How often do you run to 0 miles?
Discussion in '3rd Gen Tundras (2022+)' started by mallard386, Mar 6, 2024.
  1. Mar 6, 2024 at 6:13 AM
    mallard386
    mallard386 [OP] New Member
    Some of our trucks have the 8 gal reserve tank (I believe it’s 8 I’m no expert). How often do you run to 0 miles till empty to actually use some of the reserve tank? Am I an idiot for thinking this might not be a bad thing to do (yes I already know the answer to that question I’m an idiot) thanks in advance
  2. Mar 6, 2024 at 6:17 AM
    joescho
    joescho New Member
    Joe
    Scranton,PA
    2024 Supersonic Red Platinum
    I wouldn't just because I don't need the hassle (or any consequence that may result) if I miscalculate.
    IsaiahCanada likes this.
  3. Mar 6, 2024 at 6:33 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    Living and working in the Tampa, Fl area, hell no would I let it get that low in gas. Just the idea of running out of gas in the middle of malfunction junction gives me the shivers.
    SWFL23TRDOR and Cruiserpilot like this.
  4. Mar 6, 2024 at 6:39 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My low fuel light is on now as we speak lol.
    I might get to zero miles left once or twice a month.
    Leo's first and Medic343 like this.
  5. Mar 6, 2024 at 6:41 AM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    I don't own a 3rd gen, but gas is gas, and I did one time run down to "refuel" (or something like that) and by the time I got to the gas station and I back calculated when the gas was pumping, I was 20 miles pass the "refuel" notice came up, not the E light, the refuel notice. I have a 38G tank, and that refill was 32.5G, so yea, we have some room.
    But will I do it again? No. I rather fill up early and save the worries about getting stuck and all that, this was a one time that just happens to be.
  6. Mar 6, 2024 at 7:12 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    I think I'm at 56 right now, but I generally try not to get below 1/2 tank or so.
    Mainly 'cuz I (my wife) don't like the sticker shock of filling the 38 gallon tank from E @ CA gas prices.
    SAGE63 and Hbjeff like this.
  7. Mar 6, 2024 at 7:19 AM
    extremes074
    extremes074 New Member
    West Coast, Florida
    22 1794 TRD Off-Road
    Have done this on a few occasions. Filling it up afterwards took 27 gallons and change...
    Kap1 likes this.
  8. Mar 6, 2024 at 7:30 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I run zero miles daily. That’s why I have cars and trucks.
    in my vehicles I generally fill up when I get under half a tank full. I generally like full tanks just in case. I also generally keep 15 gal of non ethanol fuel in cans for lawn equipment/ cars. I remember a couple of years ago when almost all local gas stations were out. Worst case, my Honda trails will run on a thimble full of fuel.
  9. Mar 6, 2024 at 7:38 AM
    SD Surfer
    Bruce
    So Cal
    I'm envious... I can't even get ethanol free at the pump. (So. CA)
    If I want to run it in my generator I have to buy it in little cans at Home Depot and it's like $25+ a gallon.
  10. Mar 6, 2024 at 7:39 AM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    I run zero miles daily if that helps.
  11. Mar 6, 2024 at 7:42 AM
    SD Surfer
    Bruce
    So Cal
    I've thought about putting one of these stickers on my truck.
  12. Mar 6, 2024 at 8:55 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    The fuel pump has a fast spinning impeller on an electric motor. These create heat. Heat is the enemy of electronics. The gasoline in the tank acts as a heatsink to cool the pump. Running it out or extremely low hinders the pumps ability to dissipate heat. Food for thought.
  13. Mar 6, 2024 at 12:39 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Never. Consequences not worth the risk and there is little to no benefit. 40 miles to empty is as low as I would risk - hopefully getting to a gas station before that. Plan in advance and fill up.
    ZappBrannigan and DFS like this.
  14. Mar 6, 2024 at 12:45 PM
    DFS
    DFS New Member
    2022 Capstone Tundra
    It's just a fuel pump, I'm sure Toyota engineers just threw a random reserve number out there with no consideration at all. Run it to empty every fill up, it's a Toyota so it'll last forever regardless of your abuse.
    Leo's first likes this.
  15. Mar 6, 2024 at 12:48 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Never have never will unless something mandates me doing that.
    75tranzam likes this.
  16. Mar 6, 2024 at 12:53 PM
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    Never is the best answer. As if things aren't expensive enough on this truck, who needs the hassle of causing potential fuel pump failures due to excessive heat or fuel filter contamination by sucking up possible debris left in the bottom of the tank.
    Tundrastruck91 likes this.
  17. Mar 6, 2024 at 12:55 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    every step helps
    I’m a runner and i’ve always wanted to get one of those stickers to mock other people who put those mileage stickers on their vehicles.
  18. Mar 6, 2024 at 1:13 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Same here, did go as low as zero miles. But to refuel it only needed like 25-27 gallons, meaning that there was like 5 gallons left in the tank somehow!
    So theoretically, once you reach zero miles mark, you may still be able to drive another 90-100 miles if the truck will allow you to use every drop of gas that's left in the tank.
    Not that you want to go that low as fuel pump may burn out eventually, but in theory it's possible as the larger tank option is 32 gallons
  19. Mar 6, 2024 at 1:58 PM
    40man
    40man New Member
    I have told my wife every day since New Year's Day that I am going to go for a run, and then I don't.
    It is by far my longest running joke of the year.
    As far as my Toyota tanks, I often run them until "ICURMT" with no ill effects.
  20. Apr 20, 2024 at 1:59 PM
    smileytn1
    smileytn1 New Member
    yep 40 miles was what the mechanic told me and they had to drop the tank for the recall and i ran it down to 9 miles and then added 2 gallons because it was over 9 miles to the dealer and glad i put those 2 in brought it up to 45 miles so i could use sport mode to check power and had plenty and wasn't hard on pump just for a test
  21. Apr 20, 2024 at 4:07 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Ran mine till it no longer showed miles to empty and showed refuel now. Still couldn't get 30 gals in the tank. Plenty of fuel in it after 0 miles shown. I prefer it this way.
    Kap1 and Leo's first like this.
  22. Apr 20, 2024 at 6:06 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    I never run it under half tank. I refuse to pump a $100 dollar bill into gas tank.
  23. Apr 20, 2024 at 6:08 PM
    Outbound
    Aaron
    Northern Alberta
    I fuel up at no less than 1/4 tank, preferably aroun 1/2 tank. This is because I'm a paranoid prepper with too much tinfoil in his hat.
  24. Apr 20, 2024 at 6:09 PM
    Hella Krusty
    Hella Krusty New Member
    NEVER....fuel at a 1/4
    T-Rex266 likes this.
  25. Apr 20, 2024 at 6:10 PM
    Hella Krusty
    Vancouver BC......1/2 tank ......wait for it......$173.00, I shit you not.
    dondino, ZappBrannigan and T-Rex266 like this.
  26. Apr 20, 2024 at 6:28 PM
    Is this my wife asking this question in a way to think it’s ok for that habit of her doing so?
  27. Apr 20, 2024 at 6:44 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I'm scratching my head why anyone would ever want to run their tank to zero.
  28. Apr 20, 2024 at 8:13 PM
    bornxbackwards
    bornxbackwards New Member
    Bruno
    QC, Canada
    2024 Blueprint Tundra SR5 CrewCab
    Cooper Discoverer AT3 XLT, Bison Soft Tri-Fold Tonneau Cover, Debadged..
    All the time if I dont leave the city. I'm not in a super crowded area and there are plenty gaz stations around. 0 reason not too. There is nothing good or bad about it.
    In roadtrip or towing I don't do it...
    Leo's first and pwpblue like this.
  29. Apr 20, 2024 at 8:40 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Natural disasters will have you wishing you had gas in the tank.
    dondino and Hella Krusty like this.
  30. Apr 20, 2024 at 8:41 PM
    Hella Krusty
    Fuel in the tank cools the pump, so the BAD thing about it is if you repeatedly run to E you are frying your pump. Kinda like death by a 1000 cuts. I replaced 2 fuel pumps on other Toyotas before someone told me that, never replaced one since....I also drilled that into my twins. You be you but remember this!
