Battery Size
Discussion in '1st Gen Tundras (2000-2006)' started by ENOK, Apr 24, 2024.
  1. Apr 24, 2024 at 3:13 PM
    ENOK
    ENOK [OP] New Member
    Paul
    Adirondack Mountains, NY
    2000 SR5/AC/TRD BLACK 4X4
    What is the correct size battery for a 2000 Tundra.
    Thanks
    Paul
    Rsmallw2 likes this.
  2. Apr 24, 2024 at 3:18 PM
    What are your tray measuements and what was in it prior? 24F, 27F, and 35 will fit depending on your tray, IIRC.
  3. Apr 24, 2024 at 3:59 PM
    Rsmallw2
    Rsmallw2 New Member
    2005 Toyota Tundra DLCB 4WD
    N/A
    off topic but any chance you have an active Rock Auto Coupon? I haven’t got an email in awhile. Ordering my 4600s for my truck
  4. Apr 24, 2024 at 4:08 PM
  5. Apr 24, 2024 at 4:12 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Shifty makes a valid point. My 00 uses a 27F battery, but that doesn’t mean yours does
  6. Apr 24, 2024 at 5:46 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    My advice is in the world of batteries bigger is always better. So measure your tray and check the specs of the battery you are looking for. If you can fit a series 27 in there that would be best choice. There is so much electronics that cycles after key off that having that extra ah is worth it.
  7. Apr 24, 2024 at 5:50 PM
    Azblue
    The Dirty T ( ^_^)_且
    TWSS
  8. Apr 24, 2024 at 6:09 PM
    ENOK
    Paul
    Cant measure the tray tonight as the Tundra is in my shop about 10 miles away. I caqn measure in the morning and also note the cranking amps and cold crank amps, then head to NAPA. I was just hoping someone would know the proper replacement and save me a
    20 mile trip before I could go the other direction to NAPA
    Paul
  9. Apr 24, 2024 at 6:27 PM
    Rsmallw2
    Rsmallw2 New Member
    N/A
    I believe the AGM group 24F battery is recommended for an 02. I can get you dimensions from my 05 in the morning. I know some people don’t like the Napa batteries but I had a legend battery in 4.0L Tacoma and it was dependable for 4 years. I believe it’s made by Johnson Controls who also makes the trustart.
  10. Apr 24, 2024 at 6:38 PM
    I want to say the 2000-2002 with tow package had 27f, though, and had a different tray to accomodate the larger size. 35 is smaller than 24F and 27F, so I wouldn't be rushing to bother with a 35.
    Ultimately it boils down to what will fit in the tray the truck came with. Probing online, if the tray is 10½" wide, it takes a 24F. If it's 12¼" wide, it takes a 27F. Can you get the shop to measure it, @ENOK?
    Rsmallw2[QUOTED] likes this.
  11. Apr 24, 2024 at 7:09 PM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    In 2000:
    V6 - 35
    V6 w/ tow package - 24F
    V8 - 24F
    V8 w/ tow package - 27F
    only difference in later trucks was all 2005-06 V6 use 24F batteries instead of 35.
    The plastic tray wasn’t always sized correctly.
    shifty` and Cruiserpilot like this.
  12. Apr 24, 2024 at 7:53 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    So If you can fit the Series 27 that’s what I’d recommend. Nice info above.
  13. Apr 25, 2024 at 4:40 AM
    ENOK
    Paul
    dt325ic;
    thanks so much. You saved me miles to go to my shop and measure. I am off now to NAPA. Stay Safe
    Paul
    G_unit3000 likes this.
