chirping sound
Discussion in 'General Tundra Discussion' started by so_melo149, Apr 4, 2024.
  1. Apr 4, 2024 at 8:00 AM
    so_melo149
    so_melo149 [OP] New Member
    Los Angeles, CA
    2017 Tundra Crew-Max TRD off-road
    1.75” Rough Country Leveling Kit 275/70/18 GoodYear DuraTrac AT Honey Comb Grill
    what’s up fellas
    got some chirping/ squealing sound on my ‘17 SR5
    quick back story: it started making a chirping sound at cold start but would go away after warming up.
    its been 50k miles since my last spark plug service so i decided to replace them, while i was at it i used some MAF cleaner to clean out the MAF sensor, and throttle body cleaner to clean the throttle body.
    after doing the spark plugs, cleaning the throttle body and MAF sensor i start the truck up and the chirping/ squealing is there, louder and now it’s not going away after warming up
    any help, ideas is appreciated
  2. Apr 4, 2024 at 8:02 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Serpentine belt is old and stretched out probably. Easy and cheap fix.
    so_melo149[OP] likes this.
  3. Apr 4, 2024 at 8:05 AM
    so_melo149
    Los Angeles, CA
    thanks
    i’m at 172k miles on the original serpentine belt, should i swap the idle pulley and or tensioner?
  4. Apr 4, 2024 at 8:28 AM
    so_melo149
    Los Angeles, CA
    UPDATE: the chirping has now gone away after driving for 30 minutes
