3rd Gen Max Highway Driving Range - Hybrid vs. Non Hybrid?
Discussion in '3rd Gen Tundras (2022+)' started by winchester44, Apr 6, 2024.
  1. Apr 16, 2024 at 6:27 PM
    #91
    Hella Krusty
    Hella Krusty New Member
    you can set the dash cluster to calculate per trip ( Every time it starts ). Leave the navigation to do an " over all". no way in hell that truck is worse than the 5.7......I have owned both
    Once over 65 the hybrid is pretty much non existant.
    Mattedfred and MTRock like this.
  2. Apr 17, 2024 at 5:43 AM
    #92
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    This isn’t complicated. There’s a reason Toyota never advertised fuel saving advantages with the iForce Max. It turns out driving a 6400+ lb Lego brick isn’t efficient.
    Only when you intentionally take advantage of the hybrid drive in stop and go traffic does it help make up the fuel economy hit of lugging around the static extra 500 lb at highway speeds when the hybrid is not working.
  3. Apr 17, 2024 at 7:55 PM
    #93
    winchester44
    winchester44 [OP] New Member
    2016 1794 4WD
    So to wrap this up do we concur the hybrid will deliver significantly less highway range vs. the non- hybrid when driven at 75-80 mph highway speeds?
  4. Apr 17, 2024 at 8:21 PM
    #94
    Hella Krusty
    If that makes you sleep better at night......fill your boots. Nothing like making a conclusion off an internet forum LOL.
    You want facts line 2 identical trucks up, one with a hybrid and go on a roady. Not that tough.
    My money is on the Hybrid
    MTRock and b6graham like this.
  5. Apr 17, 2024 at 8:23 PM
    #95
    Breathing Borla
    Northern Illinois
    Who gives a shit , you have to piss before either uses up the whole tank anyways
    wxman91, kirkb, Mattedfred and 4 others like this.
  6. Apr 17, 2024 at 8:24 PM
    #96
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    Our highways in CO aren't that fast but with the hills/mountains I'd bet on the hybrid significantly out ranging a non hybrid based on the mpg I see on mine and the lexus hybrid we have
    MTRock likes this.
  7. Apr 18, 2024 at 4:59 AM
    #97
    winchester44
    2016 1794 4WD
    People who live and works in rural areas where gas stations can be few and far between.
  8. Apr 18, 2024 at 5:02 AM
    #98
    winchester44
    2016 1794 4WD
    That makes perfect sense, have driven a lot up there. Sorry I should’ve qualified that this would flat highway driving.
  9. Apr 18, 2024 at 5:06 AM
    #99
    winchester44
    2016 1794 4WD
    Exactly what I find fascinating as you have people that seem very convinced one way or the other and a few they feel the difference will actually be very marginal. There seems to be little you can glean from the EPA numbers after reading how they were gathered that is not really representative of a long road trip but more of a trip across the city with a highway component.
    I think the most interesting thing I’ve learned is the hybrid owners seem to think the hybrid motor does not contribute above constant speed 65 miles an hour. Seems to indicate it’s just quite a bit of extra weight on an extended highway trip.
    However, some think almost 10% extra weight will not make much of any difference at continuous speed, and hybrid offsets it accelerating to the speed. That might be true. I think one of the guys on here is a railroad engineer and I bet he understands the physics pretty well I believe modern locomotives are essentially hybrids.
    Of course, would love to see a test to find out for certain who is right.
    If Tundra was offered with a diesel. I can 1000% assure you this question would be tested and fully answered by now.
  10. Apr 18, 2024 at 5:06 AM
    #100
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    This is even more critical when towing because not all gas stations are large enough to conveniently accommodate trailers.
    That's why, for the F150, the non-hybrid is preferable to the hybrid powertrain when towing longer distances. The non-hybrid can be configured with a 36 gallon fuel tank and the hybrid only has a 30-32 gallon fuel tank while weighing a bit more. Although the weight factor isn't as significant as the additional fuel tank capacity when it come to constant speed driving/towing.
  11. Apr 18, 2024 at 6:09 AM
    #101
    Breathing Borla
    Northern Illinois
    sorry not buying that, range is still massive with either vehicle, there is nowhere in the USA where stations are more than 300 miles apart, and the range is way more than that
  12. Apr 18, 2024 at 6:11 AM
    #102
    Breathing Borla
    Northern Illinois
    you guys are overblowing this, there is plenty of range in either truck and there isnt much different between them, just get what you like and be done with this endless debate over 1-2 MPG
    MTRock likes this.
  13. Apr 18, 2024 at 6:26 AM
    #103
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    This is ridiculous. The mpg is slightly worse on the hybrid sure, but even if you got one less mpg over the non hybrid, you could go 30 miles less. No way you are driving 500+ miles between gas stations, no one is driving that distance without stopping and there is nowhere in the US with a gas station that far from the last one. Buy whatever truck you want and stop over thinking it. It is known that the tundra is not built for fuel efficiency and the hybrid was never designed for that. I can’t believe this thread has gone on for 4 pages and you still trying to determine which one is better. Facts remain that the hybrid system could be less efficient at highway speeds but only by small margin. But no one is getting what is even advertised because no one is driving 65-70 to make it to their destination on highways that people are driving 80 on.
    Breathing Borla likes this.
  14. Apr 18, 2024 at 7:33 AM
    #104
    Polo08816
    2014 BMW 335i
    https://www.biography.com/musicians/lisa-nowak-lucy-in-the-sky
  15. Apr 18, 2024 at 7:50 AM
    #105
    Polo08816
    2014 BMW 335i
    ... that's what I said. The difference in range will be negligible because the fuel consumption at constant highway speeds is more about overcoming aero drag for vehicles of similar weight. If the fuel tank capacities between the non iForce Max and iForce powertrains are the same, the range should be similar for constant highway speed driving. This isn't the case on the F150.
  16. Apr 18, 2024 at 7:57 AM
    #106
    SM Tundra
    Cody
    I remember that story hahaha, but doubt OP is willing to wear diapers to go the further distance possible. Wonder what she was driving, don’t think she made all 900 miles on one tank, so she had to stop at some point. Plus the non hybrid is not going 900 miles on a tank, we are talking 30-60 mile difference max between the two with averaging 1-2 mpg better if that is what you are getting difference between the two.
  17. Apr 18, 2024 at 9:23 AM
    #107
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    No.
    Tundrastruck91 likes this.
  18. Apr 18, 2024 at 9:47 AM
    #108
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    I usually show 620 to 635 miles to empty after filling up. Computer shows 22.9mpg last reset 4k miles ago. Sr5 4wd stock.
    Mattedfred likes this.
  19. Apr 19, 2024 at 5:35 AM
    #109
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    I agree that we can't know the conditions driven under or towing but that can go both ways. Here is what fuelly is reporting from owners.
    Hybrid...
    Non hybrid
  20. Apr 29, 2024 at 11:44 AM
    #110
    Starman2112
    Starman2112 New Member
    I5 so mostly flat. But We used to get 11 MPG over 100K miles in our old 2010 Sequia Platinum so 16.4 aint that bad to me.
    Colotundie likes this.
  21. May 11, 2024 at 5:24 PM
    #111
    rideandfly
    rideandfly New Member
    Our 2022 2WD SR5 Crewmax non hybrid passed 29,000 miles today on a round trip from Charlotte NC to Richmond VA and back for total of 622 miles using 25.2 gallons. This was the best trip MPG so far @ 24.6MPG. Drove 4 lane and interstates for 99% of the trip up to posted speed limits using cruise control. This Tundra has original 18" Yokohama Geolandar street tires @ 40PSI. When I filled up the gas gauge was at 1/8 tank with over 6 gallons left in the 32 gallon tank. This truck has been trouble free since buying new 12/31/2021.
  22. May 11, 2024 at 10:25 PM
    #112
    Fxclm5
    Fxclm5 New Member
    2wd, fml I shoulda just got that, out of all my last trucks only used 4wd like never lol
  23. May 12, 2024 at 5:35 AM
    #113
    rideandfly
    Our 2003 Tacoma is a 2WD, too. Getting ready to pass 210,000 miles with that one, bought it for less than $12,000 new.
