Engine light just came on!
Discussion in '3rd Gen Tundras (2022+)' started by Jriedy85, Apr 7, 2024.
  1. Apr 7, 2024 at 5:53 AM
    Jriedy85
    Jriedy85 [OP] New Member
    Josh
    2022 SR5 Tundra
    Was driving to my property this morning and I got about 10 minutes down the road and the check engine light came on. The error in the infotainment system said “a malfunction in the electronic control of the engine, throttle, or automatic transmission has been detected.” I’ve got 16,800 miles. Praying it’s nothing serious.
    Jettster likes this.
  2. Apr 7, 2024 at 6:07 AM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    hope not serious but you should be still under 3/36 warranty
  3. Apr 7, 2024 at 7:18 AM
    Brian89
    Brian89 New Member
    Just had this happen with only 2k miles and it was a bad A/F sensor. The code the dealer pulled from the OBD2 was P219519 A/F sensor signal stuck lean bank 1 sensor 1 short circuit in sensor b1s1. They replaced the sensor
    Tundrastruck91 likes this.
  4. Apr 10, 2024 at 9:43 AM
    Jriedy85
    Josh
    2022 SR5 Tundra
    Welp… I got an update today from the dealer. I’ve got a bad turbo. Anyone know what kind of mess I’m in for? How long the repair takes? Things to watch out for?
  5. Apr 10, 2024 at 9:47 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    Sorry to hear about that. Hopefully they take good care of you.
    Jriedy85[OP] and ryanwgregg like this.
  6. Apr 10, 2024 at 5:09 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Is it the turbo or something on the turbo?
    I know on a Toyota forklift 3 cyl diesel or 4 cyl the turbo is all one, meaning any sensor on the turbo is not replaceable only the whole unit can be replaced.
    Customers are still running 15w40 yet the operators manual calls for 10w30 nothing heavier......outcome is always $5,000 for a turbo assembly with low hours.
    Vain controller or seals blown pumping oil into the intake and exhaust system.
  7. Apr 10, 2024 at 5:16 PM
    Jaxyaks
    Jaxyaks New Member
    255,829 as of 24 Q1 reporting but close enough I reckon...
  8. Apr 10, 2024 at 5:20 PM
    Jriedy85
    Josh
    2022 SR5 Tundra
    I think he said turbo sub assembly. I don’t know much about turbos so I have no idea what that is. But he said it’s around $6000 in parts and 13 hours of labor.
    pwpblue[QUOTED] likes this.
  9. Apr 10, 2024 at 5:24 PM
    Hella Krusty
    Hella Krusty New Member
    What did the dealer say other than your turbo is Fubared. ??
  10. Apr 10, 2024 at 5:26 PM
    Jaxyaks
    Jaxyaks New Member
    Thats probably both of em and if I remember correctly most of them pull the cab to replace it.
    AZBoatHauler likes this.
  11. Apr 10, 2024 at 5:34 PM
    Jriedy85
    Josh
    2022 SR5 Tundra
    That sounds pleasant.
  12. Apr 10, 2024 at 5:37 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Über bad idea on a diesel.
    Mattedfred likes this.
  13. Apr 10, 2024 at 5:42 PM
    Breathing Borla
    AZ
    they do that through the wheel well
  14. Apr 10, 2024 at 5:45 PM
    Jaxyaks
    Jaxyaks New Member
    Thats good, I though I saw a bunch of cabs off trucks not long after the 22 release when a bunch of them had waste gate issue. I could be confused with another issue. But its good if they don't have to do that.
  15. Apr 10, 2024 at 5:54 PM
    13 hours for a turbo swap...damn. Your dealer should be called milkmen.
  16. Apr 17, 2024 at 6:03 AM
    Jriedy85
    Josh
    2022 SR5 Tundra
    Got my truck back yesterday. they started working on it on Saturday and finished Monday. Definitely going to be buying the factory extended warranty.
  17. Apr 17, 2024 at 5:12 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Not the case now. My friend is a Toyota mechanic 30 years now and they figured out a way to swap the turbos out without removing the cab. You’re right they used to remove the cabs initially. The gas line can also be fixed without dropping the tank completely. Good thing that Toyota mechanics talk.
  18. Nov 22, 2024 at 8:33 AM
    Jriedy85
    Josh
    2022 SR5 Tundra
    Well.....we are back. Got the same error on my truck two nights ago. What are the odds the other turbo has now failed?
  19. Nov 22, 2024 at 9:39 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    50%?
    PBNB, Raven67 and WingedHussar like this.
  20. Nov 22, 2024 at 9:42 AM
    Jriedy85
    Josh
    2022 SR5 Tundra
    LOL! true.
    75tranzam likes this.
