High idle on steep inclines
Discussion in '3rd Gen Tundras (2022+)' started by mcnabb100, Apr 3, 2024.
  1. Apr 3, 2024 at 6:00 PM
    mcnabb100
    mcnabb100 [OP] New Member
    Noticed this a little while ago and thought it was an interesting behavior.
    23 Limited TRD OR
    https://youtu.be/OyDWPjLUc3Q?feature=shared
    At the start of the video I’m stopped on a steep section of my driveway and the truck is idling around 800rpm while in drive. I proceed to a level spot and stop again and the truck drops back down to the normal idle.
    I didn’t do it in the video but if you shift into neutral it will also drop the idle back down.
    Im assuming this is some sort of hill start assist, but I’ve never seen another vehicle increase the idle speed, every other vehicle I’ve driven just holds the brakes.
    Have any of y’all noticed this?
  2. Apr 10, 2024 at 10:32 AM
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    Mine does it too I'm curious too sometimes it's rough if the rpms are too high.
  3. Apr 10, 2024 at 12:00 PM
    xc_tc
    xc_tc New Member
    I’ve also noticed this too, it does help with parking on really steep inclines. Don’t notice it too much otherwise, normal driving.
