Question on touchscreen fix
Discussion in '3rd Gen Tundras (2022+)' started by AustinTexas, Apr 10, 2024.
  1. Apr 10, 2024 at 7:52 PM
    AustinTexas
    AustinTexas [OP] New Member
    Anyone know how to fix my below issues with the touchscreen.
    this is only happening on my. 2024 Tundra. I did not have this issue with my 2022? I am hoping I just need to change a setting.
    1. when I start the truck, I get this “do you want to adjust your seat” message. If I take off driving without tapping yes or no it blocks my touchscreen from being usable. Any way have stop the message from appearing and doings this? I thought my 2022 would just automatically adjust the seat to what ever key fob was being used. If I stop , put it in park and tap yes or no, then the message goes away.
    2. when I want to make a phone call. I keep having to select my phone for the device , even though my phone is already sinked and Apple car play is being used. My phone is also the only phone in the car? My 2022 , I never had to do this every time I wanted to make a call , it just automatically called from my phone.
  2. Apr 10, 2024 at 9:04 PM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    1. You have to link your FOB to your profile. IIRC, it's in the general settings on the head unit. Do a search. It's been discussed several times on this forum.
    2. I'm not positive on this, but I think you have to confirm your phone is the default device. Again, that's somewhere in the head unit settings.
  3. Apr 11, 2024 at 9:16 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    You also must save a seat and mirror profile on the drivers door (if you haven’t already)
    ryanwgregg likes this.
  4. Apr 11, 2024 at 10:16 AM
    Matt2015Tundra
    2023 1794 CrewMax
    I don't think so. I've never set up seat and mirror profiles on my '23 1794 because I'm the only driver of my truck, so the seat and mirrors never get moved.
    Linking my fob to my profile has eliminated the "Adjust seat" message for 8 months. My phone was set to the default device when I did the initial setup. I never have to select a device to make a call.
    Mattedfred, ryanwgregg and pwpblue like this.
