  1. Apr 13, 2024 at 4:06 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I thought of you this afternoon. We went to the RV and boat show at AT&T stadium. It was a blast. The kids had so much fun being able to climb in and out and touch every thing they wanted to.
    bmf4069, khooiii, BroHon and 3 others like this.
  2. Apr 13, 2024 at 4:20 PM
    ... and golden showers? :rofl:
    Hey, I'm about to post a picture from my phone. Anyone know what it is? I found it on the ground. It's about 6-7" wide, with two ~1.25" holes and a split on either side to pinch something. It's solid steel, and covered in grease. Looks almost like it could hold a heavy u-bolt in place or something, but there's so much grease.
  3. Apr 13, 2024 at 4:28 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    this might help
    https://youtu.be/RXJKdh1KZ0w?si=QrvjJJA9LEoCmPHO
  4. Apr 13, 2024 at 4:30 PM
    JakeJake[QUOTED] likes this.
  5. Apr 13, 2024 at 4:32 PM
    It’s an expent dingle arm. (Per the video)
    shifty` and JakeJake like this.
  6. Apr 13, 2024 at 4:52 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    I thought there was some annual service to be done on sprinkler systems? Bleeding out any moisture or something. Been such a very long time.
  7. Apr 13, 2024 at 4:53 PM
    Anyone heard from @Sunnier or @alb1k lately? Hope they are doing well.
    455h0le_dachshund likes this.
  8. Apr 13, 2024 at 4:53 PM
    Yeah there is, your mainly testing tamper switches and flow switches tied into the fire panel, but that doesn’t always get rid of all the air
    NUDRAT[QUOTED][OP] likes this.
  9. Apr 13, 2024 at 4:54 PM
    They are both alive and well, I’ll send their regards on my behalf without them knowing…..
  10. Apr 13, 2024 at 5:06 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Glad I'm not the only one
  11. Apr 13, 2024 at 5:07 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    It's meant for serious off-roaders.
    If that's not your things, then OEM should be best for you.
    Not to mention, the Solo LCAs too. Not sure if their uniball LBJs work with OEM LCAs.
    Big $
  12. Apr 13, 2024 at 5:11 PM
    Sounds like a poorly designed system….or just planned obsolescence.
  13. Apr 13, 2024 at 5:15 PM
    It’s state money so probably the latter
  14. Apr 13, 2024 at 5:19 PM
    I was curious about @Sunnier as well, but didn't want to tag - got the impression the plate was a little full of stuff.
    @alb1k seems good, we were pinging back and forth last week.
    And with that, off to start a fire!
  15. Apr 13, 2024 at 5:20 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    A
    Seems really easy to just attach tubing with a line attached to it running through the top of a lid into a container and submerged in brake fluid then opening nipple at caliper and pumping it out instead of backward into the abs.
    BroHon likes this.
  16. Apr 13, 2024 at 5:22 PM
    ToyotaDude
    ToyotaDude Member
    Maybe should post this in the rear wheel bearing thread....Done a lot of reading and haven't concluded answer specific to bestgen Tundra about the claim of a new OEM axle seal redesign moving the seal lip inward toward the 3rd member, and hence an inner retainer flip recommended per Timmy @19:30 and @22:41 in his video:
    https://www.youtube.com/watch?v=AVhSDnw2ugo
    The axle housing seals (90310-50006) and the retainers (42423-20010) appear to be the same part numbers (as well as the o-rings and c-clips) on the axle he is working on (although the outer axle dust seals and bearings appear to be different part #s).
    For at least certain VIN bestgen AC 4x4 4WD:
    90363-40068 Rear Axle/Wheel Bearing
    90310-50006 Axle Housing Oil Seals (Type S Oil Seal)
    90301-88077 O-ring
    90313-54001 Dust seal (Type K Oil Seal)
    42423-20010 Retainers (Bearing Spacer)
    43517-35010 ABS Ring (Skid Control Rotor)
    90520-36045 C-clip
    It seems most are installing the retainer in the OEM orientation and then grease or sharpie testing seal contact area and adjusting. But Timmy notes @ 24:07 a risk of installing the retainer too far outward and the retainer hitting the axle housing, and hence the suggested "flip" of the retainer to move more surface under the redesigned seal?
    So for bestgen is the inner retainer recommended to be installed in the OEM orientation or flipped per Timmy his video?
  17. Apr 13, 2024 at 5:27 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    How you think they got all those trailers organized inside?
    I'm betting forklift.
  18. Apr 13, 2024 at 5:29 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I've noticed quite a few of our west coasters have been sparce to MIA
  19. Apr 13, 2024 at 5:35 PM
    daveeasa
    I’m a Westie.
  20. Apr 13, 2024 at 5:35 PM
  21. Apr 13, 2024 at 5:36 PM
  22. Apr 13, 2024 at 5:39 PM
  23. Apr 13, 2024 at 5:45 PM
    Had it rippin’ for a minute there.
  24. Apr 13, 2024 at 5:46 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    No wonder youre bald. Calm down with the hydrocarbons.
    bmf4069, Sunnier, BroHon and 2 others like this.
  25. Apr 13, 2024 at 5:51 PM
    Shhh, don’t tell the Stockholm kid.
  26. Apr 13, 2024 at 5:52 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Why do all alignment racks have the red strobe lights?
  27. Apr 13, 2024 at 5:52 PM
    Disco lasers
  28. Apr 13, 2024 at 5:56 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    So at work, I walk past the Firestone/Bridgestone next door several times per shift, and even when they are closed, the red strobes are going off through the garage door windows.
    shifty`[QUOTED] likes this.
  29. Apr 13, 2024 at 6:03 PM
    Secret rave, time to investigate.
    bmf4069, Mr.bee, FrenchToasty and 2 others like this.
  30. Apr 13, 2024 at 6:05 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    The hardware & computer is left on. The software/hardware is finicky on startup and doesn't want to load at times. A real pita when customers are waiting and it wants to play games.
