Is this oil level ok approximately 3400 miles into OCI?
Discussion in '2nd Gen Tundras (2007-2013)' started by NickG, Apr 10, 2024.
  1. Apr 10, 2024 at 3:28 PM
    NickG
    NickG [OP] New Member
    2009 Toyota Tundra Limited DC 5.7L
    This is the level it was at after a 2 hour drive. I let it sit for 10-15 minutes before checking after the drive. It’s about 3400 miles since my oil change and I do use 0w20 Valvoline.
  2. Apr 10, 2024 at 3:35 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    It looks low from the blurry picture. Next time check your oil before starting on a level surface
    Did you check the oil level after the oil change?
  3. Apr 10, 2024 at 3:36 PM
    NickG
    Anyone able to guesstimate how many quarts it’s down by? I know when I check it during the first 3000 miles OCI, it was right at the top mark. I checked this in my driveway which is mostly grassy.
  4. Apr 10, 2024 at 3:38 PM
    NickG
    Ok, here’s a picture. I know it’s blurry but I drew a line where my level is. The blue line represents the level.
  5. Apr 10, 2024 at 3:54 PM
    koditten
    Kirk
    Midland of the Mitten
    It's fine. Pretty normal.
    PhotoNerd likes this.
  6. Apr 14, 2024 at 6:06 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Anywhere between your red lines is good. If at or near lower red line you should add some to bring it closer to top red line. But it is still the safe range.
  7. Apr 14, 2024 at 8:00 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Completely fine. still has good color too.
  8. Apr 14, 2024 at 8:04 AM
    AZBoatHauler
    So.Arizona
    What brought this on? Seems odd to post a thread with a pic of oil between the two dots asking if the level is okay…
    FrenchToasty and Leo's first like this.
  9. Apr 14, 2024 at 8:15 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Thiss Exactly this I've seen a few of these lately
    Change your oil with oil and bring the level to anywhere between the dots. This just doesn't seem verry complicated to me and I'm pretty simple guy
