Newb here, 4.7 V8 vs 5.7 V8
Discussion in '2nd Gen Tundras (2007-2013)' started by Aron9000, Apr 22, 2018.
  1. Aug 19, 2018 at 12:12 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA
  2. Aug 19, 2018 at 12:32 PM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    1st Gen Tundras are pretty close in size to the current Tacomas. That's why the power felt nice. I have the 4.7 in a 4Runner and I like it. Glad I have the 5.7 in my Tundra though
  3. Oct 4, 2018 at 8:00 PM
    COToyo
    COToyo New Member
    Hunter
    2007 tundra 4.heaven
    I just got a 2007 4.7 and I'm plenty happy with it. Hauls a lot more ass than my 97 4runner. If you don't need tons of power then get it and rock it. Just my input.
  4. Apr 3, 2024 at 9:45 PM
    fastace
    fastace New Member
    Does the 4.7 have the same cam tower leak as the 5.7? It seems like nearly ever old 5.7 Tundra I've looked at has a cam tower leak. A Toyota tech said ALL 5.7's will get the Cam tower leak eventually, a 4k fix!!
    I have yet to see a 4.7 with a cam tower leak, how common is this leak in the 4.7? The million mile Tundra had a 4.7, more reliable?
  5. Apr 4, 2024 at 1:17 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    No, it’s a totally different engine. You have to watch for cam seals behind timing cover, but just make sure they are changed with the timing belt job along with front main.
  6. Apr 4, 2024 at 1:54 AM
    fastace
    fastace New Member
    Does the 4.7 can also get a leak like the 5.7? Sorry, I'm new to Tundras. There is a RCSB with a 4.7 4x4 with a little over 100k that I have an opportunity to buy but I really had my heart set on a RCSB 5.7 4x4 but clean ones are pretty rare and I worry about having to deal with the eventual expensive cam tower leak. Honestly, I don't need the extra power of the 5.7 and if the 4.7 is more reliable than the 5.7 that might sway me into getting the truck. I know the 5.7 is pretty reliable too, I often see many with well over 200k+ miles. However, the 4.7 has the timing bet to replace every 90k for 1k from a shop and the starter is a pita to replace. Either way, both engines can be expensive to maintain. I won't be using the truck much, doubt if I even put on 5k miles a year.
    Would you just wait for a clean RCSB 5.7 4x4 or get a clean RCSB 4.7 4x4 that is available now? I'm conflicted because the 4.7 has the color and configuration I want. However the 5.7 is more sought after and has better resale appeal and value. I'm almost ready to give up on getting a RCSB 5.7 4x4 and just get a more readily available clean double cab 5.7 4x4. I spent about $500 or more on pre-purchase inspections on trucks that needs thousands in repairs. O'm about ready to raise the white flag. lol The one great RCSB 4x4 5.7 I found a while back was sold out from underneath me and I'm still upset about that.
    831Tun likes this.
  7. Apr 4, 2024 at 2:23 AM
    MEWaters
    MEWaters New Member
    Maine
    Won’t get cam tower leak on 4.7, but have timing belt maintenance and should get cam seals done at those intervals as those can seep.
    They’re both reliable. There are some who have needed to do timing chain maintenance on the 5.7, cam tower job done. Most run the seeping towers with no worries, just address if under warranty or starts dripping on heat shield.
    RCSB tells me you probably won’t need the 5.7 power, but might enjoy it. I have a 4.7 and am content. You’ll read about resale value, power, etc. At the end of the day you have to look at it and drive everyday so get what you want and be happy. Just check service history on my Toyota adding the vin to your vehicles and make sure it’s clean. 5k driving a year you won’t touch the belt or pump on the 4.7 for 9 years lol. If you plan on selling before then maybe go for resale option but really it’s a toss up then. The 2UZ has been a long tested engine and may be highly sought after down the road..
    Had an 02 4.7 w 324k not a drop of oil or burning between changes. Have an 07 4.7 and have cam seals seeping at 210k because they weren’t replaced at any of the timing belt intervals (by Toyota dealerships)
    fastace and Terndrerrr like this.
  8. Apr 4, 2024 at 11:29 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    An RCSB 4x is not a very common configuration. Since it's a Toyota with only 100k I wouldn't be overly concerned about potential problems.....as long as it's not beat. You could wait for a 5.7 version and you're likely to spend a lot of time searching and possibly wait a looong time before you find one.
  9. Apr 4, 2024 at 11:58 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Not all 5.7 engines have the cam tower leak. There seemed to be a run of them where the sealant between the cam tower and cylinder head was inadequate, not sure which years or how many. They seemed to have fixed it in their engine assembly plant, my 2018 Tundra and wife's 2017 Sequoia are spotlessly clean. Even if there is a leak it is only an annoyance, regular cleaning with brake cleaner will prevent dripping on the heat shield causing smoke and smell. I have attached two pdf documents that detail the design of the 5.7 V-8. I wish I had same for the 4.7 (having owned a 2006/4.7 for 12 years).
  10. Apr 4, 2024 at 12:33 PM
    fastace
    fastace New Member
    I just had the dealership take it to a 3rd party mechanic close by and the mechanic just did visual check and told me the tailgate is rusted, covered up rust spots, covered up damage, etc. I got lucky and didn't;t have to pay him anything. I've had several RCSB and DBLCB 4x4 trucks inspected and all were either rusted out or needed thousands in repairs. I'm not in a rush for a truck and don't need one it is just for a fun project overland build, so I'll wait until the right truck comes. If anyone on this forum has a RCSB 4x4 for sale let me know.
  11. Apr 4, 2024 at 12:37 PM
    fastace
    fastace New Member
    Thanks for the info. I just went by what a Toyota master tech told me, who works on them everyday. He said the torque on these trucks are so strong that it contributes to the problem. He said all of the 5.7 tricks will eventually develop a cam tower leak, some sooner or later. I'm the type my vehicle has to be 100% perfect running, like my 05 Lexus RX330 AWD that has been flawless and still drives like new at 102k miles.
  12. Apr 4, 2024 at 12:40 PM
    fastace
    fastace New Member
    Thanks for all the info! That 4.7 4x4 RCSB I was looking at had hidden image and rust, dealership tried to cover it up. The dealership has bad reviews on Google, I should have went by the reviews and avoided this dealer. He picked it up ant an auction so you know its a crapper. Carfax shows one owner but 2 accidents, oddly, Autocheck shows no accidents which the salesman proudly displayed.
  13. Apr 4, 2024 at 12:47 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    I loved my 1st Gen w/4.7 and it did it's job adequately... towed my trailer for 6 years, never needed anything more than regular maintenance.
    That being said, get the 5.7
    4.7 - 245 HP/315 TQ
    5.7 - 381 HP/401 TQ
    More gears, bigger brakes, GOBS more power.
    07 Tundie, CaptRussia253 and fastace like this.
  14. Apr 4, 2024 at 4:27 PM
    MEWaters
    MEWaters New Member
    Maine
    The Specs you posted aren’t accurate for the 2nd gen, albeit they’re not considerably higher they are better than the 1st gen 2UZ
  15. Apr 4, 2024 at 10:23 PM
    fastace
    fastace New Member
  16. Apr 5, 2024 at 8:02 AM
    SD Surfer
    Bruce
    So Cal
    Hmmm, I'll be darned... I was just going off of the ones I've owned.
    I was not aware that they'd bumped up the power on later 4.7's... to a whopping 271! :burnrubber::rolleyes:
    What was the difference? Did the early ones not have variable valve timing I wonder?
    2000 Tundra SR5 4WD 4.7L V8
    Engine
    Base engine size
    4.7 L
    Cylinders V8
    Base engine type Gas
    Horsepower 245 hp @ 4,800 rpm
    Torque 315 lb-ft @ 3,400 rpm
    2007 SR5 Tundra 4WD 4.7L V8
    Base engine size 4.7 L
    Cylinders V8
    Horsepower 271 hp @ 5,400 rpm
    Torque 313 lb-ft @ 3,400 rpm
    Valves 32
    Cam type Double overhead cam (DOHC)
    Valve timing Variable
    2019 Tundra SR5 4WD 5.7L V8
    Engine
    Base engine size
    5.7 L
    Cylinders V8
    Horsepower 381 hp @ 5,600 rpm
    Torque 401 lb-ft @ 3,600 rpm
    Valves 32
    That being said OP, my answer is the same... given the choice and all else being equal, get the 5.7:muscleflexing::benchpress::militarypress:
    CaptRussia253 likes this.
  17. Apr 5, 2024 at 8:20 AM
    MEWaters
    MEWaters New Member
    Maine
    You can be snarky and condescending all you want. I simply told you your numbers were wrong and admitted they weren’t significantly better but still more HP. I’m sure a considerable number of tundra owners would get by with the 4.7, they just prefer a different displacement
  18. Apr 5, 2024 at 8:28 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 1997 FZJ80, 2003 Tacoma SR5 V6 5Spd
    Yea earlier 4.7's had no VVTi.
    If one just wanted a truck to haul lighter loads in the bed or overland, I'd not rule out the 4.7
    The 4.7 may very well be the best Toyota/Lexus engine ever made. And timing belt engines get way too much undue hatred. God forbid you need $500 of maintenance every decade to keep your engine running. Also provides the ideal opportunity to routinely replace a water pump rather than wait for it to fail.
    That being said the 5.7 is a beauty of an engine too, and the obvious choice of towing will be part of the trucks use
  19. Apr 5, 2024 at 8:39 AM
    SD Surfer
    Bruce
    So Cal
    Wow, simmer down buddy. :boink:
    If there was any snarkyness it was directed at Toyota for the somewhat anemic output of my '00 V8 not you.
    I acknowledged that the information I stated was incomplete. (Not exactly wrong, but incomplete)
    I also said that "I loved my 1st Gen w/4.7 and it did it's job adequately... towed my trailer for 6 years, never needed anything more than regular maintenance."
    So we were pretty much in agreement, since I'm one of those Tundra owners you mentioned that "got by with the 4.7" for years.
    Terndrerrr and 831Tun like this.
  20. Apr 5, 2024 at 10:42 AM
    #50
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Shame on you for having a sense of humor and employing lighthearted banter.:cheers:
    SD Surfer[QUOTED] likes this.
  21. Apr 5, 2024 at 10:49 AM
    #51
    SD Surfer
    Bruce
    So Cal
    It's amazing how often that seems to piss people off. :rolleyes::dancingbacon: Particularly on the Interwebz.
    831Tun[QUOTED] likes this.
  22. Apr 5, 2024 at 11:43 AM
    #52
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Redoak, Canman and SD Surfer[QUOTED] like this.
  23. Apr 5, 2024 at 12:02 PM
    #53
    SD Surfer
    Bruce
    So Cal
    HA!! I'm rolling... that totally reminded me of a text I very nearly sent my best friend.
    Years ago, I had just put a new Pioneer head unit with Android Auto in my 1st gen, and was marveling at the ability to hear and reply to texts while driving.
    I was going surfing with the boys one morning and my friend texted me for the ETA to meet at the surf spot.
    He said he was running late, I was replying with speech to text, and said "No sweat, I'm just getting on the freeway, I'll see you there."
    Just then, someone totally cut me off and (as I often do while driving alone) I berated the idiot in the other car who can't even hear me.
    I was just about to say "send" as the voice function lets you verbally hit the button.
    Fortunately it also lets you review the message first, 'cuz I very nearly sent my best friend a text saying "No sweat, I'm just getting on the freeway, I'll see you there... You STUPID FUCKING ASSHOLE!!" :rofl::eek:
  24. Apr 5, 2024 at 2:49 PM
    #54
    Canman
    Canman New Member
    2007 Crewmax Limited
  25. Apr 5, 2024 at 3:23 PM
    #55
    fastace
    fastace New Member
    4.7 for the win! I knew it. He is a Toyota master tech with an extreme amount of knowledge and experience with everything Toyota and works on them daily. I believe him more than anybody on this forum. Just saying.
    Rph74 likes this.
  26. Apr 5, 2024 at 4:26 PM
    #56
    cdub61
    cdub61 New Member
    2007 Blue Tundra SR5 TRD 4.7L
    I have a 2007 DC 4x4 TRD off road with 4.7L. Towed a 6000 pound travel trailer from NC to FL and back. Plenty of power coming back up the mountain. It is so smooth I have to check to make sure I turned it off before I get out. You will not be disappointed.
    MEWaters, Canman and fastace like this.
  27. Apr 6, 2024 at 9:55 AM
    #57
    Bergmen
    Bergmen New Member
    Ukiah, California
    As I've stated in other posts I owned a 2006/4.7 Tundra for 12 years since new. Changed the timing belt twice, was not interested in doing it again. My 2018 5.7 is at about 85,000 miles, if it was a 4.7 I would be looking at a timing belt change pretty soon.
    The 5.7 is golden to me, no belt, hydraulic valve actuation system, etc. At 74 years old, I have done enough auto repairs since the late 60s that I'm through with them if I can help it. Normal fluid/filter changes are fine, all ICE vehicles require this.
    PolishedTRD likes this.
  28. Apr 6, 2024 at 10:09 AM
    #58
    Red&03Taco
    Red&03Taco YUT
    Jerad
    I get that totally. I just think that in the timing belt vs. timing chain debate folks usually just say timing belt means maintenance, and timing chain means no maintenance, and it's a bit more complicated than that.
    A timing belt isn't submerged in oil (or at least shouldn't be). A timing chain is. This timing chain area (timing chain cover specifically) then becomes a liability for an oil leak down the road.
    The notoriously bullet proof 4.0L V6 (1GR-FE) from the 4th/5th Gen 4runners, 2nd Gen Tacomas, FJ Cruisers, and very few early 2nd Gen Tundras, is known to often develop this problem. This typically is best remedied with an engine out disassembly, reseal, and reassembly. This is about 20-22 hours in labor, or in other words $4k in engine maintenance costs. You can pay a mechanic ($1k) to do a timing belt 4 times (1x per decade), and break even with your buddy with a 1GR after 40 years of ownership. Nobody mentions this. Ever. And 3ur-fe's (5.7l V8s) are succectible to this problem too
    See here: https://www.tundras.com/threads/timing-chain-cover-leak-looking-for-advice.140645/#post-3542004
    To be clear I'm not hating on timing chain motors, just clarifying that the debate ought to be more nuanced. I own an '03 Tacoma (5vz with a timing belt), and a '18 Tundra with the 5.7 (timing chain). I'd rather do a timing belt job than fix a timing cover leaks, any day of the week, but they're both rock solid motors and need very little maintenance overall
    MEWaters and Orions Dad like this.
  29. Apr 6, 2024 at 10:24 AM
    #59
    Bergmen
    Bergmen New Member
    Ukiah, California
    Yep, agree completely! I forgot to mention I owned a 1985 Supra for 250,000+ miles and it was a belt engine also. But this was an in-line, not a "V" so much simpler. Still was a bit annoyed by the belt replacement interval but I was much younger then and could lean over the front grill for this work a lot easier than my age today. BTW, the Supra was a FANTASTIC car, truly loved that vehicle!
    It's all good!
    Red&03Taco[QUOTED] likes this.
  30. Apr 6, 2024 at 4:48 PM
    #60
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    I have a 2007 4.7L that has 265k miles I have done the timing belt/ water pump 2x the first at 100k miles the belt and components were all in good shape still could have lasted a lot longer, the 2nd time at 230k miles same story. I don’t drive the truck very much any more only 50-100 miles a week. I agree I would rather deal with a timing belt. The only part I have had to replace was the alternator @220k miles which were mostly high way, starter is still going going strong
    fastace and Red&03Taco[QUOTED] like this.
