Wire colors
Discussion in '1st Gen Tundras (2000-2006)' started by albru2, Jan 15, 2024.
  1. Jan 15, 2024 at 6:33 PM
    albru2
    albru2 [OP] Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    Newb question here. Trying to figure out how to find a constant 12v for my camper shell dome light. Looking at the towing converter behind my driver side tail light and trying to match things up with the wiring diagram. I'm realizing I've never really understood what the cross hatch marks mean. See pic below. It doesn't seem like the diagrams reference these when they're listing wire colors. For instance the wire with the arrow below would just be red right? R/B would be for red with a longitudinal black stripe?
  2. Jan 15, 2024 at 6:46 PM
    bfunke
    bfunke Tundra Curmudgeon
    can you trace the wires to your trailer plug?
  3. Jan 15, 2024 at 6:48 PM
    Paxmanhp
    Paxmanhp New Member
    Paxton
    North Carolina
    2000 Tundra Sr5 v8 2wd AC, AWD swapped
    AWD swap, HID retrofit, Sequoia center console, TRD Pro Tacoma shocks, Method wheels, custom bumpers, single pane rear window
    As someone who has worked at a Toyota dealership as a tech I also don’t know why those marks are there. It is probably something to do with manufacturing and looks to be paint not actually part of the insulation, silver is very common.
    You are correct about how to read wire color, the only tricky one is blue, “L” and “LG” is light green.
    albru2[OP] likes this.
  4. Jan 15, 2024 at 7:10 PM
    albru2
    thanks, that makes me feel better! It's like some kind of secret code.
  5. Jan 15, 2024 at 7:18 PM
    albru2
    not easily - the wires seem to go through several connectors , changing colors and combining with others in conduit. I probably just need to get the multimeter out and figure out what is what.
  6. Jan 15, 2024 at 7:31 PM
    albru2
    looking at the diagram it seems like black/yellow is 12V constant but in my diagram there's 7 wires for the converter and on my truck there's 9
  7. Jan 15, 2024 at 9:46 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Those diagrams are for a specific circuit or function - you would need to search through the entire set of diagrams for the converter or the specific connectors to see what other circuits go to that unit.
    For example - if you are looking at the power distribution circuit diagram, it may not show you the taillights or turn signal wires going to the same box…
  8. Jan 16, 2024 at 5:53 PM
    albru2
    I didn't realize that, thanks for that information
  9. Apr 23, 2024 at 7:22 AM
    albru2
    In case anyone is looking for a good place to tap into power for the dome light on their camper shell/cap/topper, my 2002 with the tow package has a pretty convenient location at the towing converter. The wires don't match well with the diagrams in the FSM but I think there was a recall so maybe not the same unit that came originally. The two wires below are 12V constant and brake, at least for my year. wire colors 2.jpg
  10. Apr 23, 2024 at 7:24 AM
    I'm fairly certain that only exists in the earlier-model trucks, FYI. I defintely don't have that in my '06 with OEM tow package.
  11. Jun 13, 2024 at 1:53 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  12. Jun 13, 2024 at 2:28 AM
    bfunke
    My 2000 has it.
  13. Jul 6, 2024 at 9:19 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    having light issues, I have this box on my 2002, I dont see a wire running from battery to the back. I will try to post some pics tonight of some strange wires in engine compartment
