2007 Toyota tundra transmission connector
Discussion in 'New Member Introductions' started by Antoniocruz38, Apr 3, 2024.
  1. Apr 3, 2024 at 8:21 AM
    Antoniocruz38
    Antoniocruz38 [OP] New Member
    Jose a Martinez Cruz
    2007 Toyota tundra silver
    Hello everyone I looking for some help a mechanic replaced the engine and dropped didn't unplug the the transmission wire harness the connector on the driver's side of the transmission has 15 pins but 4 wires are off of its placed
    Can anyone get a shot of your connector need to Kno where this guy's belong thanks
  2. Apr 3, 2024 at 12:39 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  3. Apr 3, 2024 at 2:37 PM
    Antoniocruz38
    Thanks for the response I did check this diagram but i don't know what color is each pin
  4. Apr 3, 2024 at 6:25 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    The wiring diagram pdf files also have all the connectors described and numbered, which should help you figure it out. There is a TON of info in those pdf's.
