Battery recommendation
Discussion in '3rd Gen Tundras (2022+)' started by Ipaddick, Mar 6, 2024.
  1. Mar 6, 2024 at 1:29 PM
    Ipaddick
    Ipaddick [OP] New Member
    Canada
    Platinum hybrid w/advanced package
    I have a 23 platinum hybrid with advanced package. I’ve been having electrical issues where the battery keeps dying. Once it died while having music going for about 15 mins in accessory mode.
    about a month ago it wouldn’t start after being parked for a week (Toyota told me this is normal with new vehicles which I called bs)
    Yesterday I had my truck in accessory mode while pumping gas… died in that time. So dead the running boards wouldn’t fold out.
    today my truck randomly died and I can’t get it to start even with a boost pack.
    any recommendations on a good battery. It goes to the shop tomorrow… or today if I can’t get it started.
    thanks.
  2. Mar 6, 2024 at 1:34 PM
    umrex
    umrex New Member
    X2Power AGM from Batteries Plus. BTW I have a hybrid and have the same issue also. I am thinking of upgrading to this.
    NickBrewer likes this.
  3. Mar 6, 2024 at 1:38 PM
    rlc177
    rlc177 Data Logger
    Northeast PA
    Both the non-hybrid and hybrid use LN4/H7/94R size batteries.
    The Non-Hybrid specs an EFB (Enhanced Flooded Battery) While the Hybrid specs a normal Flooded Battery.
    On the hybrid the safest thing to go with a normal H7 lead battery with better specs than the factory. Otherwise you can try an AGM H7 battery to see if that holds out better. You can go up (SLA -> EFB -> AGM) but you can't go down (EFB-> SLA) I only say "safe" as in I'm not sure the Charging profile of the Hybrid is optimized for AGM requirements, the AGM should work fine otherwise.
    Do you happen to have the Toyota dashcam? I'm finding mine is drawing a lot of power while the truck is off and its in parking mode.
    ryanwgregg likes this.
  4. Mar 6, 2024 at 1:56 PM
    Ipaddick
    Canada
    I have an aftermarket one. It shits down when truck is off. But regardless 5 mins is insane
    I know have a hybrid malfunction and can’t jump it. Waiting for a tow…
  5. Mar 6, 2024 at 2:00 PM
    rlc177
    rlc177 Data Logger
    Northeast PA
    Yeah you can always swap out for a AGM battery but it sounds like there is a bad parasitic draw on the battery somewhere. Should have the battery tested as well.
  6. Mar 6, 2024 at 2:19 PM
    rlc177
    rlc177 Data Logger
    Northeast PA
    Checking the amp draw with my clamp meter on the my non-hybrid in accessory mode is draining about 9AMPS from the battery.
    However in the hybrids probably better to avoid accessory mode and just leave the ignition on, the engine should shut off and continue to power the 12v system from the hybrid battery.
    jachal likes this.
  7. Apr 9, 2024 at 2:23 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I have an odyssey AGM in my non-hybrid. Works for me.
    jachal likes this.
  8. Apr 9, 2024 at 8:04 PM
    ArBrnSnpr
    ArBrnSnpr New Member
    Colin
    22' AG SR5 TRD OR
    What size is that?
    And what's the 250 amp fuse block wired to?
    Looks like a clean set up!
  9. Apr 10, 2024 at 9:56 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    thanks! That 0-gauge feeds my JY-power which in turn feeds my amps.
    The battery model is a 94R (specifically ODP-AGM 94RHZL4) I think there’s a similar one that’s 94R-850 but not sure of any actual differences between them
  10. Apr 10, 2024 at 10:02 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    No love for steve's products from me but def love the clean install
    Goobax likes this.
  11. Apr 10, 2024 at 10:15 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Which model did you get of the Odessey battery?
  12. Apr 10, 2024 at 10:33 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Sorry about that, I updated previous post. 94R is the size and model provided above
  13. Apr 10, 2024 at 3:23 PM
    Breathing Borla
    Northern Illinois
    whats the real life benefit of AGM in a non-hybrid over the enhanced flooded spec?
  14. Apr 10, 2024 at 7:17 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    slower drain time, less chance for corrosion, and the high demand I have on the electrical system with my sound system (1800 watts between the two) was enough for me. I disabled my start stop but that’s also another benefit where AGM is better.
  15. Apr 10, 2024 at 8:02 PM
    RatPanda
    RatPanda New Member
    2022 Tundra 4x4 CrewMax 5.5
    Where did you get the bracket to hold the fuse block?
  16. Apr 11, 2024 at 9:37 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    it was made by a local audio shop
