High Pitched Ringing Noise Start-Up
Discussion in '1st Gen Tundras (2000-2006)' started by maseb42, Jul 11, 2020.
  1. Jul 11, 2020 at 12:25 AM
    maseb42
    maseb42 [OP] New Member
    2006 4.7 Tundra RWD DC
    I have an 06 Tundra RWD SR5 4DR that I bought recently, and when I start my truck from cold, there's a high pitch noise (almost a like your ears are ringing) that lasts for about 30 sec - 1 min after starting, and then stops almost like it's warming up and stops when it's warm? Any ideas on what's causing this? Cause for immediate concern?
    I appreciate any help,
    Thanks!
  2. Jul 11, 2020 at 4:44 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    When was the last time the belts, water pump, and other goodies were changed?
    That is the obvious question. For the not so obvious questions someone will be along shortly with more experience on the V8?
  3. Jul 11, 2020 at 4:57 AM
    maseb42
    The timing belt was changed less than 5k miles ago. The serpentine belt however, I do not know when or if that has been changed recently. Same for the water pump, etc. I will have to double check the carfax from when I bought it, but I don't remember seeing anything about those parts being changed..
    There is also a vibration sound when I have the A/C on, that becomes way less pronounced when I turn off the A/C. The A/C blows cold and works fine, but there is a vibration noise that engages when I turn it on. Could be related? Serpentine belt?
    I am new to learning about the workings of my car, and have been learning how to fix things in order to save money, I have good abilities of tool usage, and feel confident I can learn most repairs.
    The truck drives GREAT, but I am just trying to get all the kinks worked out to make it last me a long time.. It has 166K on the odometer.
  4. Jul 11, 2020 at 5:04 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Good!
    Not good. Toyota reccomends replacement at 90K intervals for the water pump. The other goodies are changed out of precaution. You are already there, and if parts are on hand... may as well change them out also.
    This question is out of my league. I would imagine that it is belt related, but I dont have a V8. I am in the same boat as you. Learning my way around repairs.
  5. Jul 11, 2020 at 5:05 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    By the way, welcome to the forum.
  6. Jul 11, 2020 at 5:07 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Is it a "ring" like the title says or more of a squeal?
  7. Jul 11, 2020 at 6:20 AM
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    If it’s a high pitched noise, I’d bet it’s your air injection pump. You can either have that repaired for $2K or install the bypass (see link below) for around $200. If this, and you go the bypass route (most everyone does), soak the nuts for a few days before installing the plates. If one of the four nuts breaks off, you’re up a creek. There’s a detailed YouTube video of a guy and his dad doing the bypass and showing every step - it’s really easy.
    https://hewitt-tech.com/store/index.php?l=product_detail&p=94
    If it’s a squeal, I’d bet your serpentine belt, an idler, pulley or water pump. I’ve seen some people just replace the timing belt at 100K miles without doing the idler/pulleys or water pump - bad move. You can take off the serpentine belt and spin the pulleys to see if they’re bad (YouTube).
    artsr2002 and revtune like this.
  8. Jul 11, 2020 at 6:36 AM
    maseb42
    It is a high pitched noise like ears ringing. And then will stop after about 30 seconds, with a sound like a pressure releasing with a little hiss at the end.
    Thanks @Tundra2! This place is great!
    Thanks @Bulldog_tundra ! What does the bypass do? I'm thinking you are right about it being the air pump.
    Tundra2 likes this.
  9. Jul 11, 2020 at 9:38 AM
    I assume this is the SAI pump, based on other stuff I've read, a sound clip would really help. If you can shoot one on your phone, then go to www.imgur.com you can upload with sound and link it here for everyone to hear.
    Mine hasn't died yet. Isn't there also an inline filter you can throw on one of the lines to the pump to prolong and/or extend the life of the pump? I can't seem to find a write-up about it here.
  10. Jul 11, 2020 at 10:05 AM
    Bulldog_tundra
    USA
    2006 Double Cab
    Definitely sounds like the SAIP, here’s the link to the video I used:
    https://youtu.be/WDzNfW7Ti5g
  11. Jul 11, 2020 at 7:38 PM
    maseb42
    Yep! I just watched the video and that's the exact noise that mine makes! You nailed it! Thanks a ton!
  12. Apr 19, 2024 at 11:56 AM
    Squeakyduck4
    Squeakyduck4 New Member
    Santa Barbara
    06 DC 4x4 V8 TRD
    Does this sound indicate a problem or is it supposed to sound like that?
  13. Apr 19, 2024 at 1:26 PM
    Do you have any codes?
  14. Apr 19, 2024 at 1:30 PM
    Squeakyduck4
    Santa Barbara
    06 DC 4x4 V8 TRD
    I can plug in a scanner and find out later! No lights on dash..
  15. Apr 19, 2024 at 2:04 PM
    Squeakyduck4
    Santa Barbara
    06 DC 4x4 V8 TRD
    What toyota said "if its making noise that means its on the way out" and they quoted me 5400 to fix
  16. Apr 19, 2024 at 2:04 PM
    It'd be worth checking. If it sounds like a shop vac its hooked up to a turbo under your hood, it's the pump, and it may be on its way out.
    EDIT: Looks like we submitted our replies at the same second! So ... JINX!
  17. Apr 19, 2024 at 2:06 PM
    Squeakyduck4
    Santa Barbara
    06 DC 4x4 V8 TRD
    Ha! yea.... idk... might just trader her in...makes me sad but boy is she turning into a money pit
  18. Apr 19, 2024 at 2:08 PM
    Someone else will snatch it up and be, like, "Damn, only needed $1k in stuff, what a deal!!"
  19. Apr 19, 2024 at 2:10 PM
    Squeakyduck4
    Santa Barbara
    06 DC 4x4 V8 TRD
    dont forget im in ca so its more like 3k, ha!
  20. Apr 19, 2024 at 2:14 PM
    Squeakyduck4
    Santa Barbara
    06 DC 4x4 V8 TRD
  21. Apr 19, 2024 at 2:39 PM
    maseb42
    The SAI Bypass kit from Hewitt fixed my problem. Going on almost 4 years now.
  22. Apr 19, 2024 at 2:39 PM
    SAI pump is around $500 for the pump no matter how you slice it. Unless you buy it from the company that makes it, then it's half that price. Problem is, I forgot what company made it, someone mentioned it before, it sounded plausible, but then I couldn't find the post to verify it.
    May want to replace the starter with Denso cold weather starter while you're in there. You shouldn't need to peek under that intake for 15-20 years if you do.
    This forum is littered with people who continued to get codes after using the Hewitt kit and other kits as well. Some due to improper install (not installing blockoff platest seems to be a big one). Some because of ECU bug (cold start). Some we don't know why.
  23. Apr 19, 2024 at 2:39 PM
    Squeakyduck4
    Santa Barbara
    06 DC 4x4 V8 TRD
    wow. okay ill look into it.
  24. Apr 19, 2024 at 2:40 PM
    Squeakyduck4
    Santa Barbara
    06 DC 4x4 V8 TRD
    yea I saw on sparks parts 400-500. Will start researching.. might just do the bypass fix
  25. Apr 19, 2024 at 2:41 PM
    maseb42
    Squeakyduck4 likes this.
  26. Apr 19, 2024 at 2:42 PM
    Just be forewarned about the last sentence in my previous reply.
