Leveling Kit
Discussion in 'Suspension' started by Elkhunter330, Apr 4, 2024.
  1. Apr 4, 2024 at 9:56 AM
    Elkhunter330
    Elkhunter330 [OP] New Member
    2023 Lunar Rock
    Topper
    I would love to get bigger tires and am curious how many inches for those of you who have a 22-24 Tunda does that add to the overall height. My garage has me limited in the total height I can lift it? So leveling seems to be an option but not sure.
    Thanks
  2. Apr 4, 2024 at 10:13 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    Typically you'd raise the front 2" to totally level the truck from its stock form.
    https://exitoffroad.com/product/2-front-strut-spacer-kit-for-toyota-tundra-2022/
    Then the tires would add height too. Let's say you go from a 33" tire to a 35" tire, 2" more diameter adds 1" of lift (rough math).
    So check your garage height and make sure you have plenty of room before you make any changes. Sometimes bigger tires can be fit without adding lift too, as lift just takes away from down travel and changing the ride height. It doesn't increase the room in the fender wells unless you add a drop bracket lift kit (like a 4-6" Rough Country as an example).
  3. Apr 4, 2024 at 11:22 AM
    Elkhunter330
    2023 Lunar Rock
    Topper
    Thanks so much for the info!
  4. Apr 4, 2024 at 11:23 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    That username tho...
  5. Apr 4, 2024 at 11:28 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Markus and KNABORES like this.
  6. Apr 4, 2024 at 11:34 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    KNABORES likes this.
  7. Apr 4, 2024 at 11:59 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Expected more because of username.
    texasrho83 likes this.
  8. Apr 4, 2024 at 5:38 PM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    I went with the Rough Country 1.75 level kit on my 23 1794 with the TRD package. Sits 1/2" higher is the rear still. Good looking stance
