2023 6.5’ bed mat recommendations
Discussion in '3rd Gen Tundras (2022+)' started by Grumman41, Aug 16, 2023.
  1. Aug 16, 2023 at 8:21 AM
    Grumman41
    Grumman41 [OP] New Member
    I don’t think I’ll get my OEM bed mat and moving on. Any recommendations for a good bed mat for my 6.5 bed? I’m not sure what type of protection for the tailgate, it will probably get a lot of wear also. Not really wanting to drill extra holes for a mat type protector on the tailgate.
  2. Aug 16, 2023 at 8:29 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    Depends on your use case. A lot of us lighter duty users have bedrugs. They work great for gear and luggage under a tonneau cover and come in several varieties that cover just the bed, or also the sides and tailgate. And come out easily if you want to pick up a load of gravel or mulch. But if you are gonna mostly be hauling messy or heavier stuff the OEM would be the way to go.
    NewImprovedRon likes this.
  3. Aug 16, 2023 at 9:30 AM
    brutalitybob
    brutalitybob New Member
  4. Aug 16, 2023 at 9:51 AM
    pronstar
    pronstar New Member
    Robert
    Not a Tundra :-(
    2015 Silverado: 2.5” Kings front/rear. Icon Delta Joint UCA’s. Deavers. 17” Method 703 BeadGrips. 33” BFF KM3 2018 Suburban: 2.0” Fox front/rear. Dirt King UCA’s. Mall Cruiser.
    I run a Rough Country bed mat, and i’m happy with it. It was under $100 on Amazon, and is made of very thick & heavy rubber.
  5. Aug 16, 2023 at 10:23 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Another vote for a BedRug. However, you can get a thick rubber 4' x 6' stall mat at your local Tractor Supply reasonably priced, if you have one. The mat has a raised pattern on one side and is flat on the other. You could put it in with the flat side up.
    Goose74 and Hella Krusty like this.
  6. Aug 16, 2023 at 10:46 AM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
  7. Aug 16, 2023 at 11:04 AM
    Mykeromachine
    Mykeromachine New Member
    2022 Tundra TRD Offroad
    I definitely have a vote on the BedRug product, it gives a little cushion when moving around on my hands and knees in the box plus seems to keep things from sliding around back there. I also appreciate the fact it's one piece that goes from the tailgate to the cab and covers the gap between the tailgate and cab so things don't fall through.
  8. Nov 10, 2023 at 8:01 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  9. Nov 10, 2023 at 9:07 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have the Bedrug XL with the tailgate piece and it is great besides being super light weight. You can kneel on it without feeling the uneven bed floor. Great for knees. I can toss things in the box and they don't slide around.
    I didn't get the full sided one. Just the tailgate extension model.
  10. Nov 10, 2023 at 10:07 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    20231030_231152.jpg 20231030_231156.jpg 20231030_231202.jpg 20231106_162302.jpg Indeed, simply the best.
    Kept mine from 2.5 gen and had to cut down as the 3rd gen is smaller. Would have ordered new one but BA only makes it for long bed now. If hadn't kept old mat, would still order the long bed option and cut excess length. Which would've been much easier and cleaner than having to do the width !
    mmasse and NickBrewer[QUOTED] like this.
  11. Nov 10, 2023 at 1:43 PM
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    2023 Tundra Hybrid Limited L TRD OR 4X4
    I really like my OEM 6.5' bed mat and Mountain Hatch tailgate insert. The insert provides a flat work surface and it was a very easy install with no drilling required.
    Mattedfred likes this.
  12. Nov 10, 2023 at 8:24 PM
    weifert
    weifert New Member
    Where did you buy yours? I didn’t see one on Amazon for a 3rd gen. Thx
  13. Nov 11, 2023 at 2:19 PM
    JDSTOY
    JDSTOY New Member
    2024 GMC 2500HD, 2022 Limited 6.5, 2000 Limited
    Definitely the Black Armor. Well worth the money.
    rapide, NickBrewer and Tundrastruck91 like this.
  14. Nov 11, 2023 at 3:17 PM
    bullet3z
    bullet3z New Member
    24 Tundra
    weifert[QUOTED] likes this.
  15. Nov 11, 2023 at 9:56 PM
    weifert
    weifert New Member
    Thanks! One other Q…. I have a drop in bed liner in my Tundra. When I watched the video for the Bed Rug XLT, it mentioned it doesn’t work well with bed liners at all. And that it only works with spray in liner or no liner at all. Seems the underside of the bed rug matches the contour of the original bed (or spray bed). Is this what you have experienced as well? Do you have a drop in liner on your Tundra, were you added a Bed Rug XLT?
  16. Nov 12, 2023 at 3:43 PM
    bullet3z
    bullet3z New Member
    24 Tundra
    It will replace the drop on liner. The bottom of the Bedrug has ribs that rest in-between the factory bed ribs making the floor flat. This will be my 3rd Bedrug. I like them. When I took the rug out of my last truck, there was not a single scratch or rub mark anywhere on the painted bed.
    raylo and weifert like this.
  17. Jan 16, 2024 at 2:16 PM
    lakai536
    lakai536 New Member
  18. Jan 16, 2024 at 2:25 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    @lakai536 Where are you located? There is a 6.5' Bed bedrug on CR in the Vancouver area. This looks like a good deal if you are close enough to take advantage.
  19. Jan 16, 2024 at 2:28 PM
    lakai536
    lakai536 New Member
    I'm out in Montana so unfortunately a little too far for a bed mat. Thanks for the heads up though!
    PBNB[QUOTED] likes this.
  20. Jan 16, 2024 at 2:39 PM
    BlueCrushSC16
    Charleston, SC
    The quality is good, IMO. I've hauled drywall, 3/4 plywood and construction material in general, firewood, Pelican cases, thrown power tools on it, and run it through the touch less car wash with no problems. It's holding up like a champ. Things aren't sliding around on top of it back there.
  21. Mar 29, 2024 at 12:05 PM
    ChickenRat
    ChickenRat Yep.
    ‘24 MGM Limited OR
    Thanks for the info, I just ordered this one.
  22. Mar 29, 2024 at 12:55 PM
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    Les Schwab has the Black Armour mat for 6.5' bed. I got one a couple weeks ago for $146.
  23. Mar 30, 2024 at 5:31 AM
    ChickenRat
    ChickenRat Yep.
    ‘24 MGM Limited OR
    I really liked these but unfortunately the there are no Les Schwab’s in my area.
  24. Mar 30, 2024 at 8:48 AM
    Tundrastruck91
    That's a steal ! Paid 2x that about 2 years ago now when bought online.
  25. Jun 15, 2024 at 8:17 AM
    tamadabee128
    tamadabee128 New Member
    Just confirming you do not have a drop in liner correct? I’m an idiot and assumed just because I didn’t have bare metal, I had a drop in liner.
    I’m curious because I also want to get the XLT, but it mentions no drop in liners.
  26. Jun 16, 2024 at 7:37 PM
    Mykeromachine
    No I did not have the drop in liner, just the bed rug attached to the composite box.
  27. Jun 16, 2024 at 9:14 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    Buddy of mine just bought the weather tech bed mat and love's it
  28. Jun 17, 2024 at 7:27 AM
    ArBrnSnpr
    ArBrnSnpr New Member
    Colin
    22' AG SR5 TRD OR
    Which location did you get it from?
  29. Jun 25, 2024 at 9:58 AM
    Twin2turbo
    Pacific NW
    The Lake Grove / Lake Oswego location.
  30. Jul 9, 2024 at 11:08 AM
    mstanley13
    mstanley13 New Member
    2023 Tundra Hybrid Platinum
    Anyone tried the weather tech impact bed liner and tailgate protector with the factory composite bed liner still installed? I called weather tech to confirm compatibility, but the representative on the phone didn’t sound too confident about the fit.
