Mustache is painted! DIY
Discussion in '3rd Gen Tundras (2022+)' started by alex17117, Apr 9, 2024.
  1. Apr 9, 2024 at 7:13 PM
    alex17117
    alex17117 [OP] New Member
    Alex
    2024 limited, Lunar Rock
    I’ve been going back and forth on how to color match the mustache on my limited. I decided to diy paint it. I think it turned out okay but we’ll see how long it holds up. For less than $40 of paint and supplies I’m happy!
  2. Apr 10, 2024 at 10:27 AM
    armygreentundra
    armygreentundra LIVIN'
    Desert SW
    2021 TRD Pro MGM
    Dirty Deeds TRD Replacement
    I've been wanting to color match the mustache since I picked up mine. Looks good but maybe a little off in color? Could just be the photo or shadows. Either way it looks way better than chrome! How long form start to finish?
  3. Apr 10, 2024 at 10:31 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    way off in that lighting...got a pic in daylight?
    Breathing Borla likes this.
  4. Apr 10, 2024 at 12:36 PM
    lapoolboy
    lapoolboy New Member
    So when are you going to color-match it?
    Pilotjoe123, Siblue and eddiefromcali like this.
  5. Apr 10, 2024 at 12:45 PM
    alex17117
    Alex
    Yeah the color is a bit off. Looks much closer in daylight than at night. Took the course of a day between prep and letting the coats dry. Fun project, but only about 50% confident it will hold up.
  6. Apr 10, 2024 at 12:46 PM
    alex17117
    Alex
    Probably after this chips off...
  7. Apr 10, 2024 at 2:26 PM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    Did you prep it prior to painting or use an adhesion promoter? If you have to redo it I would recommend scuffing gel and a gray 3M scuff pad, but you might have to sand off the paint if it starts to flake making that step not needed. 400 grit wet sand paper would probably be the best to do that.
    I don't know what plastic this piece is made out of but this is what adhesion promoters are used for, from the internet:
    Parts that are made from Olefin Polymers must have an adhesion promoter used before refinishing to assure that the finish will not delaminate later.
    alex17117[QUOTED][OP] likes this.
  8. Apr 18, 2024 at 7:20 PM
    alex17117
    Alex
    Tried again. Turns out there are 2 versions of the lunar rock 6x3 code… color match is perfect and the outcome is great!
  9. Apr 18, 2024 at 7:23 PM
    alex17117
    Alex
    I did prep by sanding and then used a metal primer. When I went back and sanded for redoing the job with the right color, adhesion was great (no chipping off) so I think that the sanding and primer worked well.
    hinkle[QUOTED] likes this.
  10. Apr 18, 2024 at 8:37 PM
    TundraBrew
    TundraBrew New Member
    Which paint product(s) did you use? Second pic looks great.
  11. Apr 18, 2024 at 9:01 PM
    alex17117
    Alex
    Thanks! I’m really happy with it. It’s a spraxmax product mixed at a local auto paint shop
  12. Dec 22, 2024 at 11:49 AM
    tahoetund
    tahoetund New Member
    2024 Platinum iForce Max, Lunar
    So go to the shop and ask for 6x3 lunar rock spraymax? Sanding and what type of primer? Anything else? I tried a bumpershellz cover but i dont love it
  13. Dec 22, 2024 at 12:11 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    What a beautiful view! Looks too cold, but that view is amazing.
    Soupbean77 and Gonefishingdave like this.
  14. Dec 22, 2024 at 2:53 PM
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    I agree!!!
    If that isn’t heaven it’s close to it!
    I’ll take a 30 degree day over 90 anytime.
  15. Dec 23, 2024 at 8:49 AM
    Nates91xj
    Nates91xj New Member
    Did you wrap the Toyota letters in the grill or did you get them that way? Looks awesome
  16. Dec 23, 2024 at 12:26 PM
    tahoetund
    It came with the aftermarket grill kit. Checkout YotaExpedition Pro Grill kit.
    Nates91xj[QUOTED] likes this.
