2024 Transmission getting HOT in 4x4 climbing hills, skidplates?
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, Apr 14, 2024.
Thread Status:
Not open for further replies.
  1. Apr 15, 2024 at 10:19 AM
    #91
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    A word on the panty-dropping ability of Volvo, plz.
  2. Apr 15, 2024 at 10:21 AM
    #92
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Can you go faster in 4lo in a gen3 than what we’re used to in previous 4x4’s?
  3. Apr 15, 2024 at 10:25 AM
    #93
    SDHNTR
    SDHNTR [OP] New Member
    This is an excellent question and precisely what's on my mind. If you can, great, and I'd consider 4Lo a somewhat adequate solution. Hopefully this 10 speed allows for greater speeds in Lo.
    If not, and you are still bound to 10mph or so max like a traditional 4 or 5 speed tranny, this truck is going up for sale.
  4. Apr 15, 2024 at 10:29 AM
    #94
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I had to buy the Toyota/Lexus pack for like $20 in order to get them. Might be a monthly subscription now? I don’t know.
    I haven’t. I found the PID though and added it to my dashboard. Will report back.
  5. Apr 15, 2024 at 10:35 AM
    #95
    I’ve never driven a vehicle in 4Lo that would only go 10mph.
  6. Apr 15, 2024 at 10:36 AM
    #96
    Redseal199
    Redseal199 New Member
    2021 CM NightShade
    Nor have i....
    Doxiedad, Medic343 and AZBoatHauler like this.
  7. Apr 15, 2024 at 10:37 AM
    #97
    AZBoatHauler
    So.Arizona
    I go 35-40 in 4Lo in my gen 2.5 - not sure where the 10MPH max is coming from.
  8. Apr 15, 2024 at 10:44 AM
    #98
    MaineTundy
    I’m with sdhunter on this. Anything over 10 mph has always felt like ‘she's breaking up Captain- Scotty’.
    Maybe I just need to push her to warp speed and she’ll settle in.
    Breathing Borla likes this.
  9. Apr 15, 2024 at 10:44 AM
    #99
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    My old '81 Jeep CJ7 would blow up if I tried to go 35-40 in 4LO. But it's got gears and crawl ratios that are actually intended for 4-wheeling, unlike our trucks.
  10. Apr 15, 2024 at 10:47 AM
    #100
    AZBoatHauler
    So.Arizona
    The Tundra t-case is 2.64:1 - 35 in 4low is the same at 88 in high gear. You guys act like the thing is spinning a million miles an hour.
    ColoradoTJ and Terndrerrr like this.
  11. Apr 15, 2024 at 10:51 AM
    #101
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    "FLY HER APART, THEN!!"
    - Hikaru Sulu, Cap't of The Excelsior
  12. Apr 15, 2024 at 10:55 AM
    #102
    Redseal199
    2021 CM NightShade
    Manually select the gear you want in 4lo that way you're not running 4500RPMs
  13. Apr 15, 2024 at 11:03 AM
    #103
    AZBoatHauler
    So.Arizona
    S mode only limits up-shifting - not down-shifting.
    Breathing Borla and KNABORES like this.
  14. Apr 15, 2024 at 11:03 AM
    #104
    SDHNTR
    Dont be so literal. Yes, of course they will go over 10mph, but its not an enjoyable driving experience. Revved up and low geared.
  15. Apr 15, 2024 at 11:04 AM
    #105
    AZBoatHauler
    So.Arizona
    Two keys for not overheating…
  16. Apr 15, 2024 at 11:04 AM
    #106
    SDHNTR
    At 4000 rpm and sounding like its about to blow up?
  17. Apr 15, 2024 at 11:05 AM
    #107
    AZBoatHauler
    So.Arizona
    yep - Yota V8 can’t take 4k rpm. Have you ever looked at a power curve?
    I take OD off all the time in town on the first gen to avoid lugging and keep RPMs up. It only has 250k miles on it…
    FrenchToasty and b6graham like this.
  18. Apr 15, 2024 at 11:09 AM
    #108
    SDHNTR
    I don't doubt the truck can take it, it's the guy behind the wheel who can't. The thought of revved up driving all day long and stopping to shift in and out of 4Lo dozens of times a day navigating mountainous country is not my idea of a pleasurable driving experience.
    But is this 10 speed different? Will it smoothly run in 4Lo at 25mph at reasonable rpms, without driving me nuts?
  19. Apr 15, 2024 at 11:31 AM
    #109
    No, it’s not different in that way. You want higher rpms in a higher work scenario. Do you lug a tractor when you want it to do more work? Nope, throttle up. It’s odd to me that everyone wants to tow and do heavy work at low rpm’s. Why?
  20. Apr 15, 2024 at 11:34 AM
    #110
    Breathing Borla
    AZ
    ya you are, someones rear end, and not the trucks rear end, lol.
    I have had all generations of tundras, you can go faster than 10 in all of them in 4Lo, no problem at all
    AZBoatHauler[QUOTED] likes this.
  21. Apr 15, 2024 at 11:35 AM
    #111
    Breathing Borla
    AZ
    that was funny, HAHA:rofl:
  22. Apr 15, 2024 at 11:39 AM
    #112
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  23. Apr 15, 2024 at 11:41 AM
    #113
    Matt2015Tundra
    2023 1794 CrewMax
    You can easily calculate the RPMs you'll be spinning in any gear, at any speed, in either Hi or Low t-case range, with any sized tire.
    Go here and scroll down to the Crawl Speed Formulas. As mentioned, our t-case in 4Lo is 2.64. Our axle ratio is 3.31. Do a search for the trans ratios. The tire size will depend on what you are running.
    https://www.motortrend.com/features...=An ideal crawl ratio for,least a 100:1 ratio.
    Terndrerrr likes this.
  24. Apr 15, 2024 at 11:43 AM
    #114
    MaineTundy
    Admittedly, I don’t use 4lo often. I also have a Rock Warrior, geared lower I think. Had a 2500 HD before that.
    I tell ya what, I’m going to try and ‘fly her apart’ here in about an hour. Will report back.
    I’m still with OP though, I’d rather just tool along quietly. That B&C might be on next ridge over. ;-)
  25. Apr 15, 2024 at 11:53 AM
    #115
    Breathing Borla
    AZ
    I don't think the rock warrior is geared any different in the rear (4.30) or in the trans that any other 2/2.5 gen model.
    but obvisouly, it's different than the new one with a 3.31 since its got 10 speed behind it. we would have to do all the math for final ratios, but alas, I don't feel like doing that as I don't care enough at the moment, I just use 4Lo when I need to and never have a problem.
    That said, I think the new one is a good amount shorter in 1st for starters.
    but I loved your comment , it was funny and looking forward to you letting rip and reporting back, thats always fun.
  26. Apr 15, 2024 at 11:57 AM
    #116
    :yes:
  27. Apr 15, 2024 at 12:10 PM
    #117
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Now I feel like I was blind. Thanks, I owe you a beer.
  28. Apr 15, 2024 at 12:54 PM
    #118
    Probably on an HD forum somewhere
  29. Apr 15, 2024 at 2:02 PM
    #119
    Jaxyaks
    Jaxyaks New Member
    Does it also overheat in 2wd on steep grades at slow speeds on pavement...long steep mountain passes traffic backed up keeping speed slow etc, slow speed on somewhere like the tail of the dragon etc,
    It would be unfortunate to have to shift into 4 lo to keep the transmission cool while having to monitor turning to not screw up the transfer case.
  30. Apr 15, 2024 at 2:06 PM
    #120
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    For crying out loud my man:
    1.) Go get in your truck.
    2.) Start it up.
    3.) Put it in gear.
    4.) Drive to a street or road with little to no traffic.
    5.) Find a strait section to avoid driveline binding on pavement.
    6.) Go through process to place the transfer case in 4Lo.
    7.) Press down on accelerator.
    8.) Find out for yourself how fast it will go and what RPM’s it will turn.
    You can accomplish this in less than 15 minutes is my guess, and you will know from personal first hand observation.
    Doxiedad, pwpblue and Redseal199 like this.
Thread Status:
