  1. Apr 4, 2024 at 11:54 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  2. Apr 4, 2024 at 12:21 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
  3. Apr 4, 2024 at 12:48 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    Thanks, I'll have to practice on my parts sequoia mirror a couple times before I try it out on the tundra.
  4. Apr 4, 2024 at 12:59 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    hell naw, the light of my life is an autistic crackhead. He caught a bird this morning. Ate it.
    BroHon[QUOTED] and bmf4069 like this.
  5. Apr 4, 2024 at 1:12 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    Got my bils put on today. Went with notch 2 on stock coils. Ended up with about .75” which was exactly what I needed to eliminate the rubbing of my tires. Couldn’t align it though because the steering rack bushings are shot. Also have a leaking steering shaft boot so I’ll replace those when I do the LBJs soon. Truck ride home without the alignment pretty damn straight couldn’t tell a difference from when I brought it in.
    Top pic is before bottom is after.
    Tlar25, Voss, NUDRAT and 9 others like this.
  6. Apr 4, 2024 at 1:23 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I've sprayed quite a bit of their "Restoration Shop" Urethane in both the single stage and BC/CC flavors. A Gallon will do your truck twice, with some leftover.
    I wouldn't wish spraying a whole car in lacquer on my worst enemy, there's a reason everyone went to catalyzed urethanes.
    The Black Mamba likes this.
  7. Apr 4, 2024 at 1:31 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Nah, i've got a bit more of a chalkboard paint plan. Something thick sprayed on light. J/k with the laquer, but 30 coats of black laquer looks good.
  8. Apr 4, 2024 at 1:39 PM
    JakeJake
    2000 Tundra AC 4X4
    @Mr.bee Check out TCP globals hot rod flatz line. A blind monkey could make flat paint look good!
    Mr.bee and BroHon like this.
  9. Apr 4, 2024 at 1:48 PM
    That's a great color. Still one of my favorites.
  10. Apr 4, 2024 at 5:49 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    House batteries are all wired up. Right now they are not going to be connected to the alternator. I have a NOCO onboard trickle charger that I’ll use to charge them with shore power. I installed a breaker that will also act as a kill switch so that when the inverter is not in use it can and will be turned off so as not to have live voltage running through the cables.
    Tlar25, Voss, flipoffartist and 7 others like this.
  11. Apr 4, 2024 at 6:08 PM
    KTM_AJ421
    AJ
    2006 SR5 DC 2WD 4.7
    I can’t believe how much it looks like a Tacoma in that picture. My ocd kicks in now because I had a shop put them in and I’m debating loosening the bottom shock bolt with the truck on the ground to center the bottom bushing but trying to make myself not do it.
    oscardog86 and FrenchToasty like this.
  12. Apr 4, 2024 at 8:09 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Drove mine yesterday to grab some materials at the local big blue box store. I noticed that although the replacement backup camera has a nice picture now, I didn't install the rubber spacers so the angle is now off and it's looking up higher than before. I can't see my trailer hitch no mo so I'm gonna have to take it apart to install the spacers to angle it back down some. Dammit.
    oscardog86 likes this.
  13. Apr 4, 2024 at 8:33 PM
    Provably worth doing
    shifty` and oscardog86 like this.
  14. Apr 4, 2024 at 9:13 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    1500w oughtta be able to run a coffee maker.
  15. Apr 4, 2024 at 9:32 PM
    Or you could just use an electric free French Press.
    Hummer and BroHon like this.
  16. Apr 4, 2024 at 9:44 PM
  17. Apr 4, 2024 at 9:47 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  18. Apr 4, 2024 at 10:22 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I just wanna see it run something.
    Jack McCarthy likes this.
  19. Apr 5, 2024 at 5:06 PM
    Chrisfrom1986
    Central CA
    06 AC SR5
    Went to the junkyard and picked up a double cab axle housing. Was planning on getting the whole assembly but someone had already removed the axles to take out the differential. Fab shop finished up the cat shield so I'll test fit that this weekend for modifications needed.
  20. Apr 5, 2024 at 5:13 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Are the spring pads at the right width?
  21. Apr 5, 2024 at 5:17 PM
    Chrisfrom1986
    Central CA
    06 AC SR5
    From what I read on another thread they are but I'll find out one way or another. Going to use it with the SOS kit and leave my stock one alone.
    455h0le_dachshund likes this.
  22. Apr 6, 2024 at 5:47 AM
    flipoffartist
    flipoffartist New Member
    Jeff
    03 Gold AC 4x4 4.7 SR5
    That's a nice awning you got there. Is it canvas? I've been looking into some hail protection.
  23. Apr 6, 2024 at 5:51 AM
    flipoffartist
    Jeff
    Got my 5100's installed. I decided to go with the 3rd position. Sure had a fun time with those top nuts on the rears. I didn't realize how shot my original shocks were until I drove on the bills. So nice.
    IMG_20240405_180654.jpg IMG_20240405_180643.jpg IMG_20240405_180646.jpg IMG_20240405_195027.jpg
    Voss, bmf4069, oscardog86 and 8 others like this.
  24. Apr 6, 2024 at 5:57 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Thanks i think its a pvc coated fabric. Some moisture gets through, and it holds some mildew, but it stops hail. Except when hail hits on top of a beam.
    Its perfect for keeping the driveway and truck cooler.
    bmf4069, FrenchToasty, BroHon and 5 others like this.
  25. Apr 6, 2024 at 7:42 AM
    taranovich92
    taranovich92 300K mile club
    New Smyrna Beach, FL
    2003 Tundra T3 Edition
    Airaid cold-air intake, Airaid throttle body spacer, JBA headers w/ cats, Northeastern stainless resonator, MBRP 3" res-back exhaust, Eibach struts & springs @ 3", Suspension Maxx extended front links, SPC upper control arms, OME rear shocks, Husky Spring heavy duty leafs, 2" block in the rear, TRD rear sway bar, 1.25" wheel spacers, Yokohama Geolander AT 285/70/17, Apple CarPlay, CB radio, Randy Ellis Design front bar, Hella 500 rally lights, Mini LED projector headlights, Trailrunner Customs fogs, SkidRow Offroad skid plate.
    Removed the stupid pull-out cupholders in the lower dash and installed my old Radioshack CB. Wired to a FireStik hood-mounted antenna.
    Voss, bmf4069, oscardog86 and 9 others like this.
  26. Apr 6, 2024 at 8:06 PM
    Chrisfrom1986
    Central CA
    06 AC SR5
    Got the cat shield mostly in place, some slight adjustment needed before it gets bolted up. Fab shop couldn't do a radius bend so I had to hit it with a bfh to get it somewhat shaped at the back. It'll mount on top of the trans cross member and on top of the sway bar. Should be much more secure and significantly cheaper than some of the pieces I've seen online.
    Tlar25, Voss, bmf4069 and 10 others like this.
  27. Apr 6, 2024 at 8:13 PM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    What hood bracket is that? Any chance the hole can be drilled out for a NMO mount?
  28. Apr 6, 2024 at 8:53 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Now you're Talkin' Smokey good buddy!
    https://www.youtube.com/watch?v=zAL1wPeCAVA
    taranovich92[QUOTED] and BroHon like this.
  29. Apr 7, 2024 at 3:01 PM
    A3FAED9F-CA4B-450F-8785-9DFF0E80C19B.jpg Sundaye vibz
    Tlar25, Voss, NUDRAT and 14 others like this.
  30. Apr 7, 2024 at 3:13 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Not so much did to, but with.
    About 7 loaded down bed full from my front trees. Casey and @a55hole_dachshund will notice
