Resolved: Power steering fluid leaking into bellows
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, Apr 2, 2024.
  1. Apr 2, 2024 at 1:29 PM
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Edit: resolved by replacing steering rack with a new one, not their rebuilt version, from Detroit Axle. It was 265 with shipping and taxes. The new one has a 10 year warranty. The rebuilt one had a lifetime warranty. Perfect option, you need to flush the power steering fluid and to replace the bushings with polyurethane bushings
    After all the suspension work, I did last year it now drives like new. I could not be more pleased. I didn't realize how my string had gotten. Probably the best $265 I've spent on this truck
    Orig Post:
    Replacing my bellows this afternoon and power steering fluid came out of the bellow. More than a drop or two - maybe an ounce or so. I had already noticed there seem to be some issues with the steering box / rack
    is this something that should be Toyota OEM or are there other good brand replacements?
    Jack McCarthy likes this.
  2. Apr 2, 2024 at 1:33 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Unless you want to do it again, I would go OEM. I think you can buy reman Toyota racks. I found one for my 5th Gen 4Runner anyway. Might be able to save a few bucks that way.
    Weagle[OP] likes this.
  3. Apr 2, 2024 at 1:35 PM
    Good question. I just drain mine, clean it out and zip tie it back. At some point it'll be too much of a nuisance and a new rack will be necessary.
  4. Apr 2, 2024 at 1:47 PM
    Weagle
    Prattville, AL
    Yeah, I think I can get by for right now but that'll be a project for the next month or two. Several of the seals seem to be getting weepy
  5. Apr 2, 2024 at 1:58 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    I went ahead and ordered mine for the 4R, because the remans go out of stock quickly. If you find one, I would suggest ordering it. It's also here for when the rack totally shits the bed. But, I'm definitely not in any hurry. It's a real PITA to change on the 4R. Not so bad on the Tundra.
    Weagle[QUOTED][OP] likes this.
  6. Apr 2, 2024 at 2:39 PM
    bfunke
    bfunke Tundra Curmudgeon
    There’s an episode of All Girls Garage where they rebuild a tundra rack using only routine mechanics tools. Might want to try that.
    Jack McCarthy and Weagle[OP] like this.
  7. Apr 2, 2024 at 3:11 PM
    Weagle
    Prattville, AL
    yeah, this is the best price I've seen from a Toyota dealership for OEM. I'm still looking for remanufactured. But this price will certainly make you think about it.
  8. Apr 2, 2024 at 3:13 PM
    I’d be interested in that. First time I looked into it years back, Toyota only made a passenger side seal for the rack to replace and not the driver’s side.
  9. Apr 4, 2024 at 6:17 AM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    Before replacing the rack try flushing the fluid replacing some of the power steering fluid with a product called AT 205 which is a liquid polymer that rejuvenates seals. Approximately 1.5oz per quart
  10. Apr 8, 2024 at 8:10 AM
    Weagle
    Prattville, AL
    Thanks. I just decided to get a remanufactured rack. At 18 years of age and 308,000 miles the bushings were looking suspect too. since I am restoring the truck I just thought I would get it back in tiptop shape. New inner tie rod ends, etc.
    I'm on a journey to replace all seals and bushings anyway. Just recently replaced outer TRE's and LBJ's, sway bar links etc
    thanks for the info on that product. That might come in handy in the future
    shifty` likes this.
  11. Apr 8, 2024 at 11:56 AM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    The bushings that come included with the aftermarket racks can be a bit dubious. I’d swap in an Energy Suspension poly bushing kit. They aren’t very expensive whatsoever.
  12. Apr 8, 2024 at 12:18 PM
    Weagle
    Prattville, AL
    Wish I would've read this earlier. I just ordered ones from total chaos. They are also poly but about $10 more than the energy suspension ones
  13. Apr 8, 2024 at 3:32 PM
    Orions Dad
    2007 Tundra 4.7L
    The only thing AT 205 can’t be used for is brakes and you can use a spray bottle and apply to the outside
  14. Apr 23, 2024 at 7:17 AM
    Weagle
    Prattville, AL
    After receiving my"remanufactured toyota" steering rack with a China sticker on it, i've about decided to order the brand new OEM complete rack I posted above.
    Am I letting my OCD and perfectionistic tendencies get the best of me?
    I believe you can get the seals and rebuild it. But since the new OEM rack includes the inner TRE's and bellows and the steering gear is brand new I thought it would be worth it.
    my concerns with rebuilding are the tendency for the casing to weaken and rust-out under the bushing due to the air conditioning condensation discharge dripping directly on the steering rack.
    Does the internal gear wear overtime? It's not like it's a wheel bearing in that it doesn't have constant gear on gear movement.
    18 years old 309,000 Miles. I'm trying to do a bumper-to-bumper refresh/rebuild over time and would like for it to be in tiptop shape, proactively refreshing, rebuilding, replacing before a failure
    i've already done the lower ball joints, coils, shocks, outer tre's, sway bar links and power steering pump.
    I believe I've still got to do the control arm bushings, upper ball joints, and swaybar bushings but I am otherwise getting reasonably close on the front steering and suspension
  15. Apr 23, 2024 at 7:23 AM
    Yes, probably.
    Possibly? Someone had one for sale recently in the marketplace here, I strongly considered snatching that one up.
    All gears wear over time ...
  16. Apr 23, 2024 at 7:27 AM
    Weagle
    Prattville, AL
    OK, that fed the beast. Perfectionistic tendencies are probably going to win
  17. Apr 23, 2024 at 1:14 PM
    Weagle
    Prattville, AL
    I also ordered a steering shaft seal since I will have to take off the steering shaft coupler to replace the steering rack
    Is there anything else while I'm in there related to the steering shaft?
  18. Apr 23, 2024 at 1:27 PM
    I've had this for 2 years now. Works fine and took a lot of abuse in AZ twice.
  19. Apr 23, 2024 at 1:28 PM
    Weagle
    Prattville, AL
    Didn't I read somewhere that you had a lot of trouble replacing it? If so, any advice?
  20. Apr 23, 2024 at 1:34 PM
    It's just kind of a pain getting the sway bar off. The top nut in the center of the rack doesn't help. Plus, mine was leaking for years. It was a mess under there. I'd recommend a second set of hands for sure.
    Oh, plus we were kinda drunk.
  21. Apr 23, 2024 at 1:40 PM
    Weagle
    Prattville, AL
    :cheers:
    I'm wondering if mine is different since yours is an O2 4WD and mine is an 06 2WD because in the video I watched, they did not have to remove the swaybar. If so, I'll count myself very lucky
    I looked at this site before, but didn't know about their reputation
    when I just looked again, they have two options. One appears to be a rebuilt unit because you get a lifetime warranty when you return your core. The other is a brand new unit with a 10 year warranty.
    Did they have those options for you and if so, which one did you pick?
    Did you flush your power steering fluid while you were at it? Seems like that would be pretty easy while replacing the rack
    And I guess I need to search the forum for a way to reroute that AC drain
  22. Apr 23, 2024 at 1:49 PM
    Could be a bit different for yours for the sway bar. They have 3 options for my year. I believe the top one is reman.
    I would absolutely, 100% feel confident going with this rack again if I had to.
  23. Apr 23, 2024 at 1:51 PM
    Weagle
    Prattville, AL
    They had that third option for mine as well. Actually, they had a fourth option with wheel Bearings outer TRE's and swaybar links, etc. But I've got Already replaced all of that
    Thanks for the input. I'm leaning very heavily this way now.
    Did you flush your power steering fluid while you were at it? I definitely need to do this.
  24. Apr 23, 2024 at 1:55 PM
    Didn't have too. It had been leaking so long I had to refill the res every few months. It was beautiful red fluid in there still.
  25. Jun 4, 2024 at 11:54 AM
    Weagle
    Prattville, AL
    @bmf4069
    Are there O-rings where the hard lines connect to the rack coming from the pump and back to the reservoir?
    Mine did not come with any and when contacted a local Toyota dealership they said they didn't believe it had any because they could not find them in the diagrams. They appeared to be similar to brake lines, where both connections are beveled, and O-rings are not used
    However, when I took it to get the alignment the shop replaced one of them because they said it was leaking. I just got back from a trip and I still see leaking coming from that area. I still got to get up there and check the source but it connected to the steering Rack
    The only O-rings we could find anywhere on the diagrams were where the pressure lines connect to the steering rack. Those come with the rack already assembled
  26. Jun 4, 2024 at 11:59 AM
    I had o rings
  27. Jun 4, 2024 at 12:06 PM
    Weagle
    Prattville, AL
    Thanks! That's what I suspected.
    and that's the source of the leak and that's why it is still leaking. Meaning the shop bought and charged me for a $200 fluid line that did not need to be replaced.
  28. Jun 4, 2024 at 12:07 PM
    The o rings are somewhere in some diagram, that’s how I ordered them
  29. Jun 4, 2024 at 12:10 PM
    Weagle
    Prattville, AL
    I'll keep looking. It is not on the diagram for the actual steering rack. That one only includes the parts including O-rings for the pressure lines. It does not show the power steering fluid lines to and from the steering rack. We looked at the one for that part at the dealership the other day, but did not see any on it as well, but I'll keep looking
  30. Jun 4, 2024 at 12:41 PM
    These guys?
