Swap out grills
Discussion in '3rd Gen Tundras (2022+)' started by jasonv100, Mar 1, 2024.
  1. Mar 1, 2024 at 4:33 AM
    jasonv100
    jasonv100 [OP] New Member
    I’m looking to swap out my sr5 grill to a heritage grill.
    I bought the grill oem and looking to buy the light bar and switches and marker lights. My question is can I wire them on to a switch ?
    I was going to buy the oem marker lights and the Diode Dynamics light bar for $380. Do I buy 2 switches to run the marker lights and light bar ?
  2. Mar 1, 2024 at 6:25 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Lot of how toos on here and YouTube.
    Light bar will come with a switch. But you can buy an oem style one to make a nicer install.
    Marker lights you can either add a fuse into the fuse box on the passenger side in the hood, and they’ll always be on when the truck is on, or you could tap into the headlight running lights. I mean you could get a switch for them but I haven’t seen anyone do this.
  3. Mar 1, 2024 at 8:45 AM
    ghunter321
    ghunter321 Trail Hunter
    NC
    2022 Blueprint Limited Tundra
    Retrax Pro XR bed cover, UpTop Overland mid truss system with Baja Designs rock lighting X6, GGOffroad rearview camera relocation kit, Pelican cargo BX90 case, Maxtrax recovery traction boards, OEM bed step, OEM dash and door trim/cubby/footwell lighting, Slee Offroad dual wireless Qi phone charger upgrade, CBI covert front bumper with air dam delete module, TRD Pro heritage grille replace with amber OEM marker lights, Diode Dynamics 18" white lightbar kit and OEM marker lighting, Diode Dynamics covert 18" amber lightbar, Rough Country bed mat, Rough Country defender series fender flares, TRD camo tailgate spoiler and OEM marker lights, TRD camo rear bumper arms, Screen Protech for interior surfaces, OEM badge blackout
    There have been reports of the DD light bar cracking the grille since (unless it’s changed) there isn’t any support for the weight of it. I have the exact same swaps you mention in the original post. My OEM marker lights didn’t come with wiring and the connectors were hard to source. When I found the connectors, I just wired into an always on fuse under the hood with add-a-fuse. The OEM light bar that is supposed to fit there has a support but it interferes with the automatic grilled shutters if you have them. The only solution I’ve seen so far is a Baja design bar the comes with the vertical support that MIGHT fit in front of the shutters but I haven’t pulled the trigger on that yet personally…
  4. Mar 1, 2024 at 9:54 AM
    Tim P
    Tim P New Member
    Make sure you check the grille now because Toyota suppliers have been shipping the wrong parts and grilles have come in broken. I had 3 come in broken and the wrong part for the front bumper.
  5. Mar 1, 2024 at 10:54 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    diode dynamics updated their brackets late last year I believe so that shouldn’t really be an issue anymore. I saw a fair amount of posts on the lights vibrating but nothing about actually cracking the grill but I suppose that’s possible base on how much it could move
  6. Mar 1, 2024 at 11:05 AM
    ghunter321
    NC
    Intriguing. Any specifics on it? I’ll admit, with the slight wobble I see in the grille just from shutting the hood, I could easily see the weight of any light bar without support lead to the cracking people have described. I have a DD light bar in the covert CBI bumper down below and I am quite happy with it. Would love to stick with DD for consistency and price point.
  7. Mar 1, 2024 at 2:12 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    info here: https://www.diodedynamics.com/blog/how-to-install-2022-tundra-ss18-trd-pro-grille-light-bar-kit
  8. Mar 1, 2024 at 2:27 PM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
  9. Mar 2, 2024 at 5:44 AM
    Jalzate44
    Jalzate44 New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
    I just completed this last weekend. Added heritage grille with marker lights. I used the rave harness for this. Lights come on when the truck is on. DD light bar is ran to a OEM style switch that I purchased from caliLED. The light bar comes with 2 new supports (pictured above)
  10. Mar 2, 2024 at 12:00 PM
    ghunter321
    NC
    This is awesome news. I’ve noticed the profile is pretty deep on my other one. Do you have the automatic grille shutters? Does everything clear them without further modding?
  11. Mar 5, 2024 at 12:37 PM
    ghunter321
    NC
    Just a little bump for @Jalzate44
  12. Mar 5, 2024 at 8:09 PM
    Jalzate44
    San Antonio TX
    Yes I do. They do clear just have to slid the light bar all the way forward
  13. Mar 27, 2024 at 6:52 AM
    jasonv100
    Thanks for all the info, I installed my grill and all my lights. I installed the TRD marker lights with the rave, off-road harness, which works perfect and stays on when the car is on.
    My only problem is trying to wire up the light bar I have the Cali LED switch and the a light bar has just two wires coming from it. Does anybody know if there’s a wire harness or how I would wire the light bar to the switch? Thanks in advance,
  14. Mar 27, 2024 at 7:00 AM
    ghunter321
    NC
    Depending on the light bar, the wiring harness should have come with a relay which you will need to hook up to caliraised switches. If no relay was included, you may have to wire your own or see if the lightbar supplier has a plug and play harness.
    I had a recent post where I wired up my first harness on my own and so far no problems. It might be a little confusing to follow but if you're comfortable with electrical work, its the cheapest approach.
    https://www.tundras.com/threads/could-someone-help-me-make-sure-i-don’t-set-my-truck-on-fire.138648/
  15. Mar 27, 2024 at 7:12 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    You need a relay harness. You can get them on Amazon for a few bucks. The switch will power the relay and that in turn powers the light bar. I bought a Baja Designs grille light and they sent everything I needed. Looking at the DD website, it looks like the kit does come with a harness...did you not get it?
  16. Mar 27, 2024 at 7:33 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I got a DD Light bar and it does come with the relay harness kit and some brackets to stiffen up the flimsy grille.
    They even give you a little toggle switch so you can connect these up and make them work. Getting a matching switch would be a different purchase.
    I haven't hooked mine up yet, waiting for better weather so I can paint the stache and wire up my fender lights.
  17. Mar 27, 2024 at 8:40 AM
    jasonv100
    I didn’t get a wire harness with my light bar . It looks like I will have to rig something up myself. First to find a good and easy harness relay on Amazon or local store today
  18. Apr 9, 2024 at 10:01 AM
    DIYReid
    DIYReid New Member
    KC
    2024 Ice Cap Tundra Limited
  19. Apr 9, 2024 at 11:05 AM
    MaxPayne3
    MaxPayne3 New Member
    2024 Lunar Rock SR5 Crew Cab
    Just starting out but never will be done
    I have the OEM light bar in mine and I used some round aluminum stock from Home Depot and cut into 1 1/4" inch sections and got some longer 6 mm bolts to make my grill shutter clear. Was less than $15.00 in partsrock lights 2.jpg
  20. Apr 10, 2024 at 5:30 PM
    SR5_SFD
    SR5_SFD New Member
    Maine
    ‘23 Tundra SR5 Crewmax
    TRD Exhaust Tip, TRD Air Filters, TRD Skid Plate, 4” Ionic nerf bars, Tufskinz Door sill protectors, Tufskinz Drive Mode Badge, Tufskinz Badged Tailgate Inserts, Husky liners, NYTOP Front Recovery Points
    I just ordered the oem marker lights from Sparks tonight. Looks like there isn’t any wiring based on the photos. Now I’m anticipating no wiring coming with them and stumbled on your post. Where did you order from and where did you source the connectors from? TIA!
  21. Apr 14, 2024 at 1:49 PM
    ghunter321
    NC
    Got the connectors here. https://thetrailhunters.com/shop/exterior/2022-tundra-trd-pro-fender-flare-marker-light-plugs-kit/ It says fenders but the plugs are the same for the marker lights. Ran the wires along the clips in the OEM marker plastic piece and then did add-a-fuse to an always on with ignition fuse in the engine bay. (Can post pics if interested). I also had a spare waterproof harness lying around so I cut the lines right about where the other harnesses disconnect when taking off the front bumper and grille and wired them up to the connector so now I unplug 3 harnesses on that side instead of two when I need to pull off the front for other things.
    SR5_SFD[QUOTED] likes this.
  22. Apr 14, 2024 at 6:03 PM
    SR5_SFD
    SR5_SFD New Member
    Maine
    Thank you!
    Pics would great and I’m sure it’d help more people than just me. Appreciate it.
