General Supercharger Thread
  1. Apr 15, 2024 at 7:13 PM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    Yes, we did that on one of my customer’s trucks. He installed a 5.7 FFV engine into his solid axle swapped 4Runner and then converted to regular ECU. Needed to do a few extra bits and pieces, but pretty straightforward.
  2. Apr 15, 2024 at 7:28 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Do I need a specific ECU? Can you point me to the process please?
    Fastlane47, helidave and Mdl like this.
  3. Apr 15, 2024 at 8:40 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Any more info you have about the swap would be much appreciated
    e30cabrio[QUOTED] likes this.
  4. Apr 15, 2024 at 8:51 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Yes sir, no issues and pretty good right out the gate!
  5. Apr 16, 2024 at 1:38 PM
    ViktorG
    Viktor
    Calgary, Canada
    We did this 3-4 years ago, so I don't remember every detail.
    The ECU I believe we just got from the same year non-FFV truck with the same options (4wd, tow/haul).
    I don't think the ECU part number is critical.
    We replaced the fuel rail FPR with a non-FFV one.
    Lastly, the FFV ECU controls the C/OPN and Fuel pump relays to turn on the fuel pump, which is different than the non-FFV ECU, but that is the only difference (photo attached).
    We just rewired to fuel pump to come on independent of the ECU.
    You will also need to program the keys to your new ECU.
    Also, you can get rid of the fuel pressure switching valve and hoses above the tank, but it is not mandatory.
    I don't think there was anything else involved.
    I am sure @snivilous can figure it our for you guys :)
    Here is the truck we did it on:
    https://www.youtube.com/watch?v=eCp3_0qc4Ew
    https://www.youtube.com/watch?v=kJVtswxekO4
    Cheers!
    HulkSmurf14, jhrrld, reywcms and 6 others like this.
  6. Apr 16, 2024 at 1:47 PM
    e30cabrio
    Thanks, I already have all the mechanical FFV things deleted, I have direct power to the pump, the relay jumped per firemandan & an aftermarket fpr running over 50lbs
    Mdl and ViktorG like this.
  7. Apr 16, 2024 at 1:55 PM
    ViktorG
    Viktor
    Calgary, Canada
    In that case, I believe all you need to do is get a non FFV ECU from a wrecked truck with the same year/options as yours, plug it in and tune away (will need new HPTuners credits because the ECU calibration will be different).
  8. Apr 16, 2024 at 2:06 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    ^^^ Awesome!! Some folks are going to be happy. Hope that Tuning deal works out for y’all,,,, All the best!!:)
    ViktorG likes this.
  9. Apr 16, 2024 at 2:35 PM
    e30cabrio
    I knew there was a catch! That's not cheap! GRRRRRRR
    :D
    Thanks, you truly are the man!
    ViktorG[QUOTED] likes this.
  10. Apr 16, 2024 at 2:40 PM
    helidave
    flagstaff
    2015 DC 4x4
    That doesnt sound too difficult.
  11. Apr 16, 2024 at 2:41 PM
    helidave
    flagstaff
    2015 DC 4x4
    $2-300 used. Probably less if you hunt around
    ViktorG likes this.
  12. Apr 16, 2024 at 3:53 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Plus the HPT credits to retune the new ecu...stuff adds up. :)
    ARES35 likes this.
  13. Apr 16, 2024 at 4:22 PM
    e30cabrio
    I sent HPT a message asking if I can send them the old ecu & not pay again. Not holding my breath.
  14. Apr 16, 2024 at 4:23 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    Good luck
    Mdl likes this.
  15. Apr 16, 2024 at 4:40 PM
    ViktorG
    Viktor
    Calgary, Canada
    One more thing I forgot to mention, you will need to program your keys to the new ECU.
  16. Apr 16, 2024 at 4:53 PM
    e30cabrio
    Cover me, I'm going in!
    PN says 11-14 non flex 2/4wd tow package Tree! WOOT! :p 127 with a warranty so if I brick it or it doesn't work I can get the $ back lol
  17. Apr 16, 2024 at 4:55 PM
    e30cabrio
    Guys that have swapped an ECU, what is the key learn deal? Can TechStream as we have it do it?
  18. Apr 16, 2024 at 4:56 PM
    JustDSM
    JustDSM New Member
    Justin
    If you guys need HPT credits, let me know we can help out a bit on credit costs.
  19. Apr 16, 2024 at 4:56 PM
    Fastlane47
    Maryland
    2018 Platinum
    Yes, well mine was odd. Mine started at install, I didn't have to do anything, got it from eBay.
  20. Apr 16, 2024 at 5:03 PM
    e30cabrio
    I might need 4, I'll see what HPT says tomorrow.
    JustDSM[QUOTED] likes this.
  21. Apr 16, 2024 at 5:04 PM
    e30cabrio
    Maybe I'll get lucky, doubtful. lol
    Fastlane47[QUOTED] likes this.
  22. Apr 16, 2024 at 5:06 PM
    Fastlane47
    Maryland
    2018 Platinum
    I hope so sir.
  23. Apr 16, 2024 at 5:51 PM
    helidave
    flagstaff
    2015 DC 4x4
    My service manual says it auto-programs the key to the ecu when you try and start the truck. Not sure if yours is the same
  24. Apr 16, 2024 at 5:52 PM
    Fastlane47
    Maryland
    2018 Platinum
  25. Apr 16, 2024 at 7:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Hitting 18.5psi. Nice! Are you at 6800 in 4th? Couldn't see if it was let off before 6800. If not will it hit 19psi at 6800?
  26. Apr 16, 2024 at 7:32 PM
    Black@Blue19
    Ken
    SE Texas
  27. Apr 16, 2024 at 7:38 PM
    lx570dude
    lx570dude New Member
    '14 LX570
    Harrop SC Kit Icon Vector 5 17" wheels Kenda Klever 'Skinny' 35x10.5 tires IPT Performance valve body
    Hello! I joined up to ask some basic 5.7 SC questions. I have a 14 LX570 with 120k on the odo. Excellent shape mechanically. I installed a Harrop Kit not long ago. I chose it for it's design and my goals which aren't hardcore. I don't plan to do headers or intake (the build is overland/towing focused) etc.
    I know the kit is advertised by Harrop as not needing tuning. Coming from a background of modified cars and tuning, that was obviously something I was highly skeptical of. Reading about the kit, speaking to other owners and shops like Prospeed in Houston, I was less uneasy about it. Truth is that it seems to "just work". Again, stock engine. I've never heard audible pinging, never had power loss, no codes have ever been set. However, all that being said I would like to maybe get a more dialed in tune.
    In speaking to Prospeed, they told me that I should leave it as is if I have no plans to mod any further. When asked about just refining the tune, they said that tweaking it in any way would require injectors because the factory ones, even with the upgraded harrop fuel pressure regulator valve and the upgraded Deatchwerks fuel pump, are completely maxed out as is. But then they also said that the fuel rails would need to be upgraded and that I shouldn't stick with the Deatchwerks pump and that I should upgrade to the walbro 400 they sell but that one isn't a drop in so the fuel pump unit would need to be modified and new AN lines and fittings added to run to the new rails.....and all of this extra stuff that I don't think is really necessary from what ive read in this thread...?
    The point of all that background info is to ask: can I upgrade the injectors to the Deatchwerks drop in kit I've seen recommended in this thread several times, while keeping the otherwise factory fuel system, upgraded pump, in order to just get a decent 'fine tune' via HPT or VFTuner? Again, no crazy HP goal that stray too far away from what the kit is supposed to make. I just want a proper tune and maybe a small bump in power. From what I gather from all the reading I've done, the factory bottom end can handle 550 at the wheels safely but you shouldn't go above that if you want it to remain semi-reliable.
    On the tuning side I've heard that HPT can flash a 570 but you have to trick it into thinking it's a tundra? Not sure how they do it, maybe using a tundra VIN? Is VFTuner a good option? Are there decent tuners that can remote tune via VF?
    Just trying to get a real world answer on if I can just toss injectors in and get it tuned or if I really need the thousands in supporting upgrades prospeed told me I'd need. Thanks for your time and any replies!
    reywcms and AZTundra like this.
  28. Apr 16, 2024 at 8:42 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Pro Speed tries to upsell on their equipment. The stock fuel rails are fine, lots of us are still running them. You could drop in some trd green 535cc injectors or go with DW 650cc to have more head room, which is what I would do.
    The Lexus has a 992k ecu so I believe hpt will read it and a tune could be written.
    You should reach out to ott or vftuning to see what options for tuning.
    Good luck and I'm sure others will chime in.
  29. Apr 17, 2024 at 1:33 AM
    Fastlane47
    Maryland
    2018 Platinum
    Yes, it's running all the way to 6800, on another run it did hit 18.7 These temps are great for boost!!
    e30cabrio, reywcms, ARES35 and 2 others like this.
  30. Apr 17, 2024 at 5:04 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Just imagine how much fun the 2650 would be!
