NON-Flex Fuel Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraTyrant, Apr 17, 2024.
  1. Apr 17, 2024 at 4:03 AM
    TundraTyrant
    TundraTyrant [OP] New Member
    Nate
    2015 White Tundra
    35's w/ snugtop
    I'm in the market for a Transfer Flow 46 gallon fuel tank, but I've encountered a new policy issue. Transfer Flow has started requiring a photo of the emissions sticker under the hood before they will sell a tank, specifically to avoid sales to Tundra trucks that are Flex Fuel. This is because using E85 fuel in the tank can corrode the internal components over time.
    The problem is, my Tundra is a Flex Fuel model. However, I’ve never used E85 nor do I plan to. Transfer Flow themselves have stated that their tanks are compatible with Flex Fuel trucks, provided that E85 isn't used.
    Fortunately, the emissions sticker under the hood doesn’t link to your VIN number. Would anyone be willing to help me out by sharing a photo of their non flex fuel emissions sticker? This would help me circumvent what I believe is an unnecessary restriction from Transfer Flow. Thank you!
  2. Apr 17, 2024 at 4:56 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    It would be pretty inexpensive for Transfer Flow to use compatible internal hoses and parts. That's not a wise move on their part.
  3. Apr 17, 2024 at 4:57 AM
    TundraTyrant
    Nate
    2015 White Tundra
    35's w/ snugtop
    Agreed!! Idiotic imo. Bad business.
  4. Apr 17, 2024 at 5:00 AM
    Shamrock92
    Shamrock92 New Member
    The sticker is like $1 - why not just buy one worst case ?
    Part # 1129838223 (11298-38223)
  5. Apr 17, 2024 at 5:02 AM
    TundraTyrant
    Nate
    2015 White Tundra
    35's w/ snugtop
    I had not thought of that, thank you for that. I could do that, or someone could just post of photo on this thread and help other folks in the future...
  6. Apr 17, 2024 at 5:02 AM
    Florida AF
    Logan
    North Florida
    This is a strange thing on their part! I would help you out, but I am also running flex fuel. Good luck and let us know how you circumvent it and how the process goes please.
    TundraTyrant[OP] likes this.
  7. Apr 17, 2024 at 5:02 AM
    Florida AF
    Logan
    North Florida
    I didnt even know this was an issue.... nice recommendation!
  8. Apr 17, 2024 at 5:04 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Did you google this? I found both by simply searching "Toyota Tundra Emissions Sticker"
  9. Apr 17, 2024 at 5:11 AM
    TundraTyrant
    Nate
    2015 White Tundra
    35's w/ snugtop
    I did Goog it, but not good enough I guess... I did find this, which I believe will work since it says gasoline only. my truck says gasoline/ethenol.
  10. Apr 17, 2024 at 5:33 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I don't see why that wouldn't work. I found a bunch of them when I searched. Good luck! The larger tank will but really nice to have.
  11. Apr 17, 2024 at 11:59 AM
    bonefish
    bonefish New Member
    Peter
    Treasure Coast Florida
  12. Apr 17, 2024 at 3:05 PM
    TundraTyrant
    Nate
    2015 White Tundra
    35's w/ snugtop
    You are a god amongst men. Thank you sir.
