  1. Mar 31, 2024 at 7:04 PM
    265/65r17 is OEM. You've added 1" diameter by going with 265/70r17. Which is fine, it's a great upgrade for people only looking to lift ~1", it'll look awesome once you get the lift in. Other than being a little more rigid because E-rated tire.
  2. Mar 31, 2024 at 7:26 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    luckily I made sure these Mickey Thompson are SL rated. Hoping the 2nd notch will give the .75” lift and then a little trimming will get it clear. Do you think I’ll pick up any of the sagging from the old shocks that were on there?
    455h0le_dachshund likes this.
  3. Mar 31, 2024 at 7:32 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    For sure
  4. Apr 1, 2024 at 3:52 AM
    What is the total diameter of both tires? My KO2's were 32.8".
  5. Apr 1, 2024 at 4:55 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Trans is back in. Next step is balance the gold starfish, fluids and testing. Fingers crossed today, as long as the work schedule allows.
    Voss, bmf4069, flipoffartist and 5 others like this.
  6. Apr 1, 2024 at 4:57 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Man she's going to purring like a leopard in no time. Fucking 5vz bro :thumbsup::bowdown:
  7. Apr 1, 2024 at 7:13 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Simple, effective, clutter free.
    Voss, Tundra2, flipoffartist and 9 others like this.
  8. Apr 1, 2024 at 7:54 AM
    That depends. Heavily.
    If you look purely at a tire calculator, it will tell you my MT Legend EXP at 275/70r17 are 32.2" diameter. based purely on the size, ignoring tread. But I had a hard time believing it, they're so f'n knobby and aggressive, I knew the actual diameter had to be ¼"-½" bigger.
    Tiresize has actuals on everything. . . As you'll see, there's only 0.2" (I assume you got E-rated) or possibly 0.3" difference (if you went C-rated) in overall diameter on our two tires. Tread matters. And I'd argue my Mickeys are more horizontally-aggressive than your KO2s.
    And if you went C-rated, I bet your ride feels waaaaay smoother than mine. :rofl:
  9. Apr 1, 2024 at 7:59 AM
    And for the record, same story with @KTM_AJ421, his are oversized about 1/3", I guess that's the Mickey M.O. He said he went non-E-rated (smart man, if he's not planning to offroad and needs more comfy paved miles) so this is his tire; he should be a 31.6 based on calculators. He's just shy of a 32":
    KTM_AJ421 likes this.
  10. Apr 1, 2024 at 9:14 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    My DC truck came with some generic 265/70r17's that measure 31.6" and they don't get close to rubbing anywhere.
    This weekend I tackled leaking power steering fluid. The first thing I did was remove the reservoir and cleaned it. The inside of the reservoir was so gunked up I couldn't see the fluid level from the outside. I used a few different chemicals to try and clean the tank, but the only one that made any progress was Maxima CleanUp Chain Cleaner that I usually use to clean grime off of my WR250R's o-ring chain. Once cleaned and dried I installed the reservoir along with a new fit suction hose and a trimmed to fit return hose with new hose clamps. The reservoir is still stained so my fresh Dex/Merc ATF looks dark. At least I can see the level!
    I thought the vacuum switch was leaking as well, so I replaced it with a plug. The truck also experienced some smoky start ups and I wanted to verify if this vacuum switch was the culprit or not.
    And since I could order Toyota wiper blades from overseas for what Tricos cost at the parts store, I have new Toyota wiper blades on the truck.
  11. Apr 1, 2024 at 9:34 AM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Not a lot of extra cash at the moment so I’m finding some small stuff to do to the truck for now. On Saturday I did the Griot’s headlight restoration kit. Mostly was just trying to get the yellow out of the headlights - they weren’t too foggy yet. I think it turned out good. Now I gotta figure out what the deal is with the condensation inside the driver side blinker.
    Voss, ToyotaDude, bmf4069 and 8 others like this.
  12. Apr 1, 2024 at 9:41 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Drill a small hole in the bottom of the assembly and give it a day. It'll clear up
    oscardog86 likes this.
  13. Apr 1, 2024 at 11:12 AM
    Out with the factory spare, in with the new-used proper upsized flavor. Almost look the same size 265/65r17 vs. 275/70r17 at half tread. Also some frame inspection action, and a grease wipe down on the frame is coming, posting this before hands get nasty….
  14. Apr 1, 2024 at 11:50 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Pulled my grandparents boat Friday to get it cleaned up and running again to get it sold.
    Needs a few things but really just dusty and dirty after sitting indoors for a bit. Ordered a few parts. Anyone got outboard 2 stroke experience? Hoping after replacing rock hard fuel line, a leaking primer bulb and this fuel primer/choke solenoid (pictured below) that it'll run decent again.
    If anyone that's localish is looking for a boat hit a guy up. I'm not gonna make up a formal post but it'd be cool to see it go to someone here once I'm done getting it squared away.
    Truck pulled it well, as it has for everything I've had to pull with it. Wouldn't mind a few more HP but does the job for the 4 or 5 times a month I pull a trailer.
    Voss, NUDRAT, ToyotaDude and 6 others like this.
  15. Apr 1, 2024 at 11:57 AM
    I'll give you five hunned!
  16. Apr 1, 2024 at 1:34 PM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Summer wheels on, slightly cooler jalopy :cool::rofl:
    They are all pretty good shape except the rear in the picture... gnarly chunk mussing.... send it!
    Voss, bmf4069, JasonC. and 4 others like this.
  17. Apr 1, 2024 at 2:24 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Then reseal it once it’s all dry in there? Or leave it open?
    BroHon likes this.
  18. Apr 1, 2024 at 2:32 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I just checked my old corners and the oem's have 2x vents on the back. I would try removing the grey rubber vent caps for a day or two before I started poking holes. The vents themselves have some sort of foam/mesh material the may be blocked.
  19. Apr 1, 2024 at 2:50 PM
    The Black Mamba
    DFW
    Imma keep it stock
    Just leave the hole. Small hole. In the base at the bottom. Drill it and forget it.
    TXTundraGuy23[QUOTED] likes this.
  20. Apr 1, 2024 at 2:59 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    Somebody posted a picture of a Bluetooth adaptor for the oem stereo recently but I wasn't able to find it with search or reading the last 5 pages or so. Anybody know what I'm talking about?
  21. Apr 1, 2024 at 3:04 PM
    JakeJake
    2000 Tundra AC 4X4
  22. Apr 1, 2024 at 3:22 PM
    Here's another option quite a few people are using successfully for both handsfree and bluetooth audio: https://www.gtacarkits.com/product/toyota-tundra-2003-2006-iphone-aux-kit/
    JakeJake likes this.
  23. Apr 1, 2024 at 3:39 PM
    flipoffartist
    flipoffartist New Member
    Jeff
    03 Gold AC 4x4 4.7 SR5
    I got the old timing belt off. Im 95% sure it's the original. Looks and feels pretty solid for 129k. The only item that looked bad was this pulley.
  24. Apr 1, 2024 at 5:25 PM
    Chrisfrom1986
    Central CA
    06 AC SR5
  25. Apr 1, 2024 at 5:34 PM
    I dunno I looked up all of those numbers, and none came back to a Toyota/Aisin/Mitsuboshi part.
    2915122329
    2915123329
    2915124329
    2915125329
    2915126329
    2915127329
    2915128329​
  26. Apr 1, 2024 at 7:28 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 52k mi
    Ooh that would also help shade my POS highly reflective touchscreen stereo. And plus since mine is woodgrain it’ll probably hold screws way better than your cheap plastic one. ;)
  27. Apr 1, 2024 at 7:42 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Do it! I honestly was sick of the 3M failing for magnetic mounts. Don’t think it’s strong enough to hold my 12.9 iPad Pro, but it’s a sacrifice I’ll make since I’ve got CarPlay these days lol.
  28. Apr 2, 2024 at 2:08 AM
    flipoffartist
    Jeff
    Wow you're very thorough! You can't see it in the photo, but it definitely says Mitsuboshi on the other side of the belt.
    shifty`[QUOTED] likes this.
  29. Apr 2, 2024 at 4:57 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Burping the system and preparing for a test drive. Here’s just enough of the gold rim for you not to be able to see it :p
    Voss, TX-TRD1stGEN, khooiii and 6 others like this.
  30. Apr 2, 2024 at 5:02 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Ya bastard :rofl:
