Power steering fluid flush or D&F?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dirtytruck, Apr 24, 2024.
  1. Apr 24, 2024 at 9:52 AM
    Dirtytruck
    Dirtytruck [OP] Overkill it
    2021 SR5
    I chose the drain and fill method.
    I drove the truck around the neighborhood (1-2 minute drive) between each D&F to circulate and mix the fluid making sure I turned the wheel to the stops right and left.
    I found this method the easiest for me verses the flush method, but it was more time consuming.
    I ended up using 2.2 quarts of AMSOIL ATF with the Dexron II-III compatibility.
    The fluid became clean at the 7th drain and since I like nice round numbers I went to 10.
    Here’s what I learned:
    My ‘21 reservoir holds 7 fluid ounces.
    Since the fluid was clean and clear at the 7th drain I can calculate the system holds about 1.5 quarts. That amount agrees with what the tech at the dealership told me the system holds.
    Amazon sells in a pack of 30 some really big clear syringes called JelloShots. I tossed the syringes after completion and have 27 left.
    I found it necessary to attach a 8-10” rubber hose to the syringe in order to get thru the the fill hole and to the bottom of the reservoir and suck the fluid out.
    For refilling it’s convenient to have a funnel with a narrow spout. Hope this helps anyone with questions especially if you’ve never done this maintenance before.
    SnrDisregardo, Bammer and reywcms like this.
  2. Apr 24, 2024 at 12:47 PM
    d33pt
    d33pt New Member
    I use the pump from a shampoo bottle to extract it. Goes pretty fast.
    SnrDisregardo and Dirtytruck[OP] like this.
  3. Apr 24, 2024 at 1:17 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I did the the full flush on my first one since I was going from clear to red fluid. Now I just drain and fill the reservoir. The flush is super simple though, jack up the front end. Pull the return line, cap off the reservoir. Have someone turn the wheel left and right with the return line in a bottle and keep adding to the reservoir until it comes out clean.
  4. Apr 24, 2024 at 2:52 PM
    Dirtytruck
    2021 SR5
    Which one is the return line?
  5. Apr 24, 2024 at 3:52 PM
    Joe333x
    Joe333x Member
    Boston
    The higher one. Here's a good video.
    https://youtu.be/mAIRqYs_dkE
    Picture showing the return line
  6. Apr 24, 2024 at 5:59 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I did it the way Joe did it. Super easy and you know its completely flushed when the fluid comes out red.
    Joe333x likes this.
  7. Apr 24, 2024 at 8:27 PM
    Chip_Tundra
    Chip_Tundra New Member
    I got a fluid extractor from Amazon and pumped all the fluid out. Kept filling the reservoir until the fluid being extracted turned cherry red. A lot easier and cleaner of a method in my opinion.
    Here's a link to a vid of it being done to a 4runner. Very similar to the tundra.
    https://youtu.be/_FOYgaNMeZc?si=irf5PajzM9kyLLsb
    Yodagan, HulkSmurf14, Gaston and 2 others like this.
  8. Apr 25, 2024 at 2:58 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Dirtytruck[OP] likes this.
  9. Apr 25, 2024 at 3:40 AM
    Bammer
    Monroe, CT
    Thanks for the info, I plan on doing this soon.:thumbsup:
  10. Apr 25, 2024 at 7:27 AM
    Dirtytruck
    2021 SR5
    I like the flush method no doubt, but my maintenance is always a one man operation so I just go with the d&f.
    Before the p/s d&f I did the transmission d&f, both diffs, and the transfer case.
    Speaking of transmission d&f’s does the factory thermostat on the transmission drain fluid back into the pan when shut off hot? I installed a transmission cooler a couple years ago and have always wondered about that.
  11. Apr 25, 2024 at 9:34 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    Same
  12. Apr 25, 2024 at 11:01 AM
    pursuit2550
    I did the flush method by myself. It's no harder than a D&F, I think. As for you trans question, I would say if the t-stat is open then yes. I did a D&F the other day on my trans. I didn't think of it at the time, but the truck was at an incline and about 5 1/4 quarts came out. I had to jack the back up to level the trans and do a level check procedure to get it back to level.
  13. Apr 25, 2024 at 11:44 AM
    Bammer
    Monroe, CT
    After watching the video, seems like the route to take. Thank you
    Joe333x[QUOTED] likes this.
  14. Apr 25, 2024 at 12:09 PM
    Dirtytruck
    2021 SR5
    I’m pumping an extra 1.75qts (plus the factory stated 2.2) into an empty pan to cover for the cooler and lines. I know overfilling, if that’s what I’m doing, probably isn’t all that great for the system, but it’s that or under fill and scorch the fluid.
  15. Apr 25, 2024 at 12:16 PM
    pursuit2550
    On a typical D&F about 3 1/2-4 quarts should come out. This is with the trans leveled out. I dont know how the factory spec is 2.2 because according to all the members here, including myself, have drain almost double that. If I were you, I would do a trans level check. Making sure the trans is level to the ground, not just by parking it one level ground.
  16. Apr 25, 2024 at 5:18 PM
    Joe333x
    Joe333x Member
    Boston
    Yes, this is why when you check the level of the atf you need to have the thermostat pinned open so that the pan volume is correct with the amount needed for the cooler taken into the equation. If level was set with it closed then the pan level would be short what ever amount it takes to fill the cooler.
  17. Apr 26, 2024 at 3:34 AM
    Bammer
    Monroe, CT
    Ok, I have never jacked up the front end of the truck, where is a suitable place?
  18. Apr 26, 2024 at 4:48 AM
    pursuit2550
    You could jack one side up and put a jack stand then use the jack on the other side to level it out. Or, there is a front cross member, but I would probably use a 2x4 to spread the load more side to side instead of the load being right on the center jacking point. I am on a upward incline, so I have to jack the back end up which is easy by doing it from the differential pumpkin.
  19. Apr 26, 2024 at 7:29 AM
    Yodagan
    Yodagan New Member
    Peter
    Birmingham, Alabama
    2016 Toyota Tundra SR5
    I have a 2016 Tundra. I bought in 2019.
    I have never done a power steering d&f.
    When should I do this? Do I need to do this?
  20. Apr 26, 2024 at 7:30 AM
    pursuit2550
    Yes.
  21. Apr 26, 2024 at 8:20 AM
    Yodagan
    Yodagan New Member
    Peter
    Birmingham, Alabama
    I will get online to Amsoil and get the ATF Fluid then do the d&f when it comes in.
    Thank you.
  22. Apr 26, 2024 at 8:41 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I need to do mine as well...I have a fluid extractor and plenty of fluid...Time for some fresh fluids! Mine is dark! Thanks for the video link and suggestions!
    Yodagan likes this.
  23. Apr 26, 2024 at 9:15 AM
    Chip_Tundra
    Hey bud I get discounts on amsoil. If you want, DM me and I'll link you. *shameless plug*
    Yodagan[QUOTED] likes this.
  24. Apr 26, 2024 at 9:19 AM
    pursuit2550
    Amsoil is a over kill. But it's your money.
  25. Apr 26, 2024 at 9:51 AM
    Yodagan
    Yodagan New Member
    Peter
    Birmingham, Alabama
    @pursuit2550 I have been using Amsoil since I had my 2006 Mazda Speed 6.
    I know what you mean.
  26. May 8, 2024 at 7:37 PM
    Yodagan
    Yodagan New Member
    Peter
    Birmingham, Alabama
    I went to Home Depot got some clear 3/8" ID tubing and 3/8" barb.
    Plan on doing the power steering flush Saturday.
    Bammer likes this.
  27. May 8, 2024 at 11:48 PM
    737fixer
    737fixer New Member
    I'll admit I go overboard with the OEM fluid except motor oil but for peace of mind you can do three drain and fills once per year with the OEM stuff P/N 00718-ATF00 at $12-15 per quart and you know your good. Forever. Thats one quart per year.
    Joe333x and Bammer like this.
  28. May 9, 2024 at 3:45 AM
    Bammer
    Monroe, CT
    Thanks for that info, will be getting the same supplies.
  29. May 9, 2024 at 4:47 AM
    Yodagan
    Yodagan New Member
    Peter
    Birmingham, Alabama
    @ Bammer here is what I got at Home Depot and how much it was per item. Tax and all I spent $12.63.
    Everbilt 1/2 in. O.D. x 3/8 in. I.D. x 10 ft. Clear PVC Vinyl Tube
    Store SKU #702229
    Internet #207144365
    1 x $6.87 $6.87
    Everbilt 3/8 in. x 3/8 in. Barb Brass Splicer Fitting
    Store SKU #674812
    Internet #300096242
    1 x $4.67 $4.67
    Bammer and HulkSmurf14 like this.
  30. May 9, 2024 at 6:15 AM
    Bammer
    Monroe, CT
    Much obliged sir ! :hattip:
