Goodyear Wrangler Ultraterrian AT - 275/65r20 follow up
Discussion in '3rd Gen Tundras (2022+)' started by grnwdjsn, Oct 3, 2023.
  1. Oct 3, 2023 at 6:47 AM
    grnwdjsn
    grnwdjsn [OP] New Member
    2023 Tundra Limited TRD Offroad
    Well I have a couple thousand miles on my 34" Goodyear Wrangler Ultraterrain 275 65r20. They are not as impressive as I had first imagined. These appear to be branded specifically for Discount Tire. I compared them to my last set of GY Wrangler DuraTrac's and they seemed on par with them (also having that snow rating was a plus here in Michigan).
    Pro's
    - look fantastic
    - priced right
    - Discount Tire treated me awesome
    Con's
    - Tire squirm
    - Can't seem to find the sweet spot on tire pressure
    - Varying road noise (depends on speed and turning)
    - Hold gravel like a sling shot and let go at high speeds
    - Lost 2mpg - also have 1.75" levelling kit
    This is not like a 16" tire with 35's on it. I tried to keep it pretty middle of the road on size. I had the same size on my 2019 Ram (in DuraTrac) and they were so much nicer. I even had a 2" levelling kit on that truck as well.
    The squirm seems to be settling down after a few thousand miles, but it still feels a little soft. Had pressures from 36-54 PSI.
    Take it for what it is worth. Wish I had sprung for the BFG's. I will burn these up and move on...
    Polo08816, QuicksandPNW, Kap1 and 9 others like this.
  2. Oct 3, 2023 at 1:24 PM
    malveman
    malveman New Member
    New jersey
    2022 Limited long bed MGM
    Nice honest review thanks
    23 Platinum likes this.
  3. Oct 3, 2023 at 1:33 PM
    AWDDude
    AWDDude New Member
    2023 Tundra Limited - Crew Max TRD Off Road 4x4
    Interesting, I had a set on my tacoma and loved them, never had "squirm" issues, although I would need a better description of what you mean by "squirm". I wonder if it could be a load rating thing. what load range did you get?
    ScootARoot likes this.
  4. Oct 3, 2023 at 2:44 PM
    I’ve never been impressed with a Goodyear tire. Not sure if it’s the rubber compound they use?
    SWB Tundra and DFS like this.
  5. Oct 3, 2023 at 3:07 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I ran DuraTracs on my last Tundra, mostly because I liked their aggressive look. Decent tires, but not great on longevity, and they get terribly noisy when at the end of their lives.
    I went back to BFG KO2s on my new Tundra.
  6. Oct 4, 2023 at 6:29 AM
    grnwdjsn
    By squirm, when I change lanes at freeway speeds and say cross a line or a tar seam you can feel the tires want to shift. Or when on an onramp at speed.
    https://www.google.com/search?q=tir...ve&ip=1&vld=cid:62f296e4,vid:JYp2nBtR3Ds,st:0
    Load rating is "E"
  7. Oct 5, 2023 at 9:31 AM
    AWDDude
    AWDDude New Member
    Yeah load E sounds right to me. The times I have had squirmy issues was due to under inflation or uneven tread wear due to long term over inflation. It sounds like you haven't settled on a tire pressure yet, have you tried Chalking your tires?
  8. Oct 5, 2023 at 10:53 AM
    grnwdjsn
    That is on the radar for this weekend. I am driving 1500 miles to Colorado next week to elk hunt so I hope to have it dialed in before then.
  9. Oct 5, 2023 at 2:58 PM
    AWDDude
    AWDDude New Member
    Good luck, I would be curious what PSI you end up with. I have the same TRD OR wheels and was thinking about getting the same exact tire you got, even the same size you got, since I have had such a great experience with them on my Tacoma. If you can't get them dialed in I might have to rethink my choice.
  10. Oct 6, 2023 at 8:02 PM
    23 Platinum
    23 Platinum 25 Platinum Off-road
    California
    25 Tundra Silver Platinum off-road
    Thanks, I've been considering those. I am also interested in Falken All Terrain.
  11. Nov 2, 2023 at 5:01 PM
    23 Platinum
    California
    I bought those exact same tires last week. I really like them.
    I also got a Westcott Designs 2 " 1" lift that I do not care for the ride. Probably going to have it uninstalled. Do you know if these tires will still fit on my Platinum if I go back to the original suspension setup?
    Thanks in advance
  12. Nov 2, 2023 at 5:32 PM
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    You'll be fine
    23 Platinum[QUOTED] likes this.
  13. Nov 2, 2023 at 5:34 PM
    23 Platinum
    California
    Thanks for the info!
  14. Nov 2, 2023 at 7:02 PM
    rdavenp3
    rdavenp3 New Member
    I had the same tires and liked them, until it rained. They are terrible on wet roads. The tires were breaking loose on wet roads pulling a 5 thousand pound camper. Luckily, Discount Tire bought them back with 6k miles and I put on a set of my go to tire, Michelin Defenders.
  15. Nov 2, 2023 at 7:04 PM
    23 Platinum
    California
    Good to know Discount does that . It seems like a good place to do business.
  16. Nov 2, 2023 at 7:29 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Thanks for the review. I thought about trying the UTs on my wife’s LX, but I’m seeing a lot of negative reviews.
    I’m on my 2nd set of Duratracs on my Tundra. Got 47k out of the first set. Not bad for an aggressive AT (that’s really halfway to a MT).
    Pro tip for others reading: They stay quiet if you rotate every 3k. That is KEY.
  17. Nov 3, 2023 at 3:52 AM
    grnwdjsn
    Just to follow up. I drove from Michigan to Colorado (and back) last month. I just did my first rotation after the trip. The tires seem to be settling down after that trip and a rotation. Seems like a lot of miles for break in. They performed awesome in the mountains though. I really put my truck through some rough terrain while I was out there and have no complaints on the tires offroad. There is no way I could have gone where I did on those OEM Wildpeak AT3 turds.
  18. Nov 3, 2023 at 4:55 AM
    23 Platinum
    California
    Thanks for sharing. I just purchased these based partially on your thread.
  19. Apr 21, 2024 at 5:44 PM
    23 Platinum
    California
    Update on these tires, they work well for me in California. I have to say the only visual drawback is the molding teets that stick out like crazy. I have been lately pulling them off with a set of pliers each evening. But with what seems like a million, I'll be at it a while
    pwpblue likes this.
  20. Apr 21, 2024 at 6:14 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I was no fan of Goodyear when I bought these for my 2014 in 275/60/20 and I love them.
    Ride and wear better than the stock 285/55/20 KOs and the 275/60/20 KO2s I had.
    Much quieter as well.
    I wouldn't hesitate to buy them again...:thumbsup:
