Spare tire swap
Discussion in 'Wheels & Tires' started by purplenova, Apr 13, 2024.
  1. Apr 13, 2024 at 1:03 PM
    purplenova
    purplenova [OP] Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Can a 275/70r18 be swapped with the OEM size spare. Will the larger tire fit up under the rear since the mentioned size is a bit larger.
  2. Apr 13, 2024 at 1:05 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    i believe a lot of people make a 295/70 r18 fit
    i'll be trying with a 315/70 r17 tomorrow
  3. Apr 13, 2024 at 1:16 PM
    biebs96
    PA
    Yes. I have a 285/75/18 (35”) under mine.
    purplenova[OP] likes this.
  4. Apr 13, 2024 at 7:16 PM
    purplenova
    Tom
    Ohio
    Did you do any mods to make it fit?
  5. Apr 13, 2024 at 7:41 PM
    biebs96
    PA
    the metal guides that are from the factory, need to be bend/cut off.
    it is very easy and does not harm anything.
  6. Apr 13, 2024 at 7:53 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    My 275/70/18 Falken Wildpeak AT3W on aftermarket Black Rhino wheel, fits under my 2019 with no modifications.
    I have a 5 tire rotation.
  7. Apr 15, 2024 at 8:33 AM
    purplenova
    Tom
    Ohio
