Name this thing - what is it?
Discussion in 'Off-Topic Discussion' started by shifty`, Apr 14, 2024.
  1. Apr 14, 2024 at 6:32 AM
    shifty` [OP] You can call 1 (800) PP5-1-DooDoo
    Curious what this thing I found on the side of the road is. It's about 6-7" wide, with two ~1.25" holes, and a split on either side of the holes to pinch it onto something. It's solid steel, and covered in grease. Looks almost like it could hold a heavy u-bolt in place or similar, tons of grease/dirt buildup so assuming automotive/industrial use. No markings I could find though.
  2. Apr 14, 2024 at 7:01 AM
    2mchfun
    Attitude adjuster
    Cpl_Punishment and shifty`[OP] like this.
  3. Apr 14, 2024 at 7:06 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    It’s one side of a spring shackle from a commercial truck, and I’d go as far as to say a Kenworth or Peterbilt.
    Odd that it still has the pinch bolts but nothing left of the spring pins , and odd that it was laying on the side of the highway.
  4. Apr 14, 2024 at 7:10 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  5. Apr 14, 2024 at 7:11 AM
    2mchfun
    Yep. This/\/\
  6. Apr 14, 2024 at 7:15 AM
  7. Apr 14, 2024 at 7:32 AM
    Well hot damn, at least I got the purpose within a few inchest of actual purpose :rofl:
    I found it in an exceptionally chunky section of street in an old intown neighborhood. Best guess, it slipped off. Wonder how far the vehicle got before their leaf pack fell off?
    It's hefty. It really could be an attitude adjuster.
    Black@Blue19 and 2mchfun like this.
  8. Apr 14, 2024 at 8:01 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    I'd call it a widget.
