2011 Tundra Bed Rust Advice
Discussion in '2nd Gen Tundras (2007-2013)' started by Sbenecki, Feb 26, 2024.
  1. Feb 26, 2024 at 10:11 AM
    Sbenecki
    Sbenecki [OP] New Member
    Any advice for this area of rust in the corner of the bed? It is flaking up pretty bad. Think I can get away with using a stripping wheel on the angle grinder? Or is it going to have to be cut out and patched? Also not sure if there is a bed mount under there that will complicate things.
  2. Apr 15, 2024 at 11:46 AM
    ljburns
    ljburns New Member
    I just removed my bed liner and have the exact same issue in the same spot. What did you do to fix this? I got a quote for $2000, but seams a bit excessive.
  3. Apr 15, 2024 at 12:06 PM
    Sbenecki
    I didn't do anything. Truck has 218K miles on it, so I will take care of the mechanical and not be a perfectionist about the body. I found a deal on a camper top and bed rug, so now I don't look at it.
    ljburns likes this.
  4. Apr 15, 2024 at 8:29 PM
    LaMobyDick
    LaMobyDick New Member
    Up north
    2009 Crew Cab 5.7
    Rescued this truck from a pothead up north I'm not planning on going full monster, just to update a bit what the guys at Toyota masterfully created. Extended CV axes, Rancho 9600s, new needle bearing, Hewitt Technology secondary air pump bypass, timing chain, VVT screen filter, full towing package, all led custom-made lights and fog lights.
    This is the nightmare I found after removing the plastic liner. The rust in the corners is the easiest to fix if you have to cut it out, because is flat and easy to replace. However, deep rust in the center section represents a problem because finding the corrugated steel sheet is next to each impossible.
    I ended up buying some for GMC trucks and adapting it, then sanding and applying a thick coat of Herculiner.
    PhotoNerd and Cruiserpilot like this.
  5. Apr 16, 2024 at 7:21 AM
    ljburns
    ljburns New Member
    I am glad I don't have anything quite that bad. I might cry. I think I'll go with the bed mat route and monitor for spread every once in a while. I will get it fixed when I have the cash.
