  1. Mar 28, 2024 at 7:39 PM
    RobertD
    Robert
    DFW, Texas
    Looks good :thumbsup:
    Vizsla[QUOTED] likes this.
  2. Mar 28, 2024 at 7:39 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Great Jam on the radio
  3. Mar 28, 2024 at 8:09 PM
    Vizsla
    Vizsla 2 = 2.5
    Yeah buddy! Btw @reywcms, look at my fuel pressure gauge. In today’s episode of shit you don’t need/want to know, it holds some fuel pressure if parked up hill or level, for weeks… Bleeds off parked down hill in a few hours. :monocle:
    reywcms[QUOTED] and bulldog93 like this.
  4. Mar 28, 2024 at 8:20 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Wtf lol hmm
  5. Mar 28, 2024 at 8:57 PM
    BuilderBee
    BuilderBee New Member
    Southern California
    2017 Tundra Double Cab TRD SR5
    BakFlip MX4 Tonneau Cover Stubby Antenna Husky Floor Liners
    What a difference with the new suspension and air bags. Leveled the front end. Air Bags definitely made a difference on towing and also adding a Flated camper shell made a world of difference to my truck.
  6. Mar 28, 2024 at 10:03 PM
    TundraBrew
    TundraBrew New Member
    Got my oil changed at the dealership (my first mistake, I know), and asked them NOT to perform the headlight recall because I swapped the halogens with LEDs. But they decided to do it anyway.
    All lights function as they should. Messaged ihacker, who says the recall mod should not affect anything.
    woods and bulldog93 like this.
  7. Mar 29, 2024 at 5:41 AM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    You mean you don’t daily your wide body LT Tundra?
    I’m at 61.5k. 7-8k of that is just getting to your side of the country…
  8. Mar 29, 2024 at 6:15 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The finished product looks just right to me
  9. Mar 29, 2024 at 6:21 AM
    grant.ducckk
    grant.ducckk New Member
    Grant
    2019 DC Cavalry Blue Limited 4x4
    What app are you playing music through that actually loads album art? I listen to Spotify all day every day and have never had a single album art come up on the display.
  10. Mar 29, 2024 at 6:30 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Mine loads art no problem I use Apple Music
  11. Mar 29, 2024 at 6:47 AM
    joey2018
    joey2018 New Member
    Proclip
    Bergy24[QUOTED] likes this.
  12. Mar 29, 2024 at 6:54 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Album art shows up on mine with Spotify (the free version).
  13. Mar 29, 2024 at 8:05 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    How hard was it to install the steering wheel? I’d really like to do the same. Super clean!
  14. Mar 29, 2024 at 8:08 AM
    foxhound81
    foxhound81 New Member
    Arizona
    2014 BRM Crewmax SR5
    Well finally took my first steps years later. My 'budget' lift.
    Bilstein 6612's, 5160's. Coachbuilder +3 shackles. Freedom Offroad UCA's. Method 703's +35. Toyo AT III's.
    When she came home:
    How she stand now!
  15. Mar 29, 2024 at 8:12 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Easy peasy
  16. Mar 29, 2024 at 8:14 AM
    grant.ducckk
    Grant
    Good to know, I will look into it. My guess is I have some sort of data-saver option so it doesn't load them.
  17. Mar 29, 2024 at 8:25 AM
    Vizsla
    Vizsla 2 = 2.5
    It’s easy, but will likely require an alignment after, so need to budget for that. The splines aren’t clocked the same on the cores used, so steering wheel will be off unless you get lucky. The AJT trim pieces are crap, just paint the original pieces or source the oem version.
    reywcms, bulldog93 and koditten like this.
  18. Mar 29, 2024 at 8:30 AM
    koditten
    Kirk
    Midland of the Mitten
    If you keep the SW locked in the perfectly 12:00 position, just attach new wheel in the same position. No need to get an alignment. The splines are pretty course on the steering shaft. If you are off 1 spline, you will definitely notice that the wheel is " off" and needs to be moved 1 spline left or right.
    Doing it this way also eliminates over extending the ribbon cable.
  19. Mar 29, 2024 at 8:43 AM
    Vizsla
    Vizsla 2 = 2.5
    Of course, but nope. The splines are clocked differently on the core, others have same results.
  20. Mar 29, 2024 at 8:58 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Pretty damn easy
    Takes longer to wait for the airbag circuit to be discharged after pulling the negative battery cable…
  21. Mar 29, 2024 at 9:00 AM
    RainMan_PNW
    Casey
    Clark County, WA
    My wheel (same one) was clocked the same as my factory wheel.
    Maybe I just got lucky…
    I can see where they could be off kilter though, since the spline socket is a press-in bushing in the wheel core, so if they aren’t consistently jigging the wheel core and spline bushing when mating those parts up, that could cause minor shifts in the wheel clocking from wheel to wheel.
    bulldog93 likes this.
  22. Mar 29, 2024 at 9:06 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    Hit my oldest and my birthday in the mileage.
  23. Mar 29, 2024 at 9:19 AM
    831mic
    831mic 2016 DC TRD PRO
    California
    '16 DC TRD PRO
    The "album art" in that photo was the stock "ROCK" image. I haven't had it load any album cover art on my '16, using spotify, plex, apple, Amazon. If the artist matches to what they have stored, it shows it, but usually WAY outdated.
  24. Mar 29, 2024 at 9:31 AM
    grant.ducckk
    Grant
    Interesting, the first image is stock, the second image is Chevelle's album art.
    The plot thickens!
  25. Mar 29, 2024 at 12:17 PM
    Durania
    Durania New Member
    Crossville, TN
    2019 Cavalry Blue CM Ltd
    Thank you! 275/65-18
  26. Mar 29, 2024 at 1:58 PM
    MountainMan
    MountainMan New Member
    Idaho/Washington border
    2021 1794 Edition
    Bilstein 5100s, 285/70R17s, Tuff Country rear add-a-leaves, Rough Country rear bumper, Rough Country CAI, Dirty Deeds Ind. straight pipe kit, Ironman Raid front bumper, 13k lb. winch, Leer topper, custom rack, Decked bed drawer system, AuxBeam fogs, Midland CB radio.
    Tuff Country rear leveling kit installed by local shop. Total nightmare. I just wanted a simple add-a-leaf installed to level the rear since the Leer topper and Decked system added a ton of weight and caused a slight squat.
    They quoted me $200 to do it Monday afternoon.
    A couple of hours later, the guy calls me at work and says they have the leaves in but that the factory U-bolts aren't long enough. OK, odd that Tuff Country didn't mention that or included them in the kit. Shop doesn't have any and neither does anyone local. I go online and order a 2" lift block kit with U-bolts for $40. I tell the shop that the new bolts and blocks will be here Thursday and I'll drop them off before I leave for work at 1pm.
    The blocks and U-bolts arrived and I stop by the shop to drop off the parts. There is a sign on the door saying they closed early. I put the parts in my pickup, which is sitting outside, call the shop number and leave a voicemail.
    Shop called this morning and said they have the parts, but to put in the 2" blocks will require more hours and they won't have time to get to it until next week, and the block kit says you need a brake line relocation kit, which is also not included. WTF?? I need my truck this weekend to meet the family at the cabin for Easter and the grandkids want to ride the ATV. So I tell him to just put the longer U-bolts on and get it drivable. He gets it done and I go to pick it up and the bill is nearly $400!
    I specifically paid a shop to do it so I could avoid a headache and have it ready for towing by the weekend. For what I ended up paying in parts and labor, I could have bought a Firestone air-bag system and installed it myself for much less stress.
    So, it is done, it rides fine, and it will do for hauling the utility trailer. But I will avoid Tuff Country products in the future due to their deceptive advertising and incomplete kits.
  27. Mar 29, 2024 at 2:23 PM
    dan8906
    dan8906 New Member
    Daniel
    2017 MGM Tundra SR5 TRD OR, 2011 Tacoma TRD OR & 2004 Tacoma TRD OR
    I thinks it’s important to note, that ubolts are a stretch to torque style bolt and should be replaced.
  28. Mar 29, 2024 at 2:23 PM
    centex
    centex New Member
    Make sure I’m following but you wanted an add a leaf but then added blocks in as well?
    koditten likes this.
  29. Mar 29, 2024 at 2:31 PM
    MountainMan
    2021 1794 Edition
    With the add a leaf, it leveled it out, but since I plan on doing some towing, I figured a shorter block would give enough rake to level it when towing. I'm glad the blocks didn't work out since I'll likely add air bags this summer.
    HulkSmurf14 likes this.
  30. Mar 29, 2024 at 3:33 PM
    coTony
    Tony
    Montrose, CO
    Been trying to find a place to mount my gas cans and they end up beside my spare each time so I bought the mount kit for the spare. Works for me
