Engine swap question
Discussion in '1st Gen Tundras (2000-2006)' started by Arlott1, Apr 2, 2024.
  1. Apr 2, 2024 at 9:33 PM
    Arlott1
    Arlott1 [OP] New Member
    2005 Silver Tundra DC SR5
    Can I swap an engine from a 2wd model to my 4wd?
    Are there any differences in it connecting to the bell housing or transmission?
    What about wiring harnesses?
    They are both 2005
    Thanks in advance
  2. Apr 3, 2024 at 6:18 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I want to say yes but I'm far from an expert on the matter. Wiring harnesses are usually the thing that get people but with them being the same year they should be the same.
    What happened to your old engine?
    Edit: I see you made two threads.
  3. Apr 3, 2024 at 7:06 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Jack McCarthy and whodatschrome like this.
  4. Apr 3, 2024 at 7:27 AM
    shifty` Ten EV 12's so you know I raise hell
    I will tell you, that grille on the Waltrip model is worth a mint. As is the exhaust, if OEM.
  5. Apr 3, 2024 at 12:33 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    The 2wd and 4wd engine block to bell housing bolt patterns are exactly the same. The wire harnesses are different between the two models. The difference is that the 4wd engine harness had an additional sub harness that’s located in the main harness loom. Simply unplug the 2wd engine harness off the donor engine, and plug your existing 4wd engine harness to block that was in Dale’s truck.
    Pro tip, it’s waaaaaaaaaaaaaaaaay easier to remove or install the engine harness AFTER you pull the engine out of the truck! Which also means that it’s WAY easier to install your existing 4wd engine harness BEFORE you fit the engine back into the bay! That means you need to unplug the engine harness from the fuse block as well as other ancillary bits, bobs, and sensors. All that is much easier and faster than it sounds.
    shifty` and w666 like this.
  6. Apr 7, 2024 at 6:01 PM
    Arlott1
    I pulled the plugs today and noticed this in one of the cylinders.... Thoughts?
    I feel like a got a little movement out of the crank this time so I will be letting some marvel mystery soak in and try agin in a few days..
