 2WD 4.7
    I’ve looked a bit and haven’t seen much for the 1GY understandably.
    been looking around Instagram and seen a few shops that are dropping LS motors into land cruisers during restorations.
    if you were going to keep your truck for the next 20 years and your engine crapped out, what would you swap it for? Research says not to rebuild the 2-UZ for whatever reasons whether it be rod thickness or timing belt.
    would you dump an LS in it or something from Lexus/Toyota?
  2. Apr 24, 2024 at 6:07 PM
    GenIII SBC. Hands down.
    Someone near me has a GenIII swapped T4R. I pulled up next to them on the way to the airport a few days ago.
    whodatschrome and KTM_AJ421[OP] like this.
  3. Apr 24, 2024 at 6:10 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    SBC? Short block Chevy?
  4. Apr 24, 2024 at 6:25 PM
    3rd gen GM small block, yup.
    KTM_AJ421[QUOTED][OP] likes this.
  5. Apr 24, 2024 at 6:30 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I’ve been thinking more and more about this truck the more I’m under it. This thing has zero corrosion at all and I really want it to be a classic. Just thinking about the future
  6. Apr 24, 2024 at 6:56 PM
    What's special about that particular engine? I'm not familiar with it.
    KTM_AJ421[OP] likes this.
  7. Apr 24, 2024 at 7:19 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I think it’s renowned as a plentiful engine with a vast array of aftermarket and OEM parts availability and can make huge power relatively easy.
    Tundra2, ZappBrannigan and shifty` like this.
  8. Apr 24, 2024 at 7:23 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    Plus can be mated to a 6 spd and return 325hp and 20ish mpg
    Tundra2 likes this.
  9. Apr 24, 2024 at 8:07 PM
    Yes and yes. To boot, easy to swap, lots of retrofit support. Lots of accessory setups available OEM, and oil pan options.
    But also a step backwards in reliability. Reliable but not 250k+ miles reliable.
  10. Apr 24, 2024 at 9:54 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Small block Chevy = plentiful, cheap and generally easy. It’s the “basic bitch” of engine swaps for a reason
  11. Apr 25, 2024 at 2:15 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Basic Bitch......
    ZappBrannigan likes this.
  12. Apr 25, 2024 at 4:45 AM
    I wouldn’t be concerned about a proven long lasting engine like the 2UZ crapping out, and if it did, I would pop another one in. No way I’m LS swapping this truck.
    ViktorG, 87warrior, OldGuy03 and 3 others like this.
  13. Apr 25, 2024 at 5:53 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    1kd
    1gz
    2urfse
    1vd
    15b
    i'd try to swap in anything. In fact, i oughtta be searching for a clutch pedal & bracket for when the time comes.
    3-53t detroit.
    JakeJake likes this.
  14. Apr 25, 2024 at 6:47 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    I'd pop in another 2UZ engine. Be the easiest and most straightforward option. Nothing changes.
  15. Apr 25, 2024 at 7:16 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    +1
    ViktorG likes this.
  16. Apr 25, 2024 at 8:25 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    @KTM_AJ421 are you planning to drive the Tundra to 2 MILLION miles? We already know the 2UZ can make it to 1 MILLION miles.
    ViktorG likes this.
