32 gallon tank swap COMPLETED!
Discussion in '3rd Gen Tundras (2022+)' started by cccasti3, Mar 30, 2024.
  1. Mar 30, 2024 at 6:29 AM
    cccasti3
    cccasti3 [OP] New Member
    Ok guys not sure if anyone else has actually done the swap yet but I couldn’t find anything so I just went for it. Found a complete 32 gallon with everything included ( pump, lines , level sender etc). Dropped the old tank and everything plugged right up correctly. Used some blocks on one end and a floor jack on the other and was able to get it up in there by myself. The larger tank has three straps and the smaller only has two. While trying to put the straps back in the original location on the truck I realized you have to move the middle strap to the forward location (not used on the 22 gallon but it is there in the frame) and it will work with the new tank. Then just order the correct middle strap from one of the online Toyota shops. Other than that everything worked as it should. The only caveat I have found is the DTE or distance till empty shows I’ll only have about 260 miles when I fill up however on my last tank I reset the trip computer and went 360 miles. Going off of the fuel level meter everything is correct filled up on the E Line and it took 26 gallons so I appear to have that 6 gallon reserve everyone else with the 32 gallon tanks are reporting. Just thought I would post as I know there are a lot of people with the 22 gallon tank that tow things and really want to upgrade. This is confirmation everything works but you may have to ignore the trip computer and just go off of the fuel gauge. For me this was acceptable but may not be for you. FWIW I talked to Toyota to see if they could flash the computer or something but they said no.
    I’m a SR5 getting 13mpg 4” lift with 35’s on 22’s. My MPG hasn’t changed since upgrading the tank so maybe there is still a chance that the trip computer will continue to adjust upwards and relearn? I will report back to keep you all posted.
    Big_Turp, when96, j-utah and 17 others like this.
  2. Mar 30, 2024 at 8:46 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    Computer probably has to go through fuel tank to calibrate. 360 miles range sounds about right if you're getting 13 mpg.
    4lo Toys likes this.
  3. Mar 30, 2024 at 8:49 AM
    TheBeast
    TheBeast The Beach
    13 mpg on a 22 ? I get about the same mpg with my old V8 / similar lift and tires. Do you tow a lot ?
  4. Mar 30, 2024 at 9:11 AM
    Markysharky
    Markysharky New Member
    Pictures of the tank, assuming it’s just a fuel pump wire harness connector and the straps and fuel fitting quick connect? Have a 2023 SR this fuel range is poor especially when towing?
  5. Mar 30, 2024 at 10:11 AM
    cccasti3
    Yes 13. I have not recalibrated for the tire size so my speed is off by about 5mph at 60mph.
  6. Mar 30, 2024 at 10:12 AM
    cccasti3
    yes all
    Of the fittings for the wiring and the quick connect for the fuel hose connected right up with no changes necessary.
  7. Mar 30, 2024 at 12:34 PM
    cccasti3
    Found it on eBay for 250$price was right so I decided to go ahead and be the guinea pig lol
  8. Mar 30, 2024 at 2:24 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Haha I knew you would be in on this thread
  9. Mar 31, 2024 at 8:53 AM
    brutalitybob
    brutalitybob New Member
    Can you provide the OEM part numbers for the straps and any other part numbers that may help us out? For any of us looking to do this in the future, im hunting around for a tank online but no luck
  10. Mar 31, 2024 at 9:34 AM
    cccasti3
  11. Mar 31, 2024 at 9:43 AM
    cccasti3
    Part number of the tank is in the picture I posted. I don’t have the part number for the middle strap yet, running it with just the front and back now but I have an appointment at Toyota next week and will post the part number then… that’s it nothing else needed
  12. Mar 31, 2024 at 1:50 PM
    brutalitybob
    Thanks man also your likely going to need 2 new bolts for the additional strap if you can capture that number while your there!
    Oolypoolay likes this.
  13. Apr 1, 2024 at 4:42 AM
    wauto
    wauto New Member
    mike
    LKQ-Keystone of Utah has four of them listed.
  14. Apr 1, 2024 at 7:01 AM
    brutalitybob
    you have a link?
  15. Apr 1, 2024 at 11:20 AM
    wauto
    wauto New Member
    mike
    Try this...
    2023
    Fuel Tank Assembly
    Toyota Tundra SR5,3.4,4X4 GASOLINE, ID 77001-0C160 000 A
    0 TY00404 $452
    undmg LKQ-Keystone-Utah USA-UT(Salt-Lake City) Request_Quote 801-489-9373
  16. May 31, 2024 at 9:07 PM
    paravane
    paravane New Member
    c
    I know I'm necro-ing this up a bit. But I'm looking at doing this mod myself. Here's the chart with all the part numbers.
    Raven67 and Woocawachie like this.
  17. Jun 5, 2024 at 5:26 AM
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    Did the fuel gauge ever re calibrate? Or still shows empty while there’s plenty of fuel left ?
  18. Jun 5, 2024 at 9:15 AM
    paravane
    paravane New Member
    c
    @cccasti3 any update on if it re-calibrated? That's my only reservation with this mod.
  19. Jun 5, 2024 at 11:08 AM
    paravane
    paravane New Member
    c
    Actually doing the math on his MPG 13 MPG with a 6 gallon reserve is accurate so it seems like it re-calibrated correctly.
    I just ordered me one on eBay for about $600 after tax for the full assembly.
  20. Jun 5, 2024 at 12:12 PM
    rwsessions
    rwsessions New Member
    2023 Silver SR5
    Was that shipped? I've been looking for one and the only options I've found have been for local pickup only in MS.
  21. Jun 5, 2024 at 12:31 PM
    paravane
    paravane New Member
    c
    Lol I bought one of the ones from that scrapper. It's local pickup in MS. But it's only 6 hours one way for me.
    I'll take a vacation day at work. Take the RAV4 Hybrid and be out a tank of gas. But $600 plus gas vs $1300 from Toyota. I'll take it.
    DogRunner2 likes this.
  22. Jun 6, 2024 at 4:17 AM
    paravane
    paravane New Member
    c
    Talked to the boss about taking a day off to go there and he informed me we have business there so I'm getting paid to go pick it up now. :)
    22whatwedo, rwsessions and MoPops like this.
  23. Jun 6, 2024 at 4:28 AM
    MoPops
    MoPops New Member
    Jeff
    2012 Dbl cab, 4x4, 2023 SR5 TRD 4x4 Dbl cab
    Bilsteins all around, RAS, E tires.. All on the 2012
    I need to look into this. I’ll have to do some searching on eBay. good post.
  24. Jun 6, 2024 at 5:31 AM
    rwsessions
    2023 Silver SR5
    Oh that’s nice, and even nice you’re getting paid! Well done sir! For me it’s closer to like 10-11 hours :/, so the search continues…
  25. Jun 6, 2024 at 5:16 PM
    paravane
    paravane New Member
    c
    Without checking if I remember when I looked at the trims. Starts at the SR5 with TRDOR package and up.
    DogRunner2[QUOTED] likes this.
  26. Jun 6, 2024 at 5:23 PM
    paravane
    paravane New Member
    c
    I definitely re-read OP's post and I read it wrong. Sounds like the truck isn't recalibrating for DTE.
    Maybe if I find a tuner they can set it. Once it's installed I'll check with some dealers around me and see who would change it in the ECU.
    rwsessions likes this.
  27. Jun 7, 2024 at 3:57 AM
    Woocawachie
    Dickens
    Philadelphia
    Let us know… and take lots of pictures. I’m going to need step by step lol
  28. Jun 7, 2024 at 7:38 PM
    paravane
    paravane New Member
    c
    I'm 100% wingin it. But I'll try.
  29. Jun 7, 2024 at 11:30 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Standard with TRD pkg no matter the bed length. My Limited TRD OR 5.5’ has it std.
  30. Jun 7, 2024 at 11:42 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    Nope, my 23 TRD has the small tank.
    You need the optional deluxe electronics package to get the larger tank. BSM, more front and rear sensors etc.
