Antenna base mount/bezel whatever you call it
Discussion in '1st Gen Tundras (2000-2006)' started by 2000TundraKid, Apr 19, 2024.
  1. Apr 19, 2024 at 7:40 AM
    2000TundraKid
    2000TundraKid [OP] New Member
    2000 AC SR5 4.7 V8 2WD
    Grill Guard and 16" 398 Vision Manx Competition
    Has anyone run into a problem with the base mount for the antenna? Mines plastic is cracked and the base doesn't hardly hold the antenna stable anymore, think it's missing the nut that's supposed to screw it down to hold it and the internal piece is really loose and has a lot of play without it. Cannot find the part anywhere all I get is loads of 07s and parts for 97 tacomas as well as 4 runners. Thanks
  2. Apr 19, 2024 at 7:54 AM
    Part is discontinued. Gonna need to hit a junkyard for it.
    2000TundraKid[OP] likes this.
  3. Apr 19, 2024 at 7:58 AM
    2000TundraKid
    Bummer. Thank you
  4. Apr 19, 2024 at 8:02 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Be careful at the JY as the one you take off will be just a brittle. Mine fell apart in my hand just turning the chrome ring.
  5. Apr 19, 2024 at 8:09 AM
    CCE525
    CCE525 New Member
    Chad
    2000 SR5
    None
    We need the instagram 3D printed tailgate bushing guy to print some of these …I need one too and am 0/5 at bone yards.
  6. Apr 19, 2024 at 8:20 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    That's a fantastic idea!
    I replaced mine with an RV marine antenna mounted to my front brush guard
  7. Apr 19, 2024 at 8:24 AM
    2000TundraKid
    I kinda wanna poke around on scamazon to find something that may pop in lol. The one and probably only thing I bought off Amazon for parts was windshield spray nozzles and I got some for a FJ Cruiser that this YouTube video recommended and they're much better imo than the dual streamers that were on there previously since I wanted ones that cover the whole window. Only thing that seemed off to me was 28 bucks and they come separate but what the hellScreenshot_20240419_081821_Amazon Shopping.jpg
  8. Apr 19, 2024 at 8:26 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    They work. I have one FJ on the left side and one Tundra on the right. I believe @shifty` said it's the same part number that's on his 06. Toyota changed the design sometime back and that's why the part shows no compatible with your 2000. Trust me, it fits and works just fine.
  9. Apr 19, 2024 at 8:27 AM
    2000TundraKid
    Oh yeah they fit cause they're installed already haha love them
  10. Apr 19, 2024 at 8:28 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Ah, sorry. I misread that
  11. Apr 19, 2024 at 8:29 AM
    2000TundraKid
    You're good :cheers:
  12. Apr 19, 2024 at 9:59 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  13. Apr 19, 2024 at 10:34 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  14. Apr 19, 2024 at 12:54 PM
    w666
    Maryland
  15. Apr 19, 2024 at 1:31 PM
    Yeah, I might've misspoken, I think it's the top nut/ring things. @daveeasa mentioned it's NLA. I was thinking the "jewelry" (black part) was unavailable.
  16. Apr 19, 2024 at 4:42 PM
    daveeasa
    I have an entire unit to replace someday.
    I did buy a replacement nut somewhere but then killed it trying to dechrome with bleach so that was a foolish experiment.
    shifty` likes this.
  17. Apr 19, 2024 at 5:03 PM
    w666
    Maryland
  18. Apr 19, 2024 at 5:53 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  19. Apr 19, 2024 at 6:09 PM
    I want to retrofit the sequoia frenched/power antenna into my AC. But I haven't been able to find one.
    I hate that mine hits everything driving into parking decks etc. Granted, it's a good warning.
  20. Apr 20, 2024 at 2:27 PM
    Solid Snake
    Solid Snake The Anciet of Mu Mu
    West TN
    2006 AC 4x4 V8
    I wouldn't mind just removing the antenna completely and plugging the hole. Or finding a way to mount a CB antenna there.
  21. Apr 20, 2024 at 2:40 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Snorkel to cover the hole and mount a marine RV AM/FM antenna to the front brush guard :D
  22. Apr 21, 2024 at 6:30 AM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Drilling big holes in good metal, I be like
  23. Apr 23, 2024 at 6:16 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    I actually just bought that same part from Ourisman and it did include the black plastic mount and the chrome ring.
    Weagle likes this.
  24. Apr 23, 2024 at 6:22 AM
    kentuckyMarksman
    @2000TundraKid, I would honestly just buy a new antenna base assembly from Ourisman and do that since yours looks pretty rusty. I just had to do that on my truck because there was a break in my radio line. The black plastic piece and chrome nut came with my new antenna base.
    That being said, I have a used black plastic piece and chrome nut if you interested, just send me a PM if you want to go that route.
    You'll also want to buy some fender well clips and some other clips (for your fender flares) if you replace your antenna base. It's accessible from inside the passenger side fender, and you'll run the wire to the back of your radio.
    2000TundraKid[OP] and Weagle like this.
  25. May 10, 2024 at 12:52 PM
    2000TundraKid
    Yeah I could do that, I have a Bluetooth connector to my stereo since I still got the og tape deck and with higher volumes it develops some static. Gotta go with a little restoration. I just replaced one of my AC knobs cause the clip to hold it on was broke lol
