Fueling the 2023 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by skelly, Apr 11, 2024.
  1. Apr 11, 2024 at 8:00 AM
    skelly
    skelly [OP] New Member
    Shawn
    2023 Toyota Tundra TRD PRO, Metallic Grey.
    N/A
    Anyone have any ideas as to why I can add almost 2.5 to 3.00 gallons of fuel to my 2023 Tundra after the pump clicks off ? Is it safe to top it off ? Can it be damaging to do so ?
    Any thoughts would be appreciated,
  2. Apr 11, 2024 at 8:06 AM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Topping off your gas tank is a bad idea. Overfilling saturates your vehicle's vapor recovery system which can lead to permanent damage and avoidable repairs.
  3. Apr 11, 2024 at 8:09 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I usually do one more click after...I dont shove more in there after that. My father in law ruined a charcoal canister (EVAP Stuff) doing what youre doing. He'd shove as much gas as he could into his Avalon until one day he got an evap code...$800 canister later, he stopped doing that. Theres no need for it, dont do it
    Mattedfred and cmiles97 like this.
  4. Apr 11, 2024 at 8:16 AM
    skelly
    Shawn
    N/A
    Thank you, I appreciate the explanation. I will no longer be topping it off.
    cmiles97 and drewpweinerMD like this.
  5. Apr 11, 2024 at 8:38 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    I always use to lower lock position on the the fuel handle to add fuel a little slower. All pumps are not created equal so maybe another station may be different too.
    Hi from PA
  6. Apr 11, 2024 at 8:51 AM
    nodak67
    nodak67 New Member
    JR
    i put the pump on med click and stop once it pops off. if i need more gas i will fill again.
    i only track gas consumption as a gee whiz fun project. we dont care how much it costs cause really, we will get the gas whether its $5 a ga or $3 gal and we can afford it. otherwise we wouldnt have bought the tundra.
    TundraDan723 likes this.
  7. Apr 11, 2024 at 9:12 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Tank on the right, fill on the left. Theres a long hose across the truck that could hold a gallon or two on top of completely filling the tank. That’s your extra gallons.
    FWIW if you like this guy - short explanation of the possible damage in overfilling >>> https://youtu.be/jPiiqcDxDxY?feature=shared
    cmiles97 and Tundrastruck91 like this.
  8. Apr 11, 2024 at 10:41 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    Years back I read or saw a video on why this is bad, which has already been pointed out above, and haven't done it since.
    1st click, done and move on.
    What do folks think squeezing a little bit more gas accomplishes? Not worth the risk. Yet to this day I hear other folks fill and click many times.
    Jettster and Tundrastruck91 like this.
