Should your Off-Road Tundra go on a diet? What Cargo Weight Rating do you have left?
Discussion in '3rd Gen Tundras (2022+)' started by Balzac, Apr 6, 2024.
  1. Apr 6, 2024 at 9:59 AM
    Balzac
    Balzac [OP] New Member
    L
    2023 Tundra Limited CrewCab, TRD OR
    Tonneau cover, added layer of ice, mud or dust
    Astonished to notice the number of heavy equipment are been affixed on this half-ton truck. Did anybody visit a CAT scale once loaded? Is there any upper limit not to be exceeded? What could be the issues with insurances in case of accident?
    My Tundra comes from factory with only 650lb or 295kg Cargo Rating.
    New steel bumper: @ each 200lb more?
  2. Apr 6, 2024 at 10:50 AM
    Breathing Borla
    AZ
    are you saying stock your payload sticker says 650lbs?
    Thats not right , even my loaded crewmax platinum with every option has 1,3xx lbs
  3. Apr 6, 2024 at 1:08 PM
    Balzac
    L
    Thanks! My error! The 650lbs figure is not from the payload sticker, but from below, got it as I searched "cargo" in the manual. Did I mix up lbs with kg? This figure probably does not include passengers. The sticker on the truck says 1400lbs or 635kg. Anyway the payload is a worry for me as this Tundra is used for hauling a 7500lbs trailer, with a consequent tongue weight, the family, canoe, and the whole stuff needed for boondocking.
  4. Apr 7, 2024 at 9:11 AM
    xc_tc
    xc_tc New Member
    Cargo means not passengers. Toyota defines passengers at some weight so with 5 passengers the truck can only carry x amount of cargo. Just go off the payload value on the sticker, it has a lot of margin as many have showed. The actual payload (GVWR MINUS CURB WEIGHT) is much higher than the indicated payload on the sticker.
  5. Apr 7, 2024 at 5:20 PM
    Balzac
    L
    Interesting. How much margin? My sticker mentions 1400lbs actual payload. Prefer doing a budget before loading
    Front and rear steel bumpers: 400lbs + Rooftop Tent Hard Shell: 170lbs + Aluminium Heavy Duty Truck Bed Rack: 80lbs + Power running boards: 50lbs that adds to 700lbs
    Not counting added lights, roof rack, tow hooks, winch, …and leaves 700lbs for passengers, tools, stuff, food and water. Not much.
    NB The weight of the accessories is infrequently shown on the specs online.
  6. Apr 7, 2024 at 6:06 PM
    blenton
    blenton New Member
    IIRC, Toyota assumes each passenger is 150 lbs. Might be accurate for you and your passengers, might not. My kids are small and mostly string beans, so even if we add the the two larger dogs and don't count them as passengers, we aren't at the 150 lb/passenger average.
  7. Apr 9, 2024 at 4:40 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    Sounds like you may want to go to a heavy duty truck like a F-250 with that kind of weight, going on trip regularly.
    Although going heavy duty didn't solve this problem.
    Mattedfred likes this.
  8. Apr 9, 2024 at 5:51 AM
    RVer
    RVer New Member
    2023 Platinum CrewMax
    Payload is certainly important but it's also important to check how much weight is on each axle and compare those numbers to the specification for your truck. The CAT scale is the easiest way to check that. I've found that it's pretty easy to overload the rear axle on these trucks.
  9. Apr 9, 2024 at 1:03 PM
    AZBoatHauler
    So.Arizona
    Right - you’re way over GVWR before you overload the axle.
    Mattedfred[QUOTED] likes this.
  10. Apr 9, 2024 at 3:14 PM
    RVer
    RVer New Member
    True, I'm just saying when balancing the load with towing between trailer, truck cargo and tongue weight / weight distribution it's good to keep an eye on how weight is distributed.
    AZBoatHauler[QUOTED] likes this.
  11. Apr 9, 2024 at 5:47 PM
    RVer
    RVer New Member
    The rated spec GAWR (front axle) is 4080lbs, the GAWR( rear axle) is 3860 on my truck. All I was trying to say was that when adding payload to the truck, as I do when towing, I was seeing numbers coming close to that rear axle spec ( front axle was fine ) without putting a whole lot of extra stuff ( I travel fairly light ) in the bed so in my view, for my situation, it seemed pretty easy to exceed the rear axle spec before I’d come close to exceeding the front axle spec. Everyone’s towing situation is different but for me it seems like I have to be pretty careful as to what I put in the bed when towing or I approach that rear axle spec.
    AZBoatHauler likes this.
  12. Apr 9, 2024 at 5:50 PM
    AZBoatHauler
    So.Arizona
    I didn’t realize they lowered the rear axle rating on the 3rd gen. Funny how they slash that but increased tow rating.
