Battery not charging properly interior fuse box no power
Discussion in '2nd Gen Tundras (2007-2013)' started by tsalinas2001, Nov 16, 2023.
  1. Nov 16, 2023 at 4:38 PM
    tsalinas2001
    tsalinas2001 [OP] New Member
    Timoteo
    2008 Tundra TRD Limited
    Hello everyone,
    I’ve been having a lot of issues here lately. It all started with my battery not charging while driving, falling below 9v. I had the alternator and battery tested. They were both bad and replaced. I put in a 150 amp alternator. I was also having issues with not being able to shift out of park, dash lights on (see picture), no blinkers, and no power to part of the interior furs box (see picture) I have gone through everything through everything that I can think of. Also the alternator is only putting out about 12.2v. If you have any ideas, o have gone through the same issues, please let me know what’s going on.
  2. Nov 17, 2023 at 7:05 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Replace the 7.5A AM1 fuse, it is in line with the ignition circuit and relay when the key is on. If it is bad power will never make it to all the fuses in your red box.
    The alternator is not charging and the blinkers are not working because the 7.5A LH-IG fuse is not getting power. It is the "ignition signal" to the turn on the voltage regulator and allow the truck to charge when running.
    A new 7.5A AM1 fuse will probably fix all of your problems. Pull it out, visually inspect it, and then replace it with a new one, even if it doesn't look fully burned out/blown.
    NewImprovedRon likes this.
  3. Nov 17, 2023 at 7:22 AM
    Check your grounds too
  4. Nov 20, 2023 at 3:08 PM
    tsalinas2001
    Timoteo
    I have checked all the grounds and replaced the fuse in the AM-1 slot and it’s still doing the same thing. Any other ideas? I read something g about the battery bulb having an affect with it also. Is it supposed to glow white when the key is in ACC or red. Mine is white.
  5. Nov 20, 2023 at 3:12 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Did you study the fuse box cover and layout of the box to make sure it was the AM-1 fuse? Have you checked this fuse for power using a multimeter?
  6. Nov 20, 2023 at 4:17 PM
    tsalinas2001
    Timoteo
    Yes I’m positive it was the correct fuse. I also checked it with my multimeter and it was getting power to both sides of the fuse before and after I changed it.
  7. Nov 21, 2023 at 9:33 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Then you most likely have a bad ignition switch or a break in the wiring somewhere. Are you pretty goo with a volt meter?
  8. Nov 24, 2023 at 5:40 AM
    tsalinas2001
    Timoteo
    Yes I am. The only thing that’s killing me is that I don’t know how to read a wiring diagram. Me and wiring are not friends. That’s why I have been having trouble with this problem.
  9. Dec 14, 2023 at 1:26 PM
    tsalinas2001
    Timoteo
    I changed out the ignition switch and it didn’t change anything. I’m still getting low charge to the battery, no turn signals and it won’t come out of park.
  10. Mar 29, 2024 at 4:29 PM
    tsalinas2001
    Timoteo
    So, I finally got my truck up and running. Took it to a shop and turns out it was a bad fuse box. $1500 to replace it. $1100 for the part and $400 in labor.
