Rear Glass causes beep
Discussion in '3rd Gen Tundras (2022+)' started by 2023TSS, Apr 1, 2024.
  1. Apr 1, 2024 at 7:11 AM
    2023TSS
    2023TSS [OP] New Member
    Sheldon
    2023 Tundra SR5 TSS
    Bilstien 5100 leveled, 35” tires
    Please point me to the thread if this has already been discussed.
    I noticed when I roll my rear glass all the way up I hear a beep (like the lock/unlock beep) outside the truck but its a long constant beep. Is this normal and does anyone have any idea why it does this?
  2. Apr 1, 2024 at 9:56 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
  3. Apr 1, 2024 at 4:32 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    I think it just a reminder to make sure you didn't roll it up on you cat, dog, neighbors kids! Lol
    *I purposely didn't include the wife;) lol j/k.
    I do not think it's pressure sensitive!
    raylo likes this.
  4. Apr 1, 2024 at 4:34 PM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    I do not get the beep when the rear glass closes. But I do not get the beep / chirp either when I lock the doors with the fob..... still trying to figure that out.
  5. Apr 1, 2024 at 4:36 PM
    pwpblue
    Greensburg,PA
    I wonder if your speaker is unplugged?
    Under hood on driverside grey in color I think.
    Or is the volume turned down?
  6. Apr 1, 2024 at 4:37 PM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    Thanks. I will check it tomorrow. No, the volume is not turned down.... worked that adjustment and no improvement.
    pwpblue likes this.
  7. Apr 1, 2024 at 5:07 PM
    pwpblue
    Greensburg,PA
    I think this is it?
  8. Apr 1, 2024 at 7:04 PM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Happened to me today, first time I've noticed it anyway. Sitting in a drive thru. General concensus from the other threads is its to let you know its up. Seems like a very unnecessary long beep to me, but I'm no engineer
  9. Apr 1, 2024 at 7:32 PM
    Hella Krusty
    Hella Krusty New Member
    Rolled mine up today....zero beep!
    ChucklesToy likes this.
  10. Apr 2, 2024 at 5:14 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    Some beep, some don't beep. Interesting.
  11. Apr 2, 2024 at 6:40 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Happy member of the "no beep club." I do get a notification beep if a window(s) is open when the truck is off and I exit the vehicle.
    Tundrastruck91 and ChucklesToy like this.
  12. Apr 2, 2024 at 6:43 PM
    *D*
    *D* New Member
    Dimitri
    Rhode Island
    ‘24 DC Long Bed 4x4 SR5
    I don’t have the same window as you guys (I’m in an SR5, so it’s a power horizontal sliding window).
    I wonder if you all have your fobs programmed with the ability to roll down windows with a long press of the unlock button. If it beeps for some of you and not others, maybe the difference is in wether or not your trucks are set for that option.
    PGW85706 likes this.
  13. Apr 3, 2024 at 3:35 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    An astute observation. You may be on to something. Yes, I do have the feature customized to allow the windows to power down with a long hold on the fob unlock button and I do not get the beep. Not sure if I understand the connection, but it could exist.
    [Wish windows would power up with the fob!!]
  14. Apr 3, 2024 at 9:08 AM
    PNW Tundra Mike
    Back in So Cal
    My windows are not programmed and I have the beep. Thought maybe it was a signal that all windows are up for locking purposes. Nope. Rear window still beeps when other windows are open. Very odd. If it beeped on the way up I could see it as a safety signal for someone in the bed, but not til fully up.
  15. Apr 3, 2024 at 9:27 AM
    Markus
    Mark
    Boring, MO
    A few
    Tried it again this morning. Sure enough, it beeps every time. You can't hear it while driving or over a radio at all. It's probably done this the whole time, but you actually have to be stopped with the windows down to hear it. Not sure what the point of that would be haha
  16. Apr 3, 2024 at 10:23 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    That’s funny, all I’ve ever had is crewmaxes with that window. I just went out and checked my truck and sure enough it does beep when I close it. Only when the shifter is not in park. I have a ton of miles on my 22 and I use the window a ton, but never once heard the beep till now. My only guess is that it’s a reminder that the window is fully closed. It is hard to hear with the windows closed
    Markus likes this.
  17. Apr 3, 2024 at 11:29 AM
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    OK, I have the beep and confirmed it occurs in all shifter positions except P.
  18. Apr 3, 2024 at 2:24 PM
    pwpblue
    Greensburg,PA
    Mine does in P
  19. Jan 20, 2025 at 10:44 AM
    Warefare360
    Warefare360 New Member
    William
    2024 Tundra iforce max limited
    Mine is programmed to roll windows down with the key fob but the rear window is not included all windows and sunroof open but rear window does not. I have tested this beep many ways, if you are moving over 3 mph it won’t beep, if you have not moved at all yet after starting the car it doesn’t always beep, if you have driven at all and roll it up it will beep every time once it’s fully closed. I’ve asked Toyota service they have no idea why it does it, I’ve called Toyota advocate line had them look in to it and still no answer as to why it does it. I noticed it won’t do it if you have not driven yet when I took it to Toyota to show them as I turned off the truck when I got there and when I started it up to show the tech it wouldn’t do it, as soon as I drove to the exit of the parking lot it started doing it again. That seems to be consistent if you haven’t driven yet (on mine) it will not beep. It’s very odd especially given the beep is on the outside of the vehicle you would think it would be inside if it was to warn anyone in the car of any situation. I have seen some posted online saying they determined it was an electrical fault and the beep is meant to warn of an obstruction or failure of the window closing completely and correctly however I have not been able to verify that with Toyota.
  20. Aug 14, 2025 at 2:17 PM
    GeoNeo
    GeoNeo New Member
    Geo
    2022 Tundra
    Definitely a weird thing. Happened to me a couple times and happened today in traffic so figured I’d look it up to be sure. I was definitely in “Drive” at a stop light. I always assumed it was to let you know it’s shut as it doesn’t beep until it’s fully closed but…only when not moving? Just weird. Typical confusing half assed “New Toyota” lack of communication and clarity.
