Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Apr 6, 2024 at 3:42 PM
    #5221
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Oh yeah super easy. Theres a video at the bottom of the page on how to do it.
    I did all of my glass (Tesla) and still have some left. It’ll last 3-4 months or so
  2. Apr 7, 2024 at 6:51 AM
    #5222
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  3. Apr 7, 2024 at 7:32 AM
    #5223
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I'm not looking for ceramic coating, but what else is good from Undrdog?
    ToyoMafia likes this.
  4. Apr 7, 2024 at 7:46 AM
    #5224
    ToyoMafia
    Magic carpet.
    Their QD is very good and I like the magic elixir for frequent wipe downs. I hear their soap is great.
  5. Apr 7, 2024 at 9:48 AM
    #5225
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Well I'm glad I waited now. Going to get a bottle of the 60ml for both vehicles.
    Edit: ordered. Saved $32. Thanks @ToyoMafia
  6. Apr 8, 2024 at 8:01 PM
    #5226
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    30ml will be fine. Only time I grab 60ml bottles is if I have multiple coatings booked back to back (better ROI) or if it's something like a long bed Super Duty. Better to be safe than sorry. Less is more with coatings. Saturate the pad, but no need to go overboard. Cross hatch application and you're fine. Coatings will only bond a finite amount as the solvent evaporates, any residual just causes a mess trying to get off and can cause high spots.
    ToyoMafia and Fotnot like this.
  7. Apr 10, 2024 at 10:10 AM
    #5227
    TRDRunner
    TRDRunner New Member
    2014 SSM CM
    What's up guys! Needing some input;.. Have new Toyota OEM LED Headlights ready to install. Wanting to apply some type of additional protection (Ceramic coating) onto them prior to installation. Any experience with 'Jet Seal' from Chemical Guys? Or any other recommendations are greatly appreciated! Thanks!
  8. Apr 10, 2024 at 11:36 AM
    #5228
    Damie Street
    Edsel
    I took mine to a tint shop and had them cover them in a UV protection film. Will probably just polish them once or twice a year after install
    ToyoMafia and TRDRunner[QUOTED] like this.
  9. Apr 10, 2024 at 12:07 PM
    #5229
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Wont last long...way better products out there than CG junk
    ToyoMafia and T-Rex266[OP] like this.
  10. Apr 10, 2024 at 12:40 PM
    #5230
    TRDRunner
    2014 SSM CM
    Thanks for the feedback, Eddie! Any ideas on alternative options that you have experience with?
  11. Apr 10, 2024 at 12:43 PM
    #5231
    eddiefromcali
    Eddie
    100% Stock
    I've used laminix and other brand ppf films plus ceramic coating with real good success. I really like CQuartz since its easy to work with and relatively affordable. I've used JS and recently polished headlights faded or aftermarket lights started flaking at one point or another...not the case with PPF and ceramic coating. You could do ppf only and be fine as well
    TRDRunner[QUOTED] likes this.
  12. Apr 10, 2024 at 12:53 PM
    #5232
    TRDRunner
    2014 SSM CM
    Appreciate your time & info! Cheers!
  13. Apr 16, 2024 at 11:41 AM
    #5233
    Danimal86
    Daniel
    Sacramento, CA
  14. Apr 16, 2024 at 12:06 PM
    #5234
    ToyoMafia
    Magic carpet.
    There are a couple products by CG that are ok but for paint protection I have found none. Do yourself a solid and use a real coating. Cerakote makes one that’s cost effective but I only have experience with their trim coat. I personally would use UnderDog pro.
  15. Apr 16, 2024 at 7:30 PM
    #5235
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    I have a 2023 tundra in midnight black. The dealer washed it when new and caused some minor to medium amount of swirls. I have a chemical guys DA and orange, green and black pads. Tried the orange pad with vss and meguiars ultimate polish (separately) removed most swirls but left a cloudy clear coat that was obvious and more annoying than the swirls (the swirls didn’t take me any effort to get) I then purchased a chemical guys green pad as it’s less abrasive. Same/similar results. I’ve tried long slow passes, many passes, few passes, higher speed, lower speed you name it. Same results, cloudy clear coat. The vss is suppose to diminish as you run the DA and generate heat and finish out like a finishing polish (I call BS on this, does it go bad from sitting? Who knows how long it sat on a shelf at the store) This paint is so GD soft a simple microfibre wipe will induce fine scratches seen in the light.
    What do I need to buy (polish) to get clear black paint? I’m about ready to never wash this truck again, so frustrating.
  16. Apr 16, 2024 at 7:44 PM
    #5236
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    rotary polisher, diy detail gold standard polish, and red rotary pad.
    Use a pad washer, clean pad after each section pass. (Also keeps pad damp) Lowest speed the rotary has and no pressure.
  17. Apr 16, 2024 at 8:11 PM
    #5237
    Northern Toyota
    Tires and bilstein
    Can’t I get good results with my DA? Don’t want to buy anymore “tools”
  18. Apr 18, 2024 at 9:36 AM
    #5238
    ToyoMafia
    Magic carpet.
    I would not recommend a rotary polisher if you don’t have experience. Your DA with the right pads should get it done without the chance of messing things up. Boss correction cream followed by polish and then a sealant would be the way I go.
    War Machine and Damie Street like this.
  19. Apr 20, 2024 at 7:43 AM
    #5239
    briarpatch
    briarpatch New Member
    Solid advice here....To the OP.....first mistake you made was buying CG VSS....throw it away...it's garbage, as are the other CG compounds and polish. CG Hexlogic pads are decent....but only the Quantums. I'm not fan of cleaning pads and reusing them as I go....I make sure I have lots of them so I can go right to a clean one. Along with the BOSS correction pads, pick up some Griots Garage BOSS orange (compounding) and yellow (polishing) pads, and some Perfecting cream (polish). Pick a small area, and see if you can rid yourself of the haze with the yellow pad and the Perfecting cream...before you go more abrasive. I like the BOSS pads because they are thinner and are easier to keep spinning.
    Once you get the paint to where you want it.....I'd use Jescar Ultra Lock Plus for a sealant. Very easy to use.....awesome gloss and slickness....plus 6+ months of protection.
  20. Apr 20, 2024 at 8:23 AM
    #5240
    Northern Toyota
    Tires and bilstein
    Thanks.
    I used vss on my 2020 tundra mgm and it worked great to get rid of small scratches and swirls. Maybe it’s a combo of the black paint and it seems super soft. My lunar rock Tacoma (2022) has very soft clear coat as well.
    I’ll order some perfecting cream, everything here in Canada is so much more money than US prices and shipping usually kills the price as well.
  21. Apr 20, 2024 at 9:50 AM
    #5241
    Damie Street
    Edsel
    Solid advice!!
    cartage1 and ToyoMafia like this.
  22. Apr 20, 2024 at 10:00 AM
    #5242
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Personally, I am not a fan of any CG stuff. I've tried their wash soap & interior scent sprays. Trash.
    The company gives off Hot Topic vibes marketed to Gen Z'ers who don't know any better.
  23. Apr 20, 2024 at 3:39 PM
    #5243
    briarpatch
    Interesting perspective......one of the issues is that, if you google 'automobile detailing', tons of CG videos come up. It usually takes a fair amount of trial and error before people realize there are better choices out there. I have a family member who swears by their stuff.....I just chuckle and move on.
  24. Apr 20, 2024 at 3:53 PM
    #5244
    ToyoMafia
    Magic carpet.
    That’s a great result of proper marketing
  25. Apr 20, 2024 at 4:07 PM
    #5245
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yep and I'm one of those people who have tried plenty - for me, Adam's is the savior of car care products (at least the small corner of products I use)
    T-Rex266[OP] likes this.
  26. Apr 20, 2024 at 5:23 PM
    #5246
    briarpatch
    I've not tried any of their stuff....what do you use....and why?
  27. Apr 20, 2024 at 5:45 PM
    #5247
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The 2 part foam and rinse kit they sell is inexpensive and does a great job. I usually wait for a sale and buy several of each. The foam usually goes a bottle per vehicle but I can get 2-3 rinses out of the other bottle. I also love their upholstery cleaner - gets the water stains out that are notoriously easy to occur on OEM fabric as well as headliner stains. The rubber mat cleaner cleans the mats and also leaves a darker hue to them - sort of like a conditioner. The glass cleaner is streak-free and very good as well.
    I am about to try their water spot remover tomorrow and will see if that is any good.
    Leo's first and T-Rex266[OP] like this.
  28. Apr 20, 2024 at 6:00 PM
    #5248
    95% is Adams. For me, their product does not, at least has not, disappointed me.
    My favs: Graphene shampoo (really any of them. Their soap does not leave water spots) My vehicle is ceramic coated. You could do it once a month, but I use it on each wash. It’s affordable and works well
    Total interior cleaner: friendly for all interiors including a/v displays
    Graphene tire shine: doesn’t spit shit everywhere and works great with a shine that’s not overly shiny.
    Wheel and tire cleaner: Works well. 2 birds, 1 stone.
    Upholstery cleaner (use with a cockpit brush). Cleans leather / vinyl well
    Rubber / mat cleaner.
    Clay mit: non aggressive so no marring
    I also use their from cannon, (u can just put the bottle under it without water, so no need for their container if you didn’t want to)
    My pressure washer and wall mounted vacuum is also from Adams
    dondino and ToyoMafia like this.
  29. Apr 22, 2024 at 12:13 PM
    #5249
    War Machine
    War Machine SSEM # 5 3MW
    For aggressive sidewalls that kind of brush is going to do the best job. Only issue I had with those is that they kind of unevenly apply the product, and it seems like you have to use so much that you end up with a mess.
    I’ve pretty much just started using aerosol tire shine now. (Griots Black Satin)
    The liquid tire shines just stopped being worth the hassle eventually.
    Pillslinger, Fotnot and ToyoMafia like this.
  30. Apr 22, 2024 at 12:17 PM
    #5250
    ToyoMafia
    Magic carpet.
    GG satin black is awesome.
