LED Headlights
Discussion in 'Lighting' started by Hasib, Apr 19, 2024.
  1. Apr 19, 2024 at 5:56 PM
    Hasib
    Hasib [OP] New Member
    Installed the TRD Pro LED headlights on my 2014 Platinum using @iHacker harness and both his product and instructions were flawless.
    After adjusting the lights vertically, it appears the passenger side needs to be adjusted to aim it horizontally to the left.
    I thought I read in another post this model had that capability, but
    I can’t find the metal cap and screw.
    I’m not tearing into it again tonight, but if it in fact can be done, would someone show me what I’m looking for? TiA!
  2. Apr 19, 2024 at 8:14 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    The horizontal adjuster is located in this area but never had the need to use this, I can’t really explain how it works
    1lowlife likes this.
  3. Apr 20, 2024 at 3:22 PM
    Hasib
    That’s it. Under the metal cap is this dial with an 8mm nut to turn it. It’s seemingly counter clockwise to adjust left, clockwise to adjust right.
    it’s kind of a PITA to get it where I want it, but once the grille and surround are removed it’s remove:adjust:replace: test. And repeat.
    If only the headaches were because of it being not dark enough and the wall not flat enough, but I’ve got that going for me too.
    iHacker likes this.
  4. Apr 21, 2024 at 7:43 PM
    catdawg
    catdawg New Member
    2017 SR5 5.7L Double Cab 4x4 Quicksand
    Bilstein Level Kit w/ 285/70/18 Nitto Grapplers on Factory Wheels. TRD Cat Back Dual Exhaust System.
    Brand new to the Forum. This is not really a reply, just joining in to find out how to order the iHacker harness. Picked up new 2018 LED's at the dealer. They were $666.00 for the pair. Watched plenty of vids and read threads about this upgrade and the iHacker harness. Sounds like iHacker is the obvious best way to go. I just need the harness now to get into the fun part of this upgrade. Dan in Parts at Toyota informed me I had to officially join the Forum to order the Harness. So I'm glad to finally be official so that I can try to contribute instead of just reading.
    iHacker likes this.
  5. Apr 21, 2024 at 9:30 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    Great info buddy, I knew there was the dial to adjust it but never tried that personally all the headlights I have installed in the past arrived almost perfect on spot some just slightly up or down but that was all.
  6. Apr 22, 2024 at 3:39 AM
    Beach Toy
    Beach Toy New Member
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
    https://www.tundras.com/threads/201...G N PLAY HARNESS FOR 2014-2020 MODELS [V 2.0]
    This link should help you out.
    iHacker likes this.
  7. Apr 22, 2024 at 5:02 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    Welcome to the forum!
    To send me a message you can also use the “Start a Conversation” link under my user name, if I’m correct I talked to a guy from a dealership who was interested in ordering a harness for a friend or customer.
    Send me a PM
    texasrho83 likes this.
  8. Apr 22, 2024 at 6:05 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Was wondering if anyone has had to adjust their headlight vertically to match the height of the other light cutoff line. My buddy has a set where the driver side aims higher than the passenger side.
  9. Apr 23, 2024 at 8:19 PM
    Ricky19
    Ricky19 New Member
    Ricky
    2015 Silver Toyota Tundra
    None
    Hello @iHacker i sent you a pm I was wondering if I can get some help with a harness. I have 2017 1794 front headlights going on a 2015 sr5
