Transmission Behavior
Discussion in '2.5 Gen Tundras (2014-2021)' started by ef_2016_tundra, Apr 17, 2024.
  1. Apr 17, 2024 at 7:44 AM
    ef_2016_tundra
    ef_2016_tundra [OP] New Member
    Eric
    2016 Tundra SR5 4x4 5.7
    Stock
    Hey all. I have the 2016 5.7 4WD. Love the truck in every way except for the transmission behavior.
    I like how it operates when it's not warmed up... basically lets you coast when you're not on the gas. But once it comes up to operating temperature, the transmission then drags when you let off the gas instead of freewheeling or coasting like it does when it's cold. I know part of the mapping doesn't lock up the torque converter until it gets to operating temp... but this drag happens in gears 2-4 as well when it's warm.
    Wondering if I could track down a tune to dial it in to my preference referencing the trans mapping when cold as a baseline and then just adding torque converter lockup in gears 5 and 6 as soon as it gets to op temp. Any insight would be greatly appreciated.
  2. Apr 17, 2024 at 7:53 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I would check ATF degradation counter. When TCM decides ATF is dud it changes shifting patterns to keep torque converter locked up as much as possible.
    Also valve body has an on/off solenoid for coast clutch, it may be stuck in yours. But in that case you would see a transmission error.
  3. Apr 17, 2024 at 8:43 AM
    Sciosh98
    Sciosh98 ¯\_(ツ)_/¯
    Stephen
    Tennessee
    2020 Black Tundra 1794 TRD
    I think someone on the forum (maybe) said that ~50k degradation score was fully trashed. Is that accurate?
  4. Apr 17, 2024 at 9:16 AM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
    Do a drain and fill. See what the oil looks like.
  5. Apr 17, 2024 at 9:22 AM
    Sciosh98
    Sciosh98 ¯\_(ツ)_/¯
    Stephen
    Tennessee
    My degradation score is only 2750 and my fluid looked black as night. 38k miles, no towing. Hard to gauge from look alone.
  6. Apr 17, 2024 at 9:49 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I trust color over oxidation counter any day. A properly working transmission, with proper ATF cooling, almost never turns ATF brown or even black. I still keep d&f them regularly.
  7. Apr 17, 2024 at 9:51 AM
    Sciosh98
    Sciosh98 ¯\_(ツ)_/¯
    Stephen
    Tennessee
    Yeah, I think I’ll do a drain and fill at 40k miles after seeing how dark mine looked during the cooler install.
  8. Apr 17, 2024 at 10:01 AM
    WS turns dark fast. Or maybe Toyota transmissions turn the fluid dark fast.
  9. Apr 17, 2024 at 10:03 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Check fluids, then get a tune this will make a significant difference. Paging @JustDSM from OTT.
    JustDSM likes this.
  10. Apr 19, 2024 at 9:14 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Maintenance first before trying to tune the trans.
    If you have never done it, or have not done it it past 40-50k miles, trans drain and fill is in order. Do the diffs and xfer case while you are at it and lube your driveline zerks.
