  1. Apr 17, 2024 at 8:52 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    This is a little deceiving as the nose is a bit downhill, but not bad squat for an 1100 pound load- 20 bags of ready mix. Sumo springs
    BroHon, oscardog86, NUDRAT and 6 others like this.
  2. Apr 18, 2024 at 6:26 AM
    importxpresions
    importxpresions New Member
    2001 SR5 AC Imp Jade Mica 2WD
    Replaced the PCV valve, pcv valve hose, and clips. PCV valve still moved (shook) pretty well but figured due to age it wouldn't be bad to change out the hose, clips, valve, and grommet. Had slight oil in the hose and the PCV valve wasn't dirty at 104k miles. Wasn't bad, only took about 10 minutes.
  3. Apr 18, 2024 at 7:19 AM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    Do you have the hose part number handy? Mine is cracking and may be the cause of a slight oil leak in the area.
    importxpresions likes this.
  4. Apr 18, 2024 at 7:25 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    Your 2005 PCV (screw in) will be slightly different than his 2001 (press in). The hose is also a slightly different size and connects to a different location; Intake for the 2005 and Throttle Body for the 2001.
    455h0le_dachshund likes this.
  5. Apr 18, 2024 at 7:32 AM
    87warrior
    Kansas
    2004 DC 2uz 4x4
    My oil pressure sensor had been on the fritz for awhile... then it totally stopped working.
    Seeing no oil pressure was concerning, so I ordered up a new Toyota sensor from PartSouq/Dubai and installed it.
    Now, that is what I expect to see from a warmed up 2UZ :thumbsup:
  6. Apr 18, 2024 at 7:56 AM
    Bed Tundy
    Neature Gary
    Moscow, ID
    I knew mine was screw in, I just pulled the hose yesterday to inspect pcv and thought that it connected about the same place, but I didn’t think about diameter, thanks.
    87warrior[QUOTED] likes this.
  7. Apr 18, 2024 at 10:36 AM
    Bed Tundy
    Neature Gary
    Moscow, ID
    That’s a nice clean engine, clean aluminium looks much better than my plastic. I have oil caked on that drivers PVC side, thought it might be from the valve, but on closer inspection maybe I have a valve cover leak? Going to clean it and wait.
    Does anyone else get bothered by the black oil residue behind the butterfly? Everything is kept so clean after the air filter and then once inside the manifold we just dump unburned oil Vapor’s that coats everything in a sticky black film.
  8. Apr 18, 2024 at 10:45 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I pulled my throttle body and carefully cleaned it off the truck, then reached inside and wiped what I could on the manifold.
  9. Apr 18, 2024 at 11:39 AM
    I think I'm gonna Seafoam mine soon. I've got a can of the spray. I'm desperate to get some MPG out of this truck.
    BroHon and Bed Tundy like this.
  10. Apr 18, 2024 at 11:42 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Change the fuel filter :burp:
  11. Apr 18, 2024 at 12:03 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Dad laid a nugget on me once. Block the rad, drive around with as much load as possible, get the heads & pistons hot hot, then spray the seafoam or berrymans or chemtool. And have the stuff chilled. When it starts to choke bring the engine up past peak tq & let it ride for a min or so. Makes sense, done it to a few vehicles. Prolly do it on the truck eventually. After my next trip to houston i'll see how much damage a freshly oiled k&n has done over the last 10k.
    shifty`[QUOTED] likes this.
  12. Apr 18, 2024 at 12:17 PM
    IMG_0453.jpg IMG_0452.jpg I’m Dirty. :anonymous:
    Voss, bmf4069, Mr.bee and 1 other person like this.
  13. Apr 18, 2024 at 12:43 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  14. Apr 18, 2024 at 12:55 PM
    No fuel filter on '05-'06 :(
  15. Apr 18, 2024 at 1:56 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Nope. Only the in-tank filter.
    My coworker traded his 04 DC for an 08 DC because of the terrible gas mileage on the 04. He says he is getting about 17.6 on the 08.
  16. Apr 18, 2024 at 2:02 PM
    I get about 15.6mpg in my 00.
    I get about 15.6mpg in my 19
  17. Apr 18, 2024 at 2:22 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    That's the problem. It needs one then haha
  18. Apr 18, 2024 at 2:32 PM
    Nah, it's just one more way the VVTi is superior to the earlier models. Don't need no stinking fuel filter, we go uncut.
    abcinv, bmf4069 and VR6T like this.
  19. Apr 18, 2024 at 2:37 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    I bet you like em uncut lmfao, fuel lines I mean, of course lol
  20. Apr 18, 2024 at 2:40 PM
    VR6T
    You know if you bump it up to 11.0:1 CR, you too could see 17.8 mpgs. Make those forged internals and toss 10 to 12 psi at it and super cruise highway at like almost 20 I bet. Not to mention wootootoo Chinese spinny boi noise
  21. Apr 18, 2024 at 2:53 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    So maybe it's because I'm a little 'tarded, but the PHM seatbelt post reads like he sprayed the seatbelt webbing itself with silicone spray? If so that gives me the heebie jeebies.
    I spend a lot of time trusting softgoods with my life while climbing and in that world gear is retired if you have any doubt about its strength of usable life. Even a 10% bleach disinfectant solution has been shown to reduce the minimum breaking strength of nylon webbing by 50% or more. Just some food for thought.
    I need to do some seatbelt maintenance and will be following the @shifty` gospel of targeted lubrication to the lower mech's and upper slider.
    oscardog86, shifty` and bmf4069 like this.
  22. Apr 18, 2024 at 2:56 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I hosed mine down with silicone spray 4 years ago and it's still smooth and I haven't died yet...
  23. Apr 18, 2024 at 3:22 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    same. Walmart silicone spray fixed my buddies focus, but we stroked the pull to help. The next day, they were good as new. No residue.
    VR6T likes this.
  24. Apr 18, 2024 at 3:25 PM
    I highly doubt silicone spray is going to deteriorate nylon/polyester seatbelt webbing. Best fix is to just buy a new belt and install it unless you need special tools to work with those pre-charged belt retractors and not have it go off in your face.
  25. Apr 18, 2024 at 3:34 PM
    Silicone spray is the way
  26. Apr 18, 2024 at 3:36 PM
    I just drove from Knox to Chattanooga and back and got 16.7. Not bad considering I'm on 33's with probably 400lbs of armor and a camper shell.
  27. Apr 18, 2024 at 3:36 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    Personally I'd go with folex and a pressure washer. Don't know why you'd spray silicon lubricant onto fabric.
    JakeJake likes this.
  28. Apr 18, 2024 at 3:43 PM
    JakeJake
    2000 Tundra AC 4X4
    You boys are wild.
  29. Apr 18, 2024 at 3:51 PM
    I think it’s interesting you can’t buy the seat belt for the driver’s seat on my year truck but you can buy all the others ones (passenger & rear seat belts). Look it up.
  30. Apr 18, 2024 at 4:02 PM
    JakeJake
    2000 Tundra AC 4X4
    Gotta be a stock thing. A significant collision warrants a belt replacement and the added wear and tear of being the always occupied seat.
    I have a set of front belts in tan (not positive on the color without looking) from an 02 if you need one. I'll make you a tundra forums sweetheart deal.
    I cant guarantee it hasn't been hosed down with questionable chemicals though.
